Old February 26th, 2015, 08:17 PM   #1
txnili
Motorcycle(s): 2004 Kawasaki Ninja 250 & 2004 Suzuki Katana 750
stupid fricken too big airbox help
Does anyone know how to put the airbox back into an '04 250? Saw a video where it was pulled out so know it most likely needs to be apart first but no matter what I try the thing won't go in. I bought it and it was missing. Ordered one and think now it was a waste of money. I tried with the motor unbolted and leaning all the way forward, taking off coolant reservoir and wire harness on right side. This is why I don't buy Kawasaki. Unfortunately I got this to teach my daughter throttle control before getting on track with a real sport bike. I just thought I was good a tetris
txnili is offline   Reply With Quote
Old February 26th, 2015, 08:56 PM   #2
Sorry Patrick,
There just is no "quick trick" to it. If you want it done right, then here is the link. To get the box completely out, your gunna have to remove the rear wheel and drop that fender completely off. And ya... it's a complete pain in the arse!
https://www.ninjette.org/forums/show...02&postcount=1
Old February 26th, 2015, 09:03 PM   #3
Originally Posted by txnili View Post
Does anyone know how to put the airbox back into an '04 250? Saw a video where it was pulled out so know it most likely needs to be apart first but no matter what I try the thing won't go in............
http://faq.ninja250.org/wiki/Removing_the_airbox
http://faq.ninja250.org/wiki/Battery...r_carb_removal
Old February 27th, 2015, 09:42 AM   #4
ninjunk
Lostcause enthusiast
Motorcycle(s): 2000 EX250F
D This is why I don't buy Kawasaki.
boy, if you think getting the airbox on a ninja 250 is tough don't ever buy a VFR Interceptor (honda) or just about any inline-four cylinder sportbike. Lots of 'modern' bikes you have to just about remove the engine, subframe or other major work to get the airbox in and out.
ninjunk is offline   Reply With Quote
Old February 27th, 2015, 10:45 AM   #5
agentbad
agentbad's Avatar
Sorry Patrick,
Sure there is. It involves beer and a hammer followed by pods and jets.
Old February 27th, 2015, 10:55 AM   #6
MrAtom
MOTM - July '15
I didnt have a problem with getting it off, but now that you mention it, it is pretty in there.
Old February 27th, 2015, 10:59 AM   #7
I had....
3 Beers
1 Screwdriver
1 dremel w/ cutting wheel
It was off and out in 5 minutes. I think of it like an airbox abortion.
Old February 27th, 2015, 02:49 PM   #8
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
I put the moto on the center stand, removed the top shock bolt to drop the swing arm enough to be able to remove the fender bolts and also squeeze the air box out. If you can put a piece of wood under the center stand to raise the rear a bit more it would help the swinger drop more.
My Cafe Racer Build
My intro post
Old February 28th, 2015, 06:03 AM   #9
I can get it in and out in 20 minutes. It just takes some finesse. It's like Tetris, yo!!
The halves have to be cocked at a little angle and slid past each other. If you can cut off the battery box, it really helps with getting you space to slide it fore/aft.
Old February 28th, 2015, 08:01 AM   #10
Ghostt
Ghostt's Avatar
I have done the battery box mod I highly recommend it
violente et ignorantia
ZX-2R BLOG
Old February 28th, 2015, 01:07 PM   #11
Yarhj
Yarhj's Avatar
Motorcycle(s): Ninja 250 (2001)
+1. The battery box mod will change your life.
Yarhj is offline   Reply With Quote
Old February 28th, 2015, 02:00 PM   #12
Get on my level. did that before N4mwd showed it. Only I used a hacksaw.
Old February 28th, 2015, 02:03 PM   #13
Ghostt
Ghostt's Avatar
get on my level. Did that before n4mwd showed it. Only i used a hacksaw.
like a boss!!!!!
BTW I'm bringing that say back,so get use to seeing a lot from now on.
who else is with me?
ZX-2R BLOG
Old February 28th, 2015, 04:39 PM   #14
greenaero
Motorcycle Hypermiler
greenaero's Avatar
Motorcycle(s): 1999 & 2005 Kawasaki Ninja 250R's
Gotta agree, the battery box mod makes a huge difference!
235 MPG Hypermotorcycling to a better tomorrow
greenaero is offline   Reply With Quote
Old February 28th, 2015, 07:45 PM   #15
ieathonda
ieathonda's Avatar
Motorcycle(s): Ninja EX250F
Did the battery box mod today. Also only had a hacksaw. Took about 20 minutes. Removing the airbox was a cinch compared to me separating the battery box and airbox.
ieathonda is offline   Reply With Quote
Old February 28th, 2015, 07:47 PM   #16
Ghostt
Ghostt's Avatar
Yea, if you don't do the modification, you won't be one of the cool kids
Or be forever doomed like these kids, are, and ALWAYS WILL BE!!! Regardless of the catchy tune.
ZX-2R BLOG
Old February 28th, 2015, 11:06 PM   #17
ieathonda
ieathonda's Avatar
So.. Kinda unrelated but did you guys worry about the battery tie down after the airbox mod? I'm on pod filters and don't have the oem battery tie down installed
Old February 28th, 2015, 11:18 PM   #18
Ghostt
Ghostt's Avatar
The modification doesn't bother that, at least not in my case, and most others as well, I'm sure.
Pod filters huh??
ZX-2R BLOG
Old March 1st, 2015, 06:14 AM   #19
Haven't used that battery strap in many thousands of miles. Yet to have a problem
Old March 1st, 2015, 06:16 AM   #20
Ghostt
Ghostt's Avatar
I'm sure there's a joke there somewhere about strap on?
ZX-2R BLOG
Old March 1st, 2015, 07:25 AM   #21
crazymadbastard
Stunt much?
My Cafe Racer Build
My intro post
Old March 1st, 2015, 08:11 AM   #22
nope, but the distance from the top of the battery box to the seat is smaller than the height of the battery, soooooooo regardless of what you do do it, it's not coming out while the seat on.
Let's put it this way. I crashed at ~50mph and slid across a 50' wide track, then the bike hit the dirt hard and came to a rapid stop. Battery wasn't a problem.
Old March 2nd, 2015, 07:26 PM   #23
txnili
Thank you all especially csmith12 for link. 10 bolts and the rear tire removed damn thing slid in perfectly. The issue isn't getting it out its getting it in and I don't want to cut it apart. The guy that had I bought it from did that but single pod filters wouldn't stay on from motor vibration. I don't need it suped up I just need it running right to teach my daughter throttle control. Head gasket was blown on it so I got all that replaced and fixed. You guys have been great helping me and love your senses of humor it gets me back to an eased state of mind being able to laugh about it. I was trying to get the 2 pieces to wedge in and damn hand slipped hit frame and broke a fricken nail. Seriously it tore half my thumbnail off I don't recommend it. Hence the original post that actually kinda hurt. Bad thing now is it dies without the choke on. He changed the jets to stage 2 and I know with the airbox the air fuel mixture is now jacked but that's easy fine tuning with the carbs. Really appreciate all your help
Old March 2nd, 2015, 07:29 PM   #24
txnili
I don't drink never liked alcohol and being seriously hit by 2 drunks in cars kinda ruins it more but there have been a few days on this I thought about several shot of tequila with Tabasco ;-)
Old March 3rd, 2015, 08:54 AM   #25
Old March 5th, 2015, 08:13 PM   #26
Finesse
ran when parked
Finesse's Avatar
MOTM - Sep '17, Dec '14
I had....
3 Beers
1 Screwdriver
I just DIED
LMAOOOOO
Instagram: @katie.baden
What are these airbox hoses for? Braden07 2008 - 2012 Ninja 250R Tech Talk 5 February 1st, 2015 06:40 PM
stupid stupid video toua70 General Motorcycling Discussion 24 September 28th, 2012 04:32 PM
for those of you who killed your airbox... rabies 1986 - 2007 Ninja 250R Tech Talk 18 September 11th, 2012 06:19 PM
'08+ Airbox Countersteer Motorcycle-related 0 June 10th, 2012 12:50 PM
[superbikeplanet.com] - All That Chaz: Big Fish, Big Country, Big Mountains & Big Pla Ninjette Newsbot Motorcycling News 0 February 2nd, 2011 11:51 AM
