December 3rd, 2014, 04:36 PM | #1 |
08 stumbling and not moving hard
So lately in the last few weeks my bike when its cold its fine. Rides well, tons of power and all of that.
After it warms up, it starts to stumble. So if i give it throttle i hear the bike, but the bike is not moving. And its gurgling a bit, as if its running out of gas. I thought at first i got bad gas, but now im on my 3rd gas tank and still the same. Feels like a carb issue. Because if iopen up the throttle wide it hesitates a bit. Also when its warm, at idle it dies if i dont have some throttle on. ANd if i put it at 2k rpms and keep it stable it comes down by itself. Anyone know any ideas of what it might be. 87k miles on the bike. Thanks |
December 3rd, 2014, 04:50 PM | #2 |
What other information can you provide, did the bike sit? Daily rider? Did you make any changes before? Fuel filter? Etc..... You get the point
December 3rd, 2014, 04:52 PM | #3 |
it sat a few days. I have 2 other bikes that i ride daily. I ride this one at least 2 times per week.
I didnt make any changes to the bike at all. Just ride it. Its had a recent oil and filter change. The oil level is fine. Checked the air filter and its clean. But basically i do ride it often, often enough it shouldnt gunk up the carbs that easily if i leave it for a few days right? |
December 3rd, 2014, 06:26 PM | #4 |
87k is a lot of duty cycles for the moving parts inside those carbs
Yes, the unstable idle and inability to hold steady RPM at partial throttle indicate some problem in fuel metering. I'd suggest to fully service the carbs (replace the float valves, set the fuel levels) , spark plugs, purge the fuel (water congeals at the bottom points of a tank, btw) , check all filters, etc etc. Also have the other recommend services been performed.
December 3rd, 2014, 06:34 PM | #5 |
The carbs are actually new from another bike. So they are the newest things in the bike lol. Ill have to pull the carbs apart and look at them. Not sure if the float valves are off. Might the needles be gunked up?
December 3rd, 2014, 06:38 PM | #6 |
Check the slides too, and are you running a fuel filter? I would as long as you have them out, give them a good and through going over and clean, etc.....
What about other services done? Plugs? Plugs caps? Etc.....
December 3rd, 2014, 07:10 PM | #7 |
not running a fuel filter. Just the one that is in the hose that comes with the bike.
The sparkplugs are fairly new, but i havent checked them. Ill have to do that first before i pul the carbs. But since i have it off, might as well check it. Im going to tackle this tommorow. Thanks for the suggestions |
December 3rd, 2014, 07:16 PM | #8 |
Just remember to take your time and be methodical.
December 7th, 2014, 05:45 PM | #9 |
She is stumbling. So im taking her apart finally. anyone can read these plugs? They seem ok to me, just a little dirty. When i pulled into my garage the bike smelled of gas. |
December 7th, 2014, 05:47 PM | #10 |
btw, i had the gas on prime instead on the vertical position. I've run it like this for quite some time, would this effect it?
December 8th, 2014, 06:18 PM | #11 |
looked a bit more carefully and i think i might have found the source of the problem. There is a small crack in the airbox that goes from the carb to the box. I had some silicone there but it was flaking out. Im not entirely sure it is it.
But when i sparyed starter fluid when she was idling she wasw spike only in the section. Im going to get some sealant and hopefuy close that very small crack off. |
December 10th, 2014, 03:41 PM | #12 |
Alright, so it ws not the airbox. I rode the bike today and it displayed the sam symtoms. Funny is that when its cold with less than 5 iles it pulls really hard as normal. But after warm up, it displays the stuttering and lack of power.
I need to see if its still a vaccum leak anywhere, i didnt pull off the carb or the air box. So ill have to do that . |
December 10th, 2014, 03:51 PM | #13 | |
Pull the plugs and see what they look like to confirm. |
December 10th, 2014, 03:58 PM | #14 |
The plugs look pretty good
December 10th, 2014, 07:35 PM | #15 |
could a weak battery be the culprit here? my battery this summer actually reverse polarity. When I got back from vacation it was on the battery tender and when I went to started it when I want but when I reversed it and the cables it worked.
December 10th, 2014, 07:39 PM | #16 |
cadd cadd cadd
MOTM - May '15
Have you tried spraying starter fluid or carb cleaner on the boots of the carbs (carb to motor and carb to airbox)? Any reaction with idle speed?
I'm really interested to see what it is. It's just weird that this happens only when the bike is warm. |
December 10th, 2014, 07:48 PM | #17 |
yes and sprayed starter fluid in the carb boots. The first time I sprayed them there was a little response. I filled a hairline crack width sealant. Now there is no fluctuation in the idle. There seems to be a small gap in test car boot but spraying starter fluid around does nothing. So now I'm not sure if its a vacuum leak. My air filter seems clean, but I've never replaced it. I have high miles on this bike so it could be the air filter?
December 10th, 2014, 07:49 PM | #18 |
my trying some seafoam too. Maybe you're running it through the carb my dick trick. I'll let you guys know
December 10th, 2014, 08:54 PM | #19 | |
Run some Chevron Techron Concentrate fuel system cleaner at 1oz per gal with your next tank. Use 87 octane. Plugs don't look bad. Overall not black enough to be overly rich during most riding. A bad battery will cause odd running problems. Check that it stays at 12.7V after leaving it set for a couple of hours (after a ride). |
December 10th, 2014, 09:03 PM | #20 |
Sounds like a good time to upgrade to a K&N air filter to me, I'd personally change the plugs, after all your half way there anyway.
December 11th, 2014, 12:18 AM | #21 |
cadd cadd cadd
MOTM - May '15
Is there a strong gasoline smell in the airbox when you inspected the air filter? I know you mentioned that you smelled a strong gasoline odor when you pulled the bike in the garage.
December 11th, 2014, 05:19 PM | #22 |
December 11th, 2014, 05:20 PM | #23 |
removed the carbs. there is a bit of plastic hose in the middle in that pic that is cracked.WHen i bought the this carb, it was broken and i still put it in, so im wondering if that is the reason? it didnt do it and ive ridden with it for several thousand miles.
December 11th, 2014, 10:07 PM | #24 |
ran when parked
Join Date: Aug 2013 Motorcycle(s): Freeride 250R, KLX250SF, mopeds Posts: A lot.
MOTM - Sep '17, Dec '14
'tons of power'???
clearly something is indeed very wrong. sorry, I had to........
Instagram: @katie.baden |
December 27th, 2014, 03:28 PM | #25 |
Boy Racer
Join Date: Oct 2013 Motorcycle(s): 08' NINJA 250R, 2013 BMW HP4 Posts: 41
Sounds like a vacuum issue had this a few months back was a spider stuck in my vacuum and this was the cause of the issue
Ride List: Current: 09' Ninja 250r Previous: 99' ZZR250 |
December 29th, 2014, 01:53 PM | #26 |
December 29th, 2014, 02:39 PM | #27 |
I'm crazy,your excuse is?
when where the valve clearances checked last?
December 29th, 2014, 08:56 PM | #28 |
Down Under
Join Date: Jun 2014 Motorcycle(s): Kawasaki ZXR250C Ninja Posts: 296
Here is my assessment:
Your plugs don't look the same. As if one cyl is running lean and one is rich. Bogging down could be too lean on one cyl or too rich on the other. Or both. Maybe the mixture is wrong? I would bench the carbs and have them synced, adjust the mixtures, etc. Run the bike for a bit and check the plugs again |
December 29th, 2014, 09:02 PM | #29 | |
Bench check those puppies for sure, but your problem is NOT carburetor synchronization, unless something really has gone sideways.
Hesitation/Stumbling 6K to 8K - Looking for Source - Ideas? | eif | 1986 - 2007 Ninja 250R Tech Talk | 5 | June 23rd, 2014 05:40 PM |
[visordown.com] - How hard is Dunlop pushing? This hard | Ninjette Newsbot | Motorcycling News | 0 | June 7th, 2013 11:20 AM |
stumbling bike | FvnnyL3tt3r1ng | 1986 - 2007 Ninja 250R Tech Talk | 105 | February 11th, 2013 04:29 PM |
Newly acquired 2003 w/ Muzzy - stumbling on off/on throttle and gas smell. | fierostetz | 1986 - 2007 Ninja 250R Tech Talk | 11 | August 23rd, 2012 04:00 PM |
[crash.net - MotoGP] - Singapore race plans hit stumbling block | Ninjette Newsbot | Motorcycling News | 0 | February 15th, 2010 03:30 AM |
