June 22nd, 2012, 07:57 AM | #1 |
Join Date: Mar 2012 Motorcycle(s): '08 Ninja 250R (SOLD - 2/16/2013) Posts: 492
Rear tire skid/lock during a downhill left turn.
Coming home from the DMV, right after turning in my MSF endorsment there is an S-curve. The way I was going the first part of it is uphil and it turns downhill right at the inflection point (second part of the S). Being pretty exceited, added to the fact that a minivan was riding my arse I went into the second part (downhill) of the curve too fast. I use what I think is a little rear brake and start to feel the rear wobble or fishtail.
What surprised me during and after is that I was surprisingly calm (not to toot my own horn :P). Now what I did next may not have been the best but it seemed to have worked: Put the clutch into the friction zone to take a bit of power from the rear wheel and released the rear brake as I slowly released the clutch to get full power back to the rearwheel. The frequency of the wrobble went up but as I rolled on the throttle and finished the turn the bike stabilized into the straight away. What made it a little bit scary is that there was a broken down car ron the side of the road, had it not been there I would have taken the turn a little wider and maybe kept from using the rear brake at all. All in all, I think having the MSF course fresh under my belt may have saved me from a spill. God bless.
Mods/Add-on list: DanMoto Jisu, Snorkel delete, Shimmed needles, K&N Drop-In filter, T-Rex frame sliders, Shogun swing-arm spools, CBR250 Rear Hugger, Buell XB Pegs. DIY polished rim lips |
June 22nd, 2012, 08:18 AM | #2 |
hates stupid people
Good to hear you took the MSF but I don't see how you really followed any of it's teachings in this situation unless your course was different from mine. You braked mid-turn which they tell you not to do since they want you to have your entry speed set before you hit the turn so you can throttle through. Also, you said it locked and yet you let off the rear brake even though they teach you not to. Lastly, they teach you to ride your own ride and if someone is tail gating you, increase your following distance from the vehicle infront of you and if possible, let them pass. Better to let them go in a hurry then go down trying to ride how they want you to. What did you follow from their teachings?
A week or two ago, I went out on some mild twisties with a friend and found myself too hot into a turn for my comfort level (I'm sure the ninjette could've eaten it no prob). Anyways, I braked and while I didn't lock anything up, it definitely gave me a sick feeling and I knew that's not what I should've done. I read something on here recently that I've tried to apply to my riding and so far, it's worked for the best and makes things feel much better. I usually do better with my entry speed now but if I do find myself going a bit too fast, I just trust the bike and lean more. Chances are, the bike still has plenty more room to lean and can handle anything you're hitting on city streets. Not being a dick or anything like that so hope I don't come off like that. Just my opinion.
My vlogging channel: Ma1iciousLogic |
June 22nd, 2012, 09:53 AM | #3 |
If going fast enough, the inertia of transferring from uphill onto downhill may have lighten the rear wheel enough to loose grip due to the effort of light braking for an instant.
Don't let tailgaters rush you; if you are going to fall, don't you want the guy following to be moving 10 mph slower? Don't enter curves which end you can't see at any speed higher than you are able to brake safely. Whenever in doubt about stability, gas it out!
June 22nd, 2012, 10:06 AM | #4 | |
They didn't tell us NEVER to brake in a turn because that would be impossible, they taugh us that IF possible straighten the bike before braking but they also expressly said that it's not ALWAYS possible, as it was in this case. As I mentioned there was a car on the side of the road, on a two way two lane road. I had no room to straighten and THEN brake. I never said I followed the teachings (show me where I did), and in this case I certainly didn't, this course saved me because I was confident to take the steps I did in a safe and controlled maner, instead of panicking. I was able to take the course on my own bike and pushed my comfort and controll of it to another level. I try to be a safe rider, but like they ALSO taught in my course, what they teach you is in a controlled IDEAL condition which vary rarely if ever happens outside of that course, and as I know in this case it didn't. Should I have slowed down before the turn? Yes, now I know, should I have let the van rush me? No, I know. Like they ALSO taught us, incidents are naver caused by a single thing, it's always a chain of events. I was elated and a bit too excited, I had a tailgater, I didn't slow down: 3 things if not more caused this. In the end I was able to know that it was within my ability, and the bike's to come out of this situation by doing what I did, instead of deciding to ditch the bike before I went into the car on the side. tldr; I didn't have an ideal environtment, thus I didn't take the ideal approach, like I would have during the MSF course. Do I still think the MSF possibly save me some skin and or plastic? Yes.
June 22nd, 2012, 11:51 AM | #5 |
Join Date: Nov 2010 Motorcycle(s): KTM 390 Duke Posts: 428
When going downhill, your weight shifts forward... so when you brake, the rear wheel will be lighter than what you practiced on level surface, and it will lose traction much easier.
Good to know you'er not taking MSF teaching as dogma - if you need to brake in a turn, just do it. Looks like you did very well, and appear to have a smooth and natural feel for the bike. Also, make sure to look not at the broken down car on the side, but away from it... you go where you look. Great job, man! |
June 22nd, 2012, 01:30 PM | #6 | |
Also, I have to admit that I did fixate on the car for a second and is probably another thing that added to this whole ordeal. When I signed up for the MSF course people kept saying I shouldn't take my own bike, incase I dropped it. Now, after the fact, I am so glad I did. Learning all those techniques is really great but I feel so much more confident having done it on my own bike, it really made me get to know my bike. I would really recomend taking your own bike, for any one who is going to take the BRC in the future.
June 22nd, 2012, 04:00 PM | #7 |
The MSF course I took taught us to ride the bike to a stop if the rear brake locked. Otherwise, you could high side if you release the brake at the wrong point.
The point to remember is that you need more front brake and less back brake. A locked rear brake is actually a pretty dangerous thing. In addition to causing high sides on the straightaway, it can also cause your rear to slide out on turns. It sounds like you need more experience, so use that as an excuse to go riding some more.
June 23rd, 2012, 11:47 AM | #8 | |
April 16th, 2015, 09:34 AM | #10 |
MOTM - Sep '14
this guy is good at slowing down fast
Keep calm and ride on -Motofool Never quit on a rainy day -ally99 |
April 16th, 2015, 10:31 AM | #11 |
Steep downhill turns are fundamentally different than uphill and level turns. Knowing that the bike needs a 40%/60% weight distribution for the best possible cornering, you can begin to figure out how to approach and complete the turn. Logically, going downhill will put more weight on the front. What can you do to help the bike "work as it was designed"?
Throttle control? Entry speed? Turn in point? Seating position?
April 16th, 2015, 04:59 PM | #12 |
Join Date: Sep 2013 Motorcycle(s): 2015 Yamaha FZ07, Ninja 250r 2012 Limited Edition (Sold) Posts: 529
Just a little maintenance throttle is good in a downhill. Not enough gas to accelerate. Just enough to shift weight to the rear wheel.
If you just got your MSF you might want to hold off on braking in a turn. It's doable but difficult. Especially using your rear brake in a turn.
"Take it easy driving. The life you might save might be mine." |
April 16th, 2015, 06:49 PM | #13 |
MSF is great and all, but it's just a starting point...Plus each MSF instructor can vary in suggestions.
Highly suggest you get books like Total Control and take some of their courses. Other than that sounds like you did good!
My replies are intended for street riding only, plz do not provide track only replies. Visit my new MotoVlog Channel !! |
April 16th, 2015, 07:15 PM | #14 | |
Private Joker
MOTM - Mar '14
lower entry speed to adjust for more throttle turn in point same since the goal is to get on throttle sooner already sit farther back if you can, I like to sit pretty far back in the saddle so I don't think I could comfortably move any farther back most importantly though, moar throttle!
April 16th, 2015, 07:30 PM | #15 |
April 16th, 2015, 07:30 PM | #16 |
Join Date: Aug 2014 Motorcycle(s): 2007 Ninjette Posts: 809
Just so it's clear.. 2012 was OP post date
"That's what" -she |
April 16th, 2015, 07:36 PM | #17 |
Private Joker
MOTM - Mar '14
silly roark, there wasn't a marquez in motogp in 2012
discussion still has merit at least
April 17th, 2015, 07:32 AM | #18 |
Join Date: Mar 2015 Motorcycle(s): gsxr 600 2012 Posts: 120
no humping the tanks took a newbie like myself FOREVER to figure out. That little detail just doesn't seem out there in the public. In the MSF course I was told to grip the tank obviously I am sure to help reduce weight on my hands. So, when I started on a sportsbike I hugged that sucka After reading twist of the wrist and noting the support the riders got from the rear cowl I had a "aha" moment and started to schooc back in my seat and I noticed it was much easier to relax my hands and legs and keep out of the wind better!! That and my size 45 shoe now hits the exhaust like I hear others complain about so it is all falling together
Motorcycles are stable, I am not. RELAX-Keith code |
April 17th, 2015, 10:40 AM | #19 |
I'm crazy,your excuse is?
Braking is sooooooo 2012.
I never get bored reading about close calls. |
April 17th, 2015, 11:36 AM | #20 |
You don't even know how true that statment is.
April 30th, 2015, 06:23 PM | #21 |
vampire
Join Date: Feb 2011 Motorcycle(s): 2 many 2 list Posts: A lot.
Brakes, who needs them; they only slow you down..
---Snuff Smith-- |
Rear Brake Lever Travel is Excessive and Rear Brake won't Lock Tire. | N-m | 1986 - 2007 Ninja 250R Tech Talk | 14 | July 17th, 2014 04:13 AM |
Braking in a turn while going downhill | GreatScott | Riding Skills | 35 | July 16th, 2014 09:27 AM |
Decreasing radius downhill turn.... | Jiggles | General Motorcycling Discussion | 83 | July 8th, 2013 02:22 PM |
Left Rear Set / Turn Lights | HeteronimoFD | Items Wanted | 0 | May 21st, 2010 01:00 PM |
