April 26th, 2015, 03:21 PM | #1 |
MOTM - July '15
Do I need a new clutch cover?
My dad said he could get off my stubborn gasket and I caught him using a wire brush on a drill and stopped him before he could **** it up more. Do I need a new clutch cover now?
April 26th, 2015, 03:28 PM | #2 |
No, just lay a thin bead of blue silicone around the cover before laying down the gasket.
Reinstall WIN!
April 26th, 2015, 03:46 PM | #3 |
Agreed, except use black, it matches better Personally I've never used a clutch or stator gasket, just silicone
April 26th, 2015, 04:33 PM | #4 |
Join Date: Aug 2013 Motorcycle(s): 2012 Ninja 250 Posts: 450
Just use some permatex gasket maker and you'll be fine, just let it set for a short bit before installing.
http://shop.advanceautoparts.com/p/p...2072/7310173-P |
April 26th, 2015, 04:50 PM | #6 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
I'm a fan of Permatex UltraBlack.
April 26th, 2015, 05:07 PM | #7 |
yall gotta keep in mind that clutch cover holds the clutch puller pin thingy which pulls a lot on the clutch, so its better to use a paper gasket
April 26th, 2015, 05:09 PM | #8 |
Post #2 brah... color of your choice, but both the silicone + paper gasket = problem solved. I am sure you know what we are talkin' bout.
April 26th, 2015, 05:57 PM | #10 | |
Make your dad read this: http://www.dansmc.com/gaskets.htm Also, you can make a paper gasket yourself using this template: http://n4mwd.blogspot.com/2013_08_01_archive.html
April 26th, 2015, 06:43 PM | #11 |
I'm crazy,your excuse is?
Your dad is HULK!
Tell him I said to take it easy on the lil ol moto.! |
April 26th, 2015, 08:52 PM | #12 | |
MOTM - July '15
Thanks for the links. Especially that 2nd one. |
April 27th, 2015, 04:55 AM | #13 |
Join Date: Apr 2014 Motorcycle(s): 1980 Yamaha XS850G Midnight Special, 32k Miles; 2000 EX250F, <5000 Orig Miles Posts: 98
A wire brush on a drill is not bad, IF you don't press too hard and go too fast with too coarse a brush.
They actually make textured fabric abrasive wheels for this type of thing.. I don't see where your dad ruined the cover, maybe got a bit aggressive with it..he would have been fine if he only put light to moderate pressure on it, just enough to remove the gasket material and no more. Seal it up with black RTV and be done. |
Clutch Cover | peeweesp | Items Wanted | 3 | February 8th, 2014 07:37 AM |
Clutch cover assembly | sharky nrk | Items Wanted | 4 | September 13th, 2013 12:16 PM |
CF clutch cover | cuz | 2008 - 2012 Ninja 250R Farkles | 6 | November 15th, 2012 08:43 PM |
Clutch cover questions | NinJet | 1986 - 2007 Ninja 250R Tech Talk | 10 | May 20th, 2011 11:38 AM |
Clutch cover question | GeneJunkie | 2008 - 2012 Ninja 250R Tech Talk | 3 | May 13th, 2011 01:38 PM |
