June 26th, 2014, 08:58 PM | #1 |
Join Date: Jun 2014 Motorcycle(s): Kawasaki Ninja 250 R Posts: 1
kawasaki ninja 250r dies after pull throttle
ok I let my ninja sit for about a year and im paying for it...... I cleaned the cabs because it would not start, got a new battery. Then would die when I turned off choke. so I change spark plugs clean fuel filters and new gas. now runs with out choke but as soon as I pull the throttle dies what else can I do even used sea foam NOTHING.. PLEASE HELP
June 26th, 2014, 09:14 PM | #2 |
Jigglin' your Jiglets
MOTM - Apr '13
fight1981! Glad to have you aboard...
June 26th, 2014, 09:20 PM | #3 |
Join Date: Dec 2008 Motorcycle(s): '08 Kawasaki EX250 "Yoshi", '99 Kawasaki Concours "Grace", '06 Concours "Belle", '06 Yamaha YZF600R "Slick" Posts: A lot.
You might try a good dose of Seafoam.
< ATGATT > Sweat you can wipe off, Road rash you can't. HEY!! Unregistered!! Does your bike have a name? |
June 26th, 2014, 10:29 PM | #4 |
Join Date: Nov 2012 Motorcycle(s): 2012 Ninja 250R, 2007 Ninja 650R, 2001 F650 Dakar Posts: A lot.
Did you flush and clean the tank of the old fuel? Check the floats in the carbs? Check the air filter?
Also, welcome. Sorry you're having issues with the bike. Hopefully some of the more experienced riders and members will chime in soon. |
June 27th, 2014, 02:10 AM | #5 |
Join Date: Nov 2012 Motorcycle(s): '07 ex250-F/J Posts: A lot.
Welcome, Renee! We're glad you found us.
Like Ken said, seafoam should do the trick. Good luck! |
June 27th, 2014, 09:15 AM | #6 |
June 27th, 2014, 09:20 AM | #7 |
Welcome!
Sadly, it sounds as if your gunna have to clean the fuel/air systems. Check tank for rust Fresh gas Fuel filter check Clean carbs (uggg) Check airbox Check air filter Check snorkle On good weekend day worth of work should have ya back on the road.
June 27th, 2014, 03:28 PM | #8 | |
That Sea Foam may have not had a chance to work on the clogged jets if the bike has not rolled enough. It takes about 5 minutes to dry the bowls with the engine just idling. If you manage to make it roll for some miles with little throttle, the fresh fuel and the heat may do the trick. It is important that you avoid traffic while the bike is not OK.
June 27th, 2014, 04:12 PM | #9 |
Track Clown
MOTM - Sep '15
Welcome, try to run a full tank of gas through the bike, best way to do that is go for a 200 mile ride.
June 28th, 2014, 08:15 AM | #10 |
Hello and welcome.
bike dies when giving it throttle | RED_09 | 2008 - 2012 Ninja 250R Tech Talk | 8 | December 16th, 2012 04:51 PM |
Throttle problem? Bike bogs and dies | MikeBudd | 2008 - 2012 Ninja 250R Tech Talk | 12 | September 8th, 2011 09:02 PM |
How do I adjust the throttle push-pull cables? | wtfh4xx | 2008 - 2012 Ninja 250R Tech Talk | 1 | August 10th, 2011 05:45 AM |
2009 Ninja 250R dies after adding throttle and pulling in clutch! | meehow09 | 2008 - 2012 Ninja 250R Tech Talk | 10 | August 1st, 2011 12:21 PM |
Bike has no throttle and dies? | Chubbs032 | 2008 - 2012 Ninja 250R Tech Talk | 4 | March 31st, 2010 12:46 AM |
