February 16th, 2015, 03:59 PM | #1 |
Lowered 250
Planning on checking out a 250 today that's been lowered to accommodate the owners height. I've heard some mixed opinions about this, but am looking for the facts on the topic. Is it good/bad/safe/unsafe? Thanks guys!
February 16th, 2015, 04:12 PM | #2 |
sammich maker
MOTM - Apr '15
I took my lowered 300 to the track with no issues. I lowered my 250 when I bought it too, no problems.
https://www.brocksperformance.com/VZ...0035+C450.aspx |
February 16th, 2015, 04:21 PM | #3 |
As long as both ends are lowered the same amount, it will feel the same as stock. Just remember you can only go an inch or so before you start getting clearance issues between the wheels and body parts under suspension compression.
I, for one, would never lower a sport bike. But that's just my opinion. In fact, I raised mine! |
February 16th, 2015, 04:35 PM | #4 | |
Pretty simple... Some say one can learn to stop and only put one foot down, while this is true for most, it's not always true for all.
February 16th, 2015, 05:16 PM | #5 |
Inline 4!!!
When I talked to my dealer about lowering a bike (not my 300) he said it affects the handling and he wouldn't recommend it. However I told him that it was only be for street not so much at the track (if at all) and he said then it would be fine.
Personally, I would feel much better about my bike knowing I can flat foot it. I sat on 2 600rr's and one was lowered the other wasn't and I felt MUCH more comfortable on the lowered one.
February 16th, 2015, 05:30 PM | #6 |
That is because many just toss some lowering links and call it day. Then wonder why it turns funny.
February 16th, 2015, 05:36 PM | #7 |
^^^ werd. People are too lazy/cheap to lower the front to match the rear.
February 16th, 2015, 05:48 PM | #8 |
Join Date: Aug 2011 Motorcycle(s): 2009 Ninja 250r (Sold), 2009 FZ6, 2015 Honda Grom Posts: 898
While I understand some folks may need to lower the bikes, I don't understand the whole flat foot thing. I'v never rode a single bike where I could touch both foot to the ground let enough flat. Usually I just scoot my butt off to one side of the bike and put a single foot down. This has worked for me since I was little riding 50cc dirt bikes. At 5'5" I don't even have problems riding supermotos at stock height.... but I guess everyone is different, eh?
February 16th, 2015, 06:34 PM | #9 |
Inline 4!!!
It's really a preference thing. Being able to flatfoot gives you a sense of stability. You can just sit on your bike and use your phone or relax, etc.
February 16th, 2015, 06:42 PM | #10 | |
Join Date: Jan 2015 Motorcycle(s): 2007 Yamaha FZ1, 2006 Yamaha FJR1300A, 2014 Ninja 300 Posts: 116
There are a few advantages of being tall, I suppose. A 34" inseam is great... even them tall dirt bikes aren't a problem here.
2006 Yamaha FJR1300 And, my 2007 Yamaha FZ1. My favorite bike ever. |
February 16th, 2015, 06:51 PM | #11 |
sammich maker
MOTM - Apr '15
On the 250/300 you need riser blocks.
February 16th, 2015, 06:56 PM | #12 |
sammich maker
MOTM - Apr '15
The bike can be raised back to stock with little effort.
If the bike has the roaring toyz kit on it, it will have the links, risers and shorter kick stand.
February 16th, 2015, 07:04 PM | #13 |
Ahh.... provided you're using the stock bars. I put clip-ons and didn't take into account the stock bar configuration. As I was
February 16th, 2015, 07:32 PM | #14 |
sammich maker
MOTM - Apr '15
I never thought about using clip ons instead either...lol
February 17th, 2015, 03:14 AM | #15 |
Join Date: Dec 2013 Motorcycle(s): Ducati 999 2012 Ninja 250r Ducati748 Yellow finally running 2003 SV650 S (SOLD) Posts: A lot.
I t
lowered both ends of the 250 for my wife. We did 1" risers in the front and lowering links plus a GSXR600 shock in the rear. The links dropped the rear an inch then the shock went 15mm further. We did not have trouble with the rear tire hitting the undertail as long as the tire is over half way back on the adjusters. I changed the gearing which allowed me to push the tire back and extend the wheelbase (not out side of stock adjustment). I have only touched the exhaust down once when trying to see how far it could be leaned over in a parking lot. With the bike lowered the weight is lower and you do not need to lean as much to make the same turn. I have not tried pushing this bike as hard as is possible since it is a Street only bike for now. Obviously the bike now has reduced lean angle but so far no problems with turning/leaning on the street at sane levels. Since lowering the bike we have found that you can really get on the front brakes without the rear lifting. My wife has been much more comfortable being able to put both feet flat on the ground when she stop, she was really worried since she is not strong enough to stop the bike from falling once it gets a little too far past center. Having both feet down helps her have the leverage and confidence to keep the bike upright even on off camber hill stops. The best part is everything is easily reversed as she gets more confident in her ability and her skill with the bike rises. I will be slowly raising it back up this season so she can do her first trip to the track. |
February 17th, 2015, 05:07 PM | #16 |
ran when parked
Join Date: Aug 2013 Motorcycle(s): Freeride 250R, KLX250SF, mopeds Posts: A lot.
MOTM - Sep '17, Dec '14
sorry for repeating anything but I haven't read the other posts lol
just keep in mind that in order to lower the front suspension on a ninja 250 you usually have to mess with the internals of the fork because you cannot simply slide the forks up through the triple tree. make sure you know whether that has been done or not. some people say 'lowered' when they only lowered one half of the bike, or only the seat. stock links for the rear are super cheap and it's not terrible difficult to raise it back to stock height in the rear if you have stands and a flatjack.
Instagram: @katie.baden |
February 17th, 2015, 05:42 PM | #17 | |
February 17th, 2015, 06:08 PM | #18 | |
February 17th, 2015, 06:09 PM | #19 |
Wait, Chris.... You can't flat foot the Rsizzle?!?! I can! HahAhaha that makes it so much better. The man can't even touch the ground, yet he makes me look like a fool on the brakes.
February 17th, 2015, 06:10 PM | #20 |
ran when parked
I thought he was talking about a bike that's already been lowered. just wanted to give a heads up that if it has a stock front end bars and all, it might have cut spacers in the fork and would be more difficult to swap back to stock height if he wanted to
February 17th, 2015, 06:13 PM | #21 |
Nope, just the ball of the foot on both sides on a stock height bike. Yet it want to lower the front... not the rear.
February 17th, 2015, 06:57 PM | #22 |
wow, such pain of not being able to flatfoot and R6... and kinda funny at the same time. I had no problem flatfooting a WR450.
Don't feel bad... them Spanish punks can't flatfoot their bikes and the Honda babies can't even pickup their sub 300 pound bikes if they tip them over.
February 17th, 2015, 07:06 PM | #23 | |
February 17th, 2015, 08:15 PM | #24 | |
Join Date: Aug 2014 Motorcycle(s): 2007 250R, 2000 KLR 650 Posts: 2
February 17th, 2015, 09:16 PM | #25 |
Join Date: May 2013 Motorcycle(s): '75 CB550:.'82 XV920:.'00 KLR650:.'00 EX250:.'08 Ninja 250 Posts: A lot.
MOTM - June '15
My ninja is lowered in the front, because it's fun.
And I had clipons, then went to stock style bars, now back to woodcrafts. Either way, it's pretty easy to undo lowering. My KLR is lifted, with bigger rear tire, with a seat concepts regular seat. I can barely touch down and I love it
'82 XV920: Soon to be tracker--'00 KLR685:adv --'04 DRZ400E--'12 Super Tenere --'13 Versys Ride more, worry less. |
February 17th, 2015, 09:20 PM | #26 |
ran when parked
I'm 5'5 and this is what my toe looks like on a DRZ400.
February 17th, 2015, 09:43 PM | #27 |
MOTM - June '15
Hah, I look like that on my KLR sometimes! Good form!!
'82 XV920: Soon to be tracker--'00 KLR685:adv --'04 DRZ400E--'12 Super Tenere --'13 Versys Ride more, worry less. Last futzed with by verboten1; February 18th, 2015 at 10:04 PM. |
February 17th, 2015, 10:32 PM | #28 |
LMFAO @ finesse! Hey, who knew you could ride and ballet all at the same time! LOL
So, what i gather is it's not necessarily a negative thing as long as its done right, and if necessary, can be easily reversed? In my case I don't need it as I can reach the floor just fine. My wife on the other hand is looking to learn as well, and she is 5'3." For now I think I would follow the advice of having her learn on a non-lowered bike. In the future, when she has her own bike, we can re-assess things. Thanks so much for the insights guys! |
How can I tell if my bike has been lowered? | sidekick10121 | 1986 - 2007 Ninja 250R Tech Talk | 1 | March 16th, 2014 06:53 PM |
Q: Woodcraft Lowered Risers | iplante | 1986 - 2007 Ninja 250R Farkles | 7 | May 15th, 2013 02:04 PM |
looking for pics of lowered 08+ 250's | greatwhiteninja | Pictures | 19 | June 26th, 2011 09:34 PM |
F/S: 2009 Ninja 250 SE Low Miles Lowered - New Jersey | grn09segirl | Motorcycle-related | 5 | September 12th, 2010 09:48 AM |
anyone lowered their bike? | im_a_ninja | Pictures | 45 | December 5th, 2009 11:20 PM |
