June 4th, 2014, 09:54 AM | #1 |
Join Date: May 2012 Motorcycle(s): 2009 Ninja 250R Posts: 106
Steering stem bearings- Grease or no?
To grease or not to grease? That's the question I can't find much info about.
I bought a set of tapered All Balls steering bearings, but can't find solid info on whether or not they need to be greased, upon installation. They appear to have some sort of oil coating already. But I read on some sites that some waterproof grease is needed. Can anybody confirm they do or do not need to be greased? Thanks. |
June 4th, 2014, 10:02 AM | #2 | |
MOTM - Mar '13, Jun '14
June 4th, 2014, 10:12 AM | #3 |
I'm crazy,your excuse is?
I would think wheel bearing grease is best, but I am curious for sure. I am too lazy to go the wiki and look for you...
June 4th, 2014, 11:39 AM | #4 |
MOTM - Jan '18, Sep '13
I packed mine full of waterproof grease.
June 4th, 2014, 12:06 PM | #5 |
Yes they need to be greased with bearing grease. I just used waterproof wheel bearing grease. The oily film you see on the bearings is just to prevent the bearings from rusting in storage.
June 4th, 2014, 12:09 PM | #6 |
Thanks for the input, guys. I just got back from a local bike and ATV shop, I picked up a container of Bel-rey Waterproof Grease.
June 4th, 2014, 12:18 PM | #7 |
http://www.machinerylubrication.com/.../grease-basics
say it with me; li-thi-um grease with mo-lyb-de-num di-sul-fide added
June 4th, 2014, 12:32 PM | #8 |
li-thi-um grease with mo-lyb-de-num di-sul-fide added!!!
June 4th, 2014, 01:10 PM | #9 | |
June 4th, 2014, 01:24 PM | #10 |
June 4th, 2014, 07:08 PM | #11 | |
https://www.nlgi.org/technical-info/tech-papers/ Oil is a congregation of millions of little balls keeping those two metals rolling apart and cool and growing old. Lithium (a type of soap) gives the gel consistency to the oil and repels water, which quickly induces rust and separates oil from the metals. Molybdenum adds more little balls (1–100 µm) to the mix, for when high temperatures make the oil less lubricating.
June 4th, 2014, 08:52 PM | #12 | |
Which is why I asked. Thanks for the in-depth answer, it was very informative. |
June 10th, 2014, 07:06 PM | #13 |
Board Member
RAM on Steering Stem? | headshrink | 2008 - 2012 Ninja 250R Farkles | 15 | May 30th, 2014 06:28 PM |
[motorcyclistonline] - All Balls Steering Head Bearings | MC Tested | Ninjette Newsbot | Motorcycling News | 0 | April 18th, 2013 01:10 PM |
Play / Clunk In Steering Stem | trevor_shiggs | 2008 - 2012 Ninja 250R Tech Talk | 10 | May 18th, 2012 10:26 PM |
What kind of grease for the axle/bearings? | CZroe | General Motorcycling Discussion | 7 | April 13th, 2011 11:25 AM |
steering stem nut | snowfish | 2008 - 2012 Ninja 250R Tech Talk | 2 | April 14th, 2010 07:12 AM |
