June 17th, 2014, 02:33 PM | #1 |
Urban Legend
Join Date: Apr 2014 Motorcycle(s): 09 Ninja 250R SE - Circe Posts: 542
Do I need to replace my front tire?
Thought I post this quickly before putting on some metal and dead lift my anger into oblivion.
Since I am still learning, I leave Circe at home when I am off to work. Today when I came home, I found out that my father had taken her out and well, now there was a puncture in the front tire. Fine puncture's happen, no big deal...well...turns out that a sharp screw probably a centimetre or two had embedded itself into the front tire, which has less than 500 kms on it. Since it's too late to take her a mechanic, I thought that might as well prepare myself for tomorrow, if I have to get another front tire. So let me know if in your opinion this can be repaired or do I have to prepare myself to shell out for a new tire? |
June 17th, 2014, 02:39 PM | #3 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
Looks like a big hole. I'd replace it if were mine.
June 17th, 2014, 03:24 PM | #4 |
I'm crazy,your excuse is?
Whenever I do something questionable I regret it, even if it is 'ok', I still would be worried about it every single effin time I look a the bike.
That said, I would take it to the shop, they probably will remove and patch it from the inside. do not plug it!! |
June 17th, 2014, 03:29 PM | #5 |
Join Date: Jun 2014 Motorcycle(s): Suzuki Katana 750 Posts: 4
Yes would definitely replace it. Don't take any chances.
June 17th, 2014, 03:48 PM | #6 | |
Urban Legend
I just want to make the right decision here. I don't want to think about it later. I don't want to make one because I don't want to shell out for another tire or because of any other reason. I tool a metal wire and measured the depth of the hole, since half of the air is already out it's obvious that it penetrated. Without forcing it, the went in about .75 centimetere. So I guess I am pretty much looking at replacing it. |
June 17th, 2014, 03:59 PM | #7 |
The guide to fire and forget:
Step 1: Get out wallet Step 2: Count out $$$$ Step 3: Buy what you need Step 4: Replace busted a$$ item Step 5: Live happier, with one less thing to worry about
June 17th, 2014, 04:00 PM | #8 |
Urban Legend
June 17th, 2014, 04:07 PM | #9 |
Join Date: Nov 2012 Motorcycle(s): 2012 Ninja 250R, 2007 Ninja 650R, 2001 F650 Dakar Posts: A lot.
^I have heard of mythical creatures called "cougars." Maybe you should begin your research there.
June 17th, 2014, 04:16 PM | #11 | |
Urban Legend
"Life is like riding - You can either tear the fastlane in half or stay in the slipstream trying to play catch up." -Baron |
June 17th, 2014, 04:28 PM | #12 |
it's true. now she's a lawyer and also has her MBA. i think she mostly does probono work though. i think i heard she married a judge.
June 17th, 2014, 04:33 PM | #13 |
Urban Legend
Lawyer + Judge =
June 18th, 2014, 09:29 AM | #14 |
Urban Legend
Called one place, 205 including installation for a stock size diabolo Rosso II.
Going to call another one another quote. Quick question : Both the stores are about half an hour away, should I just fill the tire and ride it there or do I somehow temporarily fix it before filling it up and riding it there ?
June 18th, 2014, 09:32 AM | #15 |
Hmmmm....
Part of me says, take it off the bike and transport it there. The other part of me says you will be fine with a plug with a good seal. Plug or no... if it will not maintain pressure, do not ride it. It's not worth it.
June 18th, 2014, 09:34 AM | #16 |
Urban Legend
Part of the problem, no other way of taking it there.
June 18th, 2014, 09:38 AM | #17 |
Sorry brah, no friends? Normally a friend will keep me safe and give me a 30 min lift if I ask.
Not hatin' on ya, just being realistic.
June 18th, 2014, 09:46 AM | #18 | |
Urban Legend
Most of them are working when I am off. I worked night shift for the past 2 years (give or take a few months), so have most of my friends. I got promoted to supervisor and became a daywalker while they are still hanging on trees at night. xD That being said, I can travel there by bus, that's not an issue, the problem is taking the bike there with me. I can bring the tire home but I have no clue how to properly install it and I don't want to F*)k it up(epic stoppie + faceplant). xD
June 18th, 2014, 10:34 AM | #19 |
Swapping wheels in and out is about as trivial a job there is, as long as you have the right stands. Once you have those, they make just about every other maintenance job more straightforward, so they are worth investing in. With those, getting either wheel on/off is simple, and you can then make sure yourself that it is done correctly. (instructions are in the owners manual, but are duplicated in the service manual as well).
Heck, I usually take my bikes in for oil changes, and I still swap my wheels in the garage. It's just much cheaper and easier to do it that way, and stock the tires myself, rather than having to ride in with the bike to a place that may or may not have the exact tires I want in stock when I need them.
June 18th, 2014, 04:04 PM | #20 | |
Urban Legend
I would do it, I have this slight paranoia that I won't be able to balance them properly, if that makes any sense.
June 18th, 2014, 05:00 PM | #21 | |
Que Buenos Son!!!
MOTM - Nov '14
I guess I you got a tire that was really off balance then maybe it would have an effect, but I think with motorcycle tires the chance of them being way off balance is minimal. Just my experience YMMV
June 18th, 2014, 05:45 PM | #22 | |
Yes - you can do the entire process at home and not have to take the wheel or tire in at all, but then yes, you need to have the tire irons, the skills, and anything you'd need if you choose to balance the wheels as well. You don't need to have a front stand that matches your rear stand. You just need a front stand that is stable.
June 18th, 2014, 07:22 PM | #23 |
EX500 full of EX250 parts
$205 sounds expensive, though I guess if you need it right away it's worth a little extra. The DRII 110/70-17 goes for about $100 online, and the dealers around here charge $30-$40 per tire for mounting (the dealer where I bought my bike did both wheels on the bike for $88 with tires I supplied). $205 sounds like you're paying more for the tire, plus more for mounting.
If you have a jack or something you can put under the engine, you can weight the rear end to hold the back down and lift the front wheel. Or hang the front end from a ladder or rafters. Just pull the whole wheel off and take that to the shop to have them mount and balance the new tire, then bring it home and reinstall it. They should charge you less if they don't have to pull the wheel off the bike also. http://www.cyclegear.com/CycleGear/A.../p/36176_00000 is a cheap front stand. I don't think I'd trust these for constant pit use with a race bike, but the set works well in my garage for occasional maintenance. http://www.invisibill.net/ninja/frontwheel1.jpg
June 19th, 2014, 07:56 AM | #24 | ||
Urban Legend
As idiotic as it may sound there are almost no garages in my town that deal with motorcycles. I say almost because there is a dealer who deals in anything but Kawasaki's. I talked to someone there and they said that they can order and mount the tire on the rim for me, he won't put on the bike for me because "they don't service Kawi's". So that's two options I have, either drive 30 mins away after temporarily filling it up with air(don't know for how long it'll hold up) or order the front stand, place an order at the one in town, take off the front wheel when the stand does get here and then get it done. Either way, no riding her this week it seems.
June 19th, 2014, 08:37 AM | #25 |
Join Date: Apr 2013 Motorcycle(s): 2004 Ninja 250 Posts: 465
Option 2 is a much better idea
Last futzed with by quarterliter; June 19th, 2014 at 11:33 AM. |
June 19th, 2014, 04:08 PM | #26 |
Urban Legend
I'm thinking along the same lines now, I tried to fill it up with air and it didn't even stay up for 20 minutes. So I'll most probably order the front stand tomorrow, when I get it, I'll order the tire from the store and take the front wheel off. I'll take a look at plugging it but I'd rather not drive her with that tire on.
I took a look in the Service Manual, the process seems pretty straight forward, except the cotter pin part. I know I am being a bit too inquisitive but does anyone have a link to a tutorial or something?
June 19th, 2014, 10:41 PM | #27 |
Fresh Deli Meat
Join Date: Feb 2014 Motorcycle(s): 2009 250R Ninja -Neener- Posts: 678
Order the stand and while your at it, got to www.americanmototire.com and order yourself a front tire for cheaper than the BS prices you were given at the shop.
A quote from my thread on tire purchases:
We shall call thee "Seahorse." -Antiant on Couvade Syndrome |
June 20th, 2014, 04:51 AM | #28 | |
Urban Legend
A) Do they ship to Canada B) Import duties <- Either way, I'll be ordering the front stand when I get home today.
[roadracingworld.com] - Michelin To Replace Bridgestone As Official MotoGP Tire Suppl | Ninjette Newsbot | Motorcycling News | 0 | May 23rd, 2014 06:40 AM |
[roadracingworld.com] - Bridgestone: New Spec Front Tire Is Now The Standard Front Ti | Ninjette Newsbot | Motorcycling News | 0 | June 12th, 2012 10:20 AM |
Desperately need to replace front rotor... | Skippii | 1986 - 2007 Ninja 250R Tech Talk | 9 | January 10th, 2012 11:03 PM |
Should I replace this rear tire? | Soujyu | 2008 - 2012 Ninja 250R Tech Talk | 18 | December 23rd, 2011 05:48 PM |
tire upgrade question: front tire? | stryder | 2008 - 2012 Ninja 250R Tech Talk | 1 | April 5th, 2010 07:40 AM |
