February 11th, 2015, 03:25 PM | #1 |
WTB 2004 piston
February 11th, 2015, 04:18 PM | #2 |
IMHO,
Hate to tell you, but I doubt it was the spark plug fault. Looks like that cylinder was running extremely lean due to a fuel delivery issue. Seen that happen too many times back in my drag racing days, when the motor was running lean. Personally I would invest in a used or new pair, if it's in your budget, and maybe just get a whole used low mileage engine. How much experience do you have on working on motorcycle engines?
February 11th, 2015, 04:41 PM | #3 |
JBWeld.... it should hold. hahahahahahhaha good luck with you search. And yea, I would just think about another engine if the price is right.
February 11th, 2015, 07:42 PM | #4 |
I'm crazy,your excuse is?
looks like a plug did punch it, any melted ring lands or scored cylinder wall?
February 11th, 2015, 07:53 PM | #5 | |
Freedom for Germany
or better this? http://www.ebay.de/itm/OEM-CYLINDER-...item2edd11e09d |
February 11th, 2015, 09:14 PM | #6 |
I can buy a new piston for 48 bucks.
13001 13001-1325 PISTON-ENGINE,STD $47.47 $47.47 2 Cylinder looks good. I am green on working with cams and chains. Have experience holing 2 stroke pistons. I will need some help here reassembling. Bike ran great. Rings seem to be obsolete. 13008-1157 RING-SET-PISTON,STD If I reuse my rings should I still hone and crosshatch the cylinder. I was thinking I read that after intial breakin of rings the outer moly wears to the crosshatching but once that is gone the rings do not seat further? I was hoping to buy a couple good pistons for 30 to 40 dollars for both. |
WTB: Crankshaft & Connecting Rods - 2004 | kirkn | Items Wanted | 0 | April 23rd, 2012 01:10 PM |
WTB Carburetor for 2004 ninja! | Obje0110 | Items Wanted | 2 | March 20th, 2012 07:59 PM |
WTB: 2004 carburetor ninja ex250! | Obje0110 | Items Wanted | 9 | December 15th, 2011 03:56 PM |
WTB: 2004-2007 Ninja 250R Engine | NinjaGirlATL | Items Wanted | 3 | November 7th, 2011 08:49 PM |
