Old April 2nd, 2014, 06:34 PM   #1
Amsler457
Amsler457's Avatar
Motorcycle(s): Ninja 250r. Suzuki Ts 185
Speed! Help
Need more low end torque and acceleration. What are some affordable upgrades / mods i can do. Even the smallest ideas are greatly appreciated!! Thanks all
Amsler457 is offline   Reply With Quote
Old April 2nd, 2014, 06:39 PM   #2
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
turbo busa.
TEAM ALFALFA
www.apexassassins.com
Old April 2nd, 2014, 06:42 PM   #3
Amsler457
Amsler457's Avatar
Turbo busa?
Old April 2nd, 2014, 06:53 PM   #4
Old April 2nd, 2014, 07:17 PM   #5
DaBlue1
DaBlue1's Avatar
Old April 2nd, 2014, 07:22 PM   #6
Amsler457
Amsler457's Avatar
Da blue that's real cool. How's it work?
Old April 2nd, 2014, 07:25 PM   #7
mrb
Motorcycle(s): 08 ninja 250r
stickers will help too.
mrb is offline   Reply With Quote
Old April 2nd, 2014, 07:40 PM   #8
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
It gives you a boost every time you shift, just like in fast & furious. that's why they're always shifting even into 10th and 11th gear.
Old April 2nd, 2014, 08:06 PM   #9
/moved to new-gen tech
(not about ninjettes at the track)
Old April 2nd, 2014, 08:32 PM   #10
jcgss77
Its not a 250,its a Ninja
jcgss77's Avatar
Motorcycle(s): '11 CBR250R, '22 CFMOTO 300NK
Originally Posted by DaBlue1 View Post
Love how that bike has NOs and yet still has the stock dunlop tires...bald...
Your bike is already black, there is no way to make it faster...
unless you wreck it, then you get to buy an r6. Best torque mod you can do to the screaming scooter!
Last futzed with by jcgss77; April 2nd, 2014 at 08:33 PM. Reason: yup
jcgss77 is offline   Reply With Quote
Old April 2nd, 2014, 08:36 PM   #11
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Smaller front sprocket. Bigger rear sprocket. Cheap!
Old April 2nd, 2014, 09:20 PM   #12
Kscreations08
Fresh Deli Meat
Kscreations08's Avatar
Motorcycle(s): 2009 250R Ninja -Neener-
Sprocket swap, while it seems to be the only legitimate answer in this thread of trolls , is a compromise. What you gain in initial pickup, you lose in top end speed. Then again, do you need to do 100 mph?
We shall call thee "Seahorse." -Antiant on Couvade Syndrome
Kscreations08 is offline   Reply With Quote
Old April 2nd, 2014, 09:37 PM   #13
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
i dont know, with a 250 asking how to get more power is like asking how to make a Miata less gay.
TEAM ALFALFA
1 out of 3 members found this post helpful.
Old April 2nd, 2014, 09:49 PM   #14
ChaoSS
Motorcycle(s): 2012 red 250 ninja
Keep in mind that you are also going to increase your freeway rpms. Not a good thing if you do any real amount of highway riding.
ChaoSS is offline   Reply With Quote
Old April 2nd, 2014, 09:51 PM   #15
Kscreations08
Fresh Deli Meat
or asking how to get better gas mileage with a Hummer
Old April 2nd, 2014, 09:55 PM   #16
jcgss77
jcgss77's Avatar
This.
OP-Ok, if you haven't been reading and researching, which if you are asking this question, you probably aren't, then here you go-Whenever you "add" performance, you have to rob something else, that way there is balance. You do the sprocket swap, and get tons (comparatively speaking) of torque.
What you give up: any use of 1st gear you had, and lower top speed, as your bike will be running at higher rpms to achieve the extra torque, and gas mileage. If this is no concern to you, then by all means, go for it. Be sure that if you replace the sprockets, do the chain as well.
To shoot straight, you will not get much more performance out of your bike. But honestly, 0-60 is achieved faster than probably 80-90% of the other cars out there. If you can't keep up with a stock ninja, you really need to learn how to ride it. I don't know your experience, but let me ask you this-do you modify your car to squeeze out all the torque you can get out of it? What I am saying is simply put, yes, you can spend thousands in getting your ninjette up to 40 hp, or you can simply save yourself the work and frustration as it probably won't run the way you envision it, and buy a bigger bike. I would not recommend this though if you are a beginner rider.
Word of advice: You do know what stickies are, right? Use them. They are there for a reason. I linked a site to you in your turn signal thread, read it and get knowledgeable. Then, ask any questions you will have, you will find the answers to be much more agreeable. Use the search function too, there is a lot of information on this website, as well as the wiki. And, welcome to ninjette.org!
Last futzed with by jcgss77; April 2nd, 2014 at 10:03 PM. Reason: old-just remembered something
Old April 2nd, 2014, 10:09 PM   #17
jcgss77
jcgss77's Avatar
I lol'd
Old April 2nd, 2014, 10:18 PM   #18
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
This is the law of equivalent exchange, there's no way around this unless you have a philosophers stone.
AFM #676
Supersports are for n00bs
Old April 2nd, 2014, 10:18 PM   #19
ChaoSS
Easy. Get it from a skinny chick that doesn't add too much weight to the vehicle. Or were you talking about a different type of hummer?
Old April 2nd, 2014, 10:58 PM   #20
psych0hans
psych0hans's Avatar
You could add a full exhaust + jetting - airbox + k&n 0990 filter... That should get you started in the right direction. Doing all this will cost you a lot of $$$ and the results will be far from drastic... Just keep that in mind...
Old April 2nd, 2014, 11:27 PM   #21
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
either someone has a miata, or they have no sense of humor.
TEAM ALFALFA
Old April 2nd, 2014, 11:54 PM   #22
Kscreations08
Fresh Deli Meat
Dont worry Binkie. The powers that be are working on making the voting public.... well.... public =)
0 out of 1 members found this post helpful.
Old April 3rd, 2014, 12:02 AM   #23
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
miata = car equivalent of the ninjette
handles well, does everything you want and need it to within reason, is fun to drive, gets great mileage, but you always want that little bit more power hahaha.
Old April 3rd, 2014, 01:44 AM   #24
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
TEAM ALFALFA
Old April 3rd, 2014, 05:39 AM   #25
DaBlue1
DaBlue1's Avatar
This particular NOS(drink) bottle works by opening the cap and drinking the highly caffeinated, lightly gaseous liquid inside. Once ingested, the liquid will help to increase your clutch/throttle performance. Extra twisting of the throttle combined with some modest modifications to the engine may produce 1-3 extra ftlbs of actual useable torque (actual results may vary).
BTW, WELCOME!
Last futzed with by DaBlue1; April 3rd, 2014 at 06:44 AM.
Old April 3rd, 2014, 06:28 AM   #26
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
This particular NOS(drink) bottle works by opening the cap and drinking the highly caffeinated, lightly gaseous liquid inside. Once ingested, the liquid will help the increase your clutch/throttle performance. Extra twisting of the throttle combined with some modest modifications to the engine may produce 1-3 extra ftlbs of actual useable torque (actual results may vary).
BTW, WELCOME!
I was thinking afterburners.
Old April 3rd, 2014, 06:57 AM   #27
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
FULL exhaust/jet/filter/kleen air delete/snorkel delete will give you gains that are truly noticeable if not huge in an absolute sense. The stock bike only puts out about 25 hp to the rear wheel. Get that up to 29 hp (easy to do) and you've got a big jump percentage-wise.
Cost: figure about $700 all up. Less if you can find a used exhaust.
You can also rev higher and get the bike up into the power band. That's free.
Old April 3rd, 2014, 12:14 PM   #28
iZapp
former ninja 250'er
iZapp's Avatar
Motorcycle(s): Aprilia 1000R, CRF450, CBR600RR tracktoy, Ninja 250 -- GONE!!!!!
Lol I love the irony of someone who rides the slowest sportbike on the planet making fun of miatas. You do realize of course that the corollary is that the ninja 250 is considered the miata of the biking world? (Haha yes I own a miata)
iZapp is offline   Reply With Quote
Old April 3rd, 2014, 12:42 PM   #29
Jiggles
Jiggles's Avatar
MOTM - Apr '13
I down voted you
AFM #676
Old April 3rd, 2014, 12:42 PM   #30
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Damn they are making it public
AFM #676
Old April 3rd, 2014, 12:44 PM   #31
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
@iZapp whats speed and riding a slow bike got to do with it? Don't think cbinker said anything about Miata's not being really fun, just that they can not be made less gay.
Think of it this way, getting **** faced, stripping down to your underwear and getting all oiled up and wrestling your closest guy friends in a royal rumble fashion would most likely be pretty fun.....gay as hell though.
Old April 3rd, 2014, 12:57 PM   #32
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
^ speaks form experience?
If you are fat may want to lose weight, else get a bigger bike.
My Cafe Racer Build
My intro post
Old April 3rd, 2014, 01:01 PM   #33
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
^ don't knock it till you try it
and FYI I won that ****, championship belt holder 2 yrs running
Old April 3rd, 2014, 03:20 PM   #34
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
the 250 isnt my only bike. and yes i already knew all that.
TEAM ALFALFA
[motorcycle.com] - 2013 AIMExpo: Speed and Strength Speed Strong Jacket Video Ninjette Newsbot Motorcycling News 0 October 18th, 2013 04:01 AM
[topix.net] - A Sexy Six-Speed | Rivera Primo Powerdrive 6-Speed Transmission Install Ninjette Newsbot Motorcycling News 0 August 9th, 2010 03:20 PM
