Old March 14th, 2016, 02:34 PM   #1
UFOmoplata
UFOmoplata's Avatar
Motorcycle(s): 2007 Hoodrat 250
Question Fuel leaking from pod filter
Engine cranks, lights work, everything seems to be in order except: no start.
It could be spark plugs. It could just need starting fluid.
Either way, I came home to a smell of gas and a smallish puddle of gas underneath the bike. The gas was tinted red from the k&n buttjuice. The bottom of the pod filter is wet from gas.
Did I achieved flood?
"Brah, you can't be looking like that on a 250, brah. You gotta mod a 250, brah. It's like the hachi-roku of bikes."
UFOmoplata is offline   Reply With Quote
Old March 14th, 2016, 02:41 PM   #2
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
1. Your petcock is leaking
2. Float valve isn't sealing in one or both carbs
Time to rebuild both of the above items so they work properly.
Check your oil, it will probably smell like gas and be "overfilled" from the gas running into the combustion chamber and then past the rings. If so, it will need an oil change also.
Goin' fast on slow bikes!
Old March 14th, 2016, 02:55 PM   #3
UFOmoplata
UFOmoplata's Avatar
Ah makes sense because I removed the stock fuel filter over the weekend.
Will need to see about the carb rebuild set.
Thank you sir.
Old March 14th, 2016, 05:23 PM   #4
UFOmoplata
UFOmoplata's Avatar
Got home. Turned key, no start. Doesn't even crank over now. I'm assuming flood?
Old March 14th, 2016, 05:36 PM   #5
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Possibly fuel locked. Time to plug the spark plugs and have a look.
Might be dead battery. Check it with a voltmeter.
Personally, I wouldn't try and start it until the float valve/petcock issue is resolved and the crankcase checked for fuel.
Old March 14th, 2016, 05:40 PM   #6
EDIT: Racin' beat me to it...
Because you have been leaking fuel into the carb, it may have worked its way into the cylinder and is "hydo-locking" the engine.
As noted - check your oil level to see if it has gotten past the rings and into the crankcase.
The safest next step, because you said it will not turn over, is to remove the spark plugs and crank the engine over. That will shoot out any gas that happens to be sitting in the cylinders - so stand back.
I would also check the battery voltage. If it's way down (below 12.3V or so), or even if it's not, it may drop off to nothing when under load (hitting the button).
Unless you have confirmed there is no raw fuel sitting in the cylinder I wouldn't try to start it. You can do damage if you were to force it to turn over, like trying to bump start it or possibly even jumping with a large/strong battery.
Old March 14th, 2016, 05:41 PM   #7
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
Dead battery
My Cafe Racer Build
My intro post
Old March 14th, 2016, 06:12 PM   #8
UFOmoplata
UFOmoplata's Avatar
Everyone thx for suggestions.
I will try the below method to clear the gas from cylinders.
Side note: spoke too soon, it does crank over now. Just won't start. This will give me reason to replace the plugs. NGK or Denso?
Old March 14th, 2016, 06:18 PM   #9
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
NGK.
Old March 14th, 2016, 07:04 PM   #10
Ghostt
Ghostt's Avatar
You need to deal with the petcock, replace it, and your float needle valves, otherwise it will happen again, and possibly damage the motor.
https://www.ninjette.org/forums/showthread.php?t=215441
violente et ignorantia
ZX-2R BLOG
Old March 14th, 2016, 08:00 PM   #11
Probably flooded the engine, and maybe run the battery down as well. If it does crank strongly, make sure the choke is all the way off, then open the throttle all the way while cranking. That will help to clear the cylinders and fire.
As others have noted - charge the battery (it should hold 12.7V or more after sitting overnight) and buy NGK plugs.
Gas dripping past the petcock can do all sorts of damage, so definitely get that resolved as soon as possible. Changing the oil is a good idea (after resolving the problem) if there's any indication of gas getting into the oil.
Old March 15th, 2016, 09:33 AM   #12
UFOmoplata
UFOmoplata's Avatar
Stupid questions:
The petcock actually felt dry. The majority of the spill looked like it came from the air filter. Did the petcock leak fuel INTO the carbs?
Also, I hooked up a vacuum from the petcock (the nipple next to the fuel line) to the carb (inlet close to the choke). Do you think that might have something to do with it?
Old March 15th, 2016, 09:41 AM   #13
HoneyBadgerRy
HoneyBadgerRy's Avatar
Take the carbs apart, and check that the float level is set properly. While the carbs are apart give them a good cleaning.
You either have a bad battery, starter, blown fuse, or hydrolocked the engine. Try turning the engine over with both plugs out, if it does turn over, try to blow as much gas out as you can. If it doesn't turn over, try to turn the engine over with a ratchet and socket on the flywheel.
Old March 15th, 2016, 09:42 AM   #14
Ghostt
Ghostt's Avatar
The petcock is vacuum type, so if the engine is off, no vacuum, then the petcock shouldn't allow fuel thru, in other words you need to replace it.
Also if the petcock is leaking the float needles shouldn't allow any more fuel to pass once the fuel bowls are full, either your float valves are dirty, and/or needs to be replaced, they are consumable parts, they don't last forever.
Personally replace the petcock, and float needle valves, and set the float height to proper height.
It's not cost effective to rebuild the peacock, here's my write-up on the subject.
If your petcock is shot, save your time, and money and get a new one, the cost of rebuilding it isn't much cheaper, due to you need two separate kits, as they for some reason don't make just one.
New one cost about $65.00
1988~00 models
http://www.partzilla.com/parts/detai...1023-1139.html
2001~07 models
http://www.partzilla.com/parts/detai...1023-1393.html
Also be sure to order the orings(92022-183 WASHER,6.2X11X1.5)and new bolts(92001-1091BOLT,6X20),trust me you'll be better off in the long run.
Rebuilding kits are about $60 total.
K&L Supply Diaphragm Only for Fuel Petcock Repair Kit 18-6638 https://www.amazon.com/dp/B0055DWO60..._s1CGub1W9N3PH
K&L Supply Fuel Petcock Repair Kit 18-2723 https://www.amazon.com/dp/B001KO2JRW..._U1CGub05DT5NT
http://faq.ninja250.org/wiki/Rebuild...tcock/fuel_tap
IMHO not worth it rebuilding, also be sure to check vacuum and fuel lines for wear, holes, and cracks, if in doubt replace them. Also replace the two small O-rings on the bolts for the petcock part# 92022.
This is the time to add an inline filter filter, if you don't have one already.
K&N 81-0221 Fuel Filter https://www.amazon.com/dp/B000E2AR70..._ncMwwbE333H0E
ZX-2R BLOG
Old March 19th, 2016, 11:13 AM   #15
UFOmoplata
UFOmoplata's Avatar
Would any of this be affected if the vacuum hose were incorrect? I noticed the vacuum line at the petcock was not connected to the right hose.
Old March 19th, 2016, 01:30 PM   #16
ducatiman
ducatiman's Avatar
the unchecked fuel flow within the carbs is specifically overspilling via the main mixing chamber...flowing both:
forward to the intake tract , chamber and crankcase
backwards, simultaneously spilling via the overfilled air correction jet ports.... thus why fuel is exiting the pods as well.
Yup, OP has some work to do.
To answer your above question...an operational petcock should block the flow of fuel with engine at rest.
Think liquid filled straw with thumb over the end of straw....your thumb is the petcock.
Old March 21st, 2016, 06:07 AM   #17
UFOmoplata
UFOmoplata's Avatar
Well, bike is apart for now. Will order new petcock soon.
@ducatiman, I have to hit you up for a carb rebuild soon. I also have some main jets to send with it.
Old March 21st, 2016, 01:40 PM   #18
ducatiman
ducatiman's Avatar
^ I'm at your service, UFO.
Pod or replacement filter vmax 2008 - 2012 Ninja 250R Tech Talk 4 August 4th, 2014 09:30 PM
K&N Pod filter mwirrick Ninjettes At Speed 13 January 10th, 2014 05:57 PM
My pod filter got wet subxero 2008 - 2012 Ninja 250R Tech Talk 53 June 16th, 2013 07:55 AM
K&N Filter or Pod jonthechron 2008 - 2012 Ninja 250R Tech Talk 6 February 17th, 2010 12:07 PM
Which pod filter do you use? null0 1986 - 2007 Ninja 250R Tech Talk 13 December 1st, 2009 12:36 PM
