October 20th, 2013, 02:59 AM | #1 |
Wannabe Reborn
Kleen Air System - Breather Filter
So I'm in the midst of putting bike back together after removing the air box and swapping out some jets. I came across the Kleen Air system, and was going to remove, but when I saw a few threads on here, it looks like there may be a certain combination of mods that will allow the bike to run well with out it. Not sure if I need to go that far, so I thought I would just throw a breather on the end of hose where it used to connect to the air box.
Has anyone done this before? No major affects? What size breather? Thanks~
October 20th, 2013, 04:20 AM | #2 |
Just remove the system all together and put a plug at the hole in the airbox. You can buy a block off plate or make your own, or be cheap and shove a bolt into the tube and clamp it.
http://www.ninjette.org/forums/showthread.php?t=9948
October 20th, 2013, 06:09 AM | #3 |
Fix It Till Ya Break It
Join Date: Oct 2011 Motorcycle(s): 08 250RRrrrr Posts: 623
I have a breather on mine and modified the valve abit, so now on decel it backfires little blue flames. Some like, some don't. Do what pleases you.
October 20th, 2013, 07:51 AM | #4 |
Wannabe Reborn
Already have air box removed, so plugging off that hole isn't an option...I'm just wondering if there is any performance/runability advantage to having it/not having it. Reading the previous issues some had with, which were most likely caused by modding, then jetting, then removing Kleen system, then having to retune carbs, I wasnt sure if someone had found a tried and true setup.
I'm doing all this work (airbox removal/pods/jetting) in cold Ohio, so I won't really have the best environment to run it before spring. Think I'm going to throw a breather on it for now until next year, see how it runs, and then remove later after fine tuning the carbs. Thanks~
For Sale: Kleen Air System | Jiggles | Motorcycle-related | 23 | February 10th, 2014 07:07 AM |
Removing the Kleen Air System on a stock bike | oblivion007 | 2008 - 2012 Ninja 250R Tech Talk | 3 | January 25th, 2014 04:28 PM |
Who's taken off their Kleen Air System? | walty87 | 2008 - 2012 Ninja 250R Tech Talk | 10 | January 29th, 2012 10:37 AM |
Kleen air system removal on CA model ninja | drumm3r9 | 2008 - 2012 Ninja 250R Tech Talk | 2 | August 10th, 2010 08:36 AM |
Kleen Air system | mxnello | 2008 - 2012 Ninja 250R Tech Talk | 6 | April 13th, 2009 01:32 PM |
