March 30th, 2015, 09:34 AM | #1 |
I'm crazy,your excuse is?
Brakes what would you do?
Brakes are 23 years old everything works, I am replacing the lines, they are not leaking.
Now do I take good working calipers apart and rebuild or leave good working factory seals out and put fresh ones in? I can argue that leave good one alone or put fresh parts in and risk fubaring it... I only dealt with one bad caliper on all the cars I have owned and it was leaking. What do you do? |
March 30th, 2015, 10:11 AM | #2 | |
Calipers should be disassembled and clean, and inspected ever brake pad change.
With that said, I would do that, and replace all seals, dust caps, etc.... Consumables. Also inspect the rotors themselves, thickness, warping, etc.... Here's my write-up on calipers Quote:
March 30th, 2015, 10:14 AM | #3 |
Normally, I am a fan of "if it aint broke don't fix it", but 23yrs aye? It's past time for "preventative" maintenance.
March 30th, 2015, 10:22 AM | #4 |
Especially brakes on a motorcycle
March 30th, 2015, 10:32 AM | #5 |
Agree'd, thing is... I aint sure he is working on his 250, as his profile shows a 07. So it begs the question... 23ys? I know I am from KY but dat math don't add up or he is work on somethin' else.
March 30th, 2015, 10:35 AM | #6 | |
But regardless what their on, it's time for either service, and replace them.
March 30th, 2015, 11:03 AM | #7 |
I swapped 1992 zx600r forks and swinger into my ninjette -along with the brake parts. I am not worried as they look fine and the fluid looks old but I have seen way worse. I am running new lines though.
@Ghostt- for reference- how many times have you rebuilt your ex500 calipers and master? Did they leak? I am curious as its about the same age. In a car I would simple buy a rebuilt for $20-50 per unit, but seems like on motos not an option. |
March 30th, 2015, 11:27 AM | #8 | |
As I've outlined in my guide, inspect everything, if there's any doubt, replace it. You're already replacing the lines, the caliper service is needed and overdue, along with the consumables. The parts needed are a lot cheaper than the lines were.
Need new brakes! | corksil | 2008 - 2012 Ninja 250R Tech Talk | 18 | September 28th, 2014 11:36 PM |
Brakes | momoru | 1986 - 2007 Ninja 250R Tech Talk | 7 | August 10th, 2014 07:26 AM |
Better brakes?? | LittleRedNinjette | 2013 - 2017 Ninja 300 Tech Talk | 39 | July 11th, 2014 08:42 AM |
Brakes | marc_previtera | 1986 - 2007 Ninja 250R Tech Talk | 5 | October 3rd, 2013 05:22 AM |
Brakes | Jesse8931 | 1986 - 2007 Ninja 250R Tech Talk | 7 | April 11th, 2011 06:17 PM |
