February 18th, 2015, 10:36 PM | #1 |
Lost brake pressure in the rear!!
I hadn't ridden my bike in six days.
It started up fine. The first day back I rode around for about 90 minutes in 85 degree temp. and I lost brake pressure in my foot completely. I pulled over and waited like 5 minutes and I got pressure back, but the pedal feels mushy and not as affective. A few hours later, the brake feels fine again. I just replaced my caliber because something similar to this happened when I first bought the bike. Should I replace the brake lines? The brake is like at 17,000 miles or a little bit more now. This hasn't happened since the first time. Could it be because I was riding the brakes a bit? I have a tendency to do that because my last bike had drum rear brakes. Thanks. |
February 18th, 2015, 10:46 PM | #2 | |
Now the caliper seals melting... that is one you might want to look closer into. If this is a habit that you have, you might also want to look into the type of brake fluid you use and select one with a higher temp rating. Organic pads are also gunna be more prone to doing this. Bottom line... ya need to stop riding the brakes.
February 18th, 2015, 11:07 PM | #3 | |
Sounds like you favor the rear brake too much, compared to the front?
If this is the case, you need to adjust your braking habits, and style, for your personal safety. One must remember that the front brake is the primary stopping force, especially in a panic stop it's almost 100%. Here is my write-up on the braking system, including diagnostic, repairs, recommendations etc.... Hope it helps. Quote:
violente et ignorantia ZX-2R BLOG Twitter and Instagram = Ghostt_Scott I'm not here to change your mind, just to inform. Last futzed with by Ghostt; February 18th, 2015 at 11:15 PM. Reason: typos |
February 18th, 2015, 11:32 PM | #4 |
so my symptoms seem normal? The fact that it goes back to normal after the brakes don't over heat means that I'm riding it? Could it be any other problems? It seems like one moment the pedal worked fine, then another moment later it sank all the way down.
Do all rear brakes have that problem if you use them too much? would replacing the brake lines with steel brake lines help? I already have a galfer set here, but I haven't replaced them yet because someone mentioned that they would provide too much stopping power. yes, i really need to readjust how I brake, but I live in Vietnam and most of the time I cruise like 30 to 40 miles at best, so I get lazy and use the rear brakes. |
February 18th, 2015, 11:56 PM | #5 | |
Do all brakes have this problem? Yep, they sure do and yea... even cars and trucks. Ask a race car driver at Talladega (they glow red) or an over the road trucker with 7 miles of downhill in front of them if brake temp is important with 60,000lbs in tow (ask yourself why they engine brake). Would replacing with a steel line help? Nope, in fact... it just might make the problem worse by allowing you (the rider) to transfer more brake pressure with less effort. Do steel lines create too much braking power? Not at all, the braking force that is applied is 100% in the riders control. For better.... for worse.
February 19th, 2015, 08:29 AM | #6 |
I'm crazy,your excuse is?
I would rebuild or replace that rear master cylinder. At very least remove boot and inspect, do a full brake fluid flush and bleed .
Last futzed with by crazymadbastard; February 19th, 2015 at 09:32 AM. Reason: typo |
February 19th, 2015, 09:05 AM | #7 |
old brake fluid saps up water which overheats and boils much much quicker than the oil itself. its also spongey when its not boiling.
February 19th, 2015, 10:36 AM | #8 |
Brake fluid surrounded by high air humidity goes bad really quickly, especially if the seal of the master cylinder leaks humid air in. Dragging the brake generates enough heat to form compressible bubbles of steam where only non-compressible liquid should be. Those bubbles keep putting more pressure than the one your foot applies on the pads, which generates more heat to create more internal steam. The mass of brake fluid is so small that a stop of a few minutes cools all steam down, which condenses and becomes water mixed with the brake fluid again: no internal steam or air = firm feeling. Don't change the lines, but check that air seal in the master cylinder's reservoir, replace your fluid frequently (around six months) and un-learn dragging the brakes.
February 20th, 2015, 12:10 AM | #9 |
thank you guys for the response.
The caliper is brand new. My old one failed, I still used the old brake lines though. It worked fine until yesterday. if it cools down and works again perfectly, then it's safe to say that it was me dragging on the brakes and nothing wrong with the bike? |
February 20th, 2015, 12:12 AM | #10 |
The caliper is brand new. My old one failed, I still used the old brake lines though. It worked fine until yesterday. if it cools down and works again perfectly, then it's safe to say that it was me dragging on the brakes and nothing wrong with the bike? why is the rear more likely to lose pressure than the front? Would riding the front brakes cause it to completely lose pressure too? I feel like when I am riding a long time, my front brakes will go in more and require me to pull in deeply slightly. but after it cools down, the lever pressure is hard again. but remember, i brake more than I throttle because of the traffic in Vietnam. |
February 20th, 2015, 12:34 AM | #11 | |
Getting any brake setup (fluid and/or hard bits) too hot will lead to a loss of braking effectiveness, it don't matter if it's front or back. The rear is more prone to temp issues due to the smaller size of the rotor and it getting less airflow due its location. The front is less prone to temp issues due to it's larger size, getting more airflow and better temperature dissipation ability in relation to it's size. Thing is, many riders feel their brakes are pretty firm and good until they feel someone's that is near "perfect".
February 20th, 2015, 12:52 AM | #12 | |
Did you flush and fill the entire rear brake system with brand new sealed DOT brake fluid? If so what kind, and type DOT#? I've never had any brake lose pressure not without a leak somewhere, in one case it was a very very old brake hose, it was swelling when I applied the brake, but I knew it was bad, just from looking at it, dry rotted. I've had fade, and glazed some in my days. Why are you even riding any brake in the first place? Have you attend an MSF course??? Did you read my caliper service write up? What is the condition of the rotor? Did you check it per the guide I provided? Condition of the pads, used? contaminated? Brand? Type? Etc...... Have you done any physical diagnostics??????? RDI????????
Who's lost the rear? (exit throttle) | tuscani451 | Ninjettes At Speed | 7 | September 9th, 2014 06:38 AM |
Rear Brake Lever Travel is Excessive and Rear Brake won't Lock Tire. | N-m | 1986 - 2007 Ninja 250R Tech Talk | 14 | July 17th, 2014 04:13 AM |
Lost the rear | alex.s | !%@*#$%!)@#&!%@ I crashed! | 74 | March 4th, 2013 12:46 AM |
Someone dropped my bike. lost starter, rear signal. | arnoldc6 | 2008 - 2012 Ninja 250R Tech Talk | 7 | October 7th, 2012 07:51 PM |
Rear brake pressure | Rawr | 2008 - 2012 Ninja 250R Tech Talk | 9 | April 26th, 2009 06:42 PM |
