Go Back   ninjette.org > Marketplace > Motorcycle-related
Old May 1st, 2014, 08:20 AM   #1
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
How much would you pay?
for a 2002 pregen with 10,000 miles, that was lowsided on its right side. damage to fairing and handlebar. no pictures sorry...
versus a
2007 250 with 2,000 miles, no damage?
Old May 1st, 2014, 08:37 AM   #2
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
1 500
2 1500
My Cafe Racer Build
My intro post
Old May 1st, 2014, 09:34 AM   #3
Joshua763
Motorcycle(s): five honda's one harley one ninja most have sold all where fun.(one honda was a moped)
sounds close to me......
Joshua763 is offline   Reply With Quote
Old May 1st, 2014, 09:36 AM   #4
lgk
500
1300
Old May 1st, 2014, 09:41 AM   #5
psych0hans
psych0hans's Avatar
3) buy a new gen
Old May 1st, 2014, 09:42 AM   #6
Joshua763
I have owned a lot of bikes and my pre gen is fun too.
Old May 1st, 2014, 09:49 AM   #7
Joshua763
Hans whats a good price on a 300 with low miles?
Old May 1st, 2014, 10:00 AM   #8
crazymadbastard
$500
My Cafe Racer Build
My intro post
Old May 1st, 2014, 11:40 AM   #9
mr2peak
Motorcycle(s): Hyper 821
Seeing as pregen motors go for ~$350-$450 by themselves, $500 for a full bike is a steal. Does it hold a salvage title?
mr2peak is offline   Reply With Quote
Old May 1st, 2014, 12:21 PM   #10
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
I don't have 2k to drop on a new generation.
Old May 1st, 2014, 12:27 PM   #11
mr2peak
Well then, make sure you budget for a full fluid and filter change at the very least. Pay attention to tire wear, and brake pad life. See how worn the rear rotor is, that's an expensive replacement part ($230+ from the dealer).
All this stuff adds up quick, that cheap bike might not be so cheap.
Old May 1st, 2014, 01:35 PM   #12
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
the 07 is the better buy for sure, the 02 is better if you don't have cash though. The 02 I'd talk down and probably pay around $600 in the end, the 07 I would talk down because it's probably been sitting a bit and pay around $12-1400 in the end.
<3 pregens, they're so easy to do maintenance on and the only thing you really need to do to them is swap the wheels to get better tires, even then the pirelli scooter tires are pretty good and the bridgestones fit the stock wheels as well
Old May 1st, 2014, 04:58 PM   #13
if the 2002 has new oil in it- don't bother. nobody would put fresh oil in that thing unless they were trying to hide blown bearings. if it's got used oil, take some oil out and check it out. if it looks like oil and not sparkley colorful rainbows, put it back and then check the coolant. if its still green, and it doesn't sound like complete **** once it warms up, buy it.
price? add it up:
working pregen 02 motor, $250
registered frame with light damage, $150
undamaged gas tank: $100
undamaged cooling system, $50
if its tires are less than 2 years old and have good tread, +$100
if a part is broken, you aren't paying for it. that means fairings and controls are "worthless" to you in your buy price since you will "have to replace them"
from what it sounds like, the 02 is probably around 500-600.
if it's not registered, don't buy it.
Old May 2nd, 2014, 01:00 AM   #14
Singh2jz
Singh2jz's Avatar
Motorcycle(s): '07 ex250-F/J
if the 2002 has new oil in it- don't bother. nobody would put fresh oil in that thing unless they were trying to hide blown bearings. if it's got used oil, take some oil out and check it out. if it looks like oil and not sparkley colorful rainbows, put it back and then check the coolant. if its still green, and it doesn't sound like complete **** once it warms up, buy it......................
I found this post very helpful.
The Bike | The Truck
Old May 2nd, 2014, 08:22 AM   #15
b.miller123
b.miller123's Avatar
Motorcycle(s): 1998 Ninja 250 2007 Yamaha R6 2003 Honda RC51... sold :(
price? add it up:
Except if they were doing an oil change. Still worth looking at the oil, but just having new oil doesn't mean bad bearings. I change the oil at least once a year (usually in the spring), even if I haven't put many miles on it.
b.miller123 is offline   Reply With Quote
Old May 2nd, 2014, 08:27 AM   #16
if it has 0 miles on the oil. don't bother with it. because you can't tell anything about the engine.
Old May 4th, 2014, 02:09 PM   #17
js380
js380's Avatar
Motorcycle(s): 2012 Kawasaki Ninja 250R
I would most definitely look on here and ebay for parts prices for the 2002 before considering it as even a option. Just as said above parts prices could make that cheap bike very expensive after it is repaired.
js380 is offline   Reply With Quote
Old May 5th, 2014, 08:36 AM   #18
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
also looking at some gs500's
Old May 6th, 2014, 06:14 AM   #19
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
how about this...don't know much about Suzuki's or rebuilt titles.
I'm selling my 2002 Suzuki bandit 1200S. its the half faired version (S). it has 11405 miles on it. not stock. new Michelin pilot sport 2 tires, current inspection. has a couple little scuffs, no cracks etc. Doesn't leak anything. Fun bike with a good amount of potential in the motor. The motor is a punched out version of the old GSXR 1100 (1157cc vs 1127cc) motor with mild cams for low end and mid range punch and a restricted exhaust. They respond very well to intake/exhaust modifications.
- mesh saddle bags,
- full holeshot exhaust($899) stepped header, free flowing mid pipe and Holeshot muffler
- flush mount led front markers
- clear led tail light with integrated turn signals
- cover
- two half helmet covers
- gsxr 750 intake cam (not installed)
- black pc'd drag bars.
- 5300k hid low beam
- pyramid plastic tire hugger
- cf belly pan
- holeshot stage one jets
- holeshot timing advancer
-k&n oil and air filter
- holeshot PAIR blockoff plates
- silver reflective rim
-includes holeshot round headlight bracket
**** its prices low bc it does have a rebuilt title*****.
Open to trades on other bikes, no snowmobiles or boats, no Honda shadows or the like. I like sport or sport touring bikes
What you pay for... adouglas Motorcycle Gear 6 October 28th, 2013 09:22 PM
How Much Would You Pay? Used Ninja General Motorcycling Discussion 40 August 16th, 2013 07:46 AM
How much would you pay?? dwright0723 General Motorcycling Discussion 28 June 9th, 2013 09:27 AM
how much should i pay? Rj. General Motorcycling Discussion 22 June 16th, 2010 04:49 PM
