Old April 25th, 2016, 07:27 AM   #1
Darkening
Motorcycle(s): Ninja 250R
Bent frame holes for footpeg
Hello to all the ninjette riders in the world! I'm writing from Argentina, I'm new here but not new to the Ninja, owning one from at least 6 years!
I need some help with my bike, after an accident I let it sit for a while and now I'm trying to get it to perfection again. I'm almost done, except for this:
http://imgur.com/bniMzvR
Yeah, that's what the title is about... Sorry for the quality, photo looked good in the small cell phone screen.
Another angle and footpeg installed, to remark the angle:
http://imgur.com/UoMf4um
So, I tried to bend it back using the footpeg but it didn't budge (I don't have the strenght I suppose). I don't want to break the footpeg from excessive force so I didn't use leverage, and I'm not sure that it will be adequate. Should I try to bend it back with something? Maybe hammer it into shape?
Any insight will be appreciated!
Regards from Argentina.
Darkening is offline   Reply With Quote
Old April 25th, 2016, 07:36 AM   #2
Welcome Xan!
The fix for that is to straighten that out as best you can (leverage required) and have a backing plate welded on from behind. Drill and tap holes so they line up with the original ones and get some longer screws to hold the rearset on.
It's a known weak point in the frame.
Old April 25th, 2016, 07:50 AM   #3
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
You probably want to heat with a torch and bend with a pipe wrench.
Bien benido!
My Cafe Racer Build
My intro post
Old April 25th, 2016, 08:01 AM   #4
Darkening
Welcome Xan!
Thanks for the help! I don't suppose there's some tutorial to follow the process?
What's the best way to straighten this? The only thing I have to use as leverage is the footpeg itself and pulling but I don't want to break it. Any other thing or tool for the job?
Bien benido!
Hello! My first idea was using a wrench and bend it back directly, but the the holes and treads in the frame are "sandwiched" between 2 metal parts. I can't bend the front part (the one in the photos) without an ungodly amount of strength and the back plate bending also. I will try a torch if it makes it easier since the paint is scrapped already and I don't worry about burning it.
Thanks for the input!
Last futzed with by Darkening; April 25th, 2016 at 08:14 AM. Reason: Double post. Merged now.
Old April 25th, 2016, 08:13 AM   #5
JohnnyBravo
JohnnyBravo's Avatar
Gonna need some heat and something to pry with... I've use everything from screwdrivers (huge ones), monkey wrenches, adjustable wrench, anything big enough you can make fit, I def wouldn't pry it with a new foot peg, a old broke one could help... Never the new one
Old April 25th, 2016, 08:17 AM   #6
You should end up doing something like this.
https://www.ninjette.org/forums/showthread.php?t=153580 or https://www.ninjette.org/forums/show...7&postcount=28
Old April 25th, 2016, 10:10 AM   #7
Darkening
Tonight I'll try. Just need to find the right tool for the job. I don't have an old footpeg and a new one here is unavailable and expensive so I won't be using my only one for that.
I'll update soon. Maybe my experience can help others in the future.
Wow, amazing jobs there! I'm not ready to do some welding for now, but if I can't straighten it back I'll have this links saved for the ocassion.
I think my frame is bent..... Sharkride 2008 - 2012 Ninja 250R Tech Talk 40 October 15th, 2015 03:44 PM
[RoadRUNNER] - Pot Holes, Sink Holes, and Buckled Roads Ninjette Newsbot Motorcycling News 0 August 26th, 2014 03:01 AM
Bent frame, what do? oblivion007 2008 - 2012 Ninja 250R Tech Talk 30 March 18th, 2014 09:53 PM
how to fix bent footpeg frame mount? Zyconic17 2008 - 2012 Ninja 250R Tech Talk 15 July 25th, 2012 10:12 PM
Questions about paint and holes in the frame. Monkeytofu 1986 - 2007 Ninja 250R Farkles 3 July 15th, 2012 05:22 AM
