April 25th, 2016, 07:27 AM | #1 |
Bent frame holes for footpeg
Hello to all the ninjette riders in the world! I'm writing from Argentina, I'm new here but not new to the Ninja, owning one from at least 6 years!
I need some help with my bike, after an accident I let it sit for a while and now I'm trying to get it to perfection again. I'm almost done, except for this: http://imgur.com/bniMzvR Yeah, that's what the title is about... Sorry for the quality, photo looked good in the small cell phone screen. Another angle and footpeg installed, to remark the angle: http://imgur.com/UoMf4um So, I tried to bend it back using the footpeg but it didn't budge (I don't have the strenght I suppose). I don't want to break the footpeg from excessive force so I didn't use leverage, and I'm not sure that it will be adequate. Should I try to bend it back with something? Maybe hammer it into shape? Any insight will be appreciated! Regards from Argentina. |
April 25th, 2016, 07:36 AM | #2 |
Welcome Xan!
The fix for that is to straighten that out as best you can (leverage required) and have a backing plate welded on from behind. Drill and tap holes so they line up with the original ones and get some longer screws to hold the rearset on. It's a known weak point in the frame.
April 25th, 2016, 07:50 AM | #3 |
I'm crazy,your excuse is?
You probably want to heat with a torch and bend with a pipe wrench.
Bien benido! |
April 25th, 2016, 08:01 AM | #4 | ||
What's the best way to straighten this? The only thing I have to use as leverage is the footpeg itself and pulling but I don't want to break it. Any other thing or tool for the job? Quote:
Thanks for the input! Last futzed with by Darkening; April 25th, 2016 at 08:14 AM. Reason: Double post. Merged now. |
April 25th, 2016, 08:13 AM | #5 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
Gonna need some heat and something to pry with... I've use everything from screwdrivers (huge ones), monkey wrenches, adjustable wrench, anything big enough you can make fit, I def wouldn't pry it with a new foot peg, a old broke one could help... Never the new one
April 25th, 2016, 08:17 AM | #6 | |
https://www.ninjette.org/forums/showthread.php?t=153580 or https://www.ninjette.org/forums/show...7&postcount=28
April 25th, 2016, 10:10 AM | #7 | ||
I'll update soon. Maybe my experience can help others in the future. Quote:
I think my frame is bent..... | Sharkride | 2008 - 2012 Ninja 250R Tech Talk | 40 | October 15th, 2015 03:44 PM |
[RoadRUNNER] - Pot Holes, Sink Holes, and Buckled Roads | Ninjette Newsbot | Motorcycling News | 0 | August 26th, 2014 03:01 AM |
Bent frame, what do? | oblivion007 | 2008 - 2012 Ninja 250R Tech Talk | 30 | March 18th, 2014 09:53 PM |
how to fix bent footpeg frame mount? | Zyconic17 | 2008 - 2012 Ninja 250R Tech Talk | 15 | July 25th, 2012 10:12 PM |
Questions about paint and holes in the frame. | Monkeytofu | 1986 - 2007 Ninja 250R Farkles | 3 | July 15th, 2012 05:22 AM |
