Old May 14th, 2015, 05:00 PM   #1
Kiid-_-Buru
Motorcycle(s): 2009 Kawasaki ninja 250
Exclamation Need advice !!!'
Hey y'all. It is my first time installing aftermarket fairing kit. I have the kit ready to go. But I would like to hear some feedbacks and advices from fellow riders who have more experience with this.
Kiid-_-Buru is offline   Reply With Quote
Old May 14th, 2015, 05:41 PM   #2
Ghostt
Ghostt's Avatar
As far as.....
violente et ignorantia
ZX-2R BLOG
Old May 14th, 2015, 05:50 PM   #3
Kiid-_-Buru
Installing the kit
Old May 14th, 2015, 07:41 PM   #4
Devita818
Motorcycle(s): ninja 250
Well its pretty straight forward take a piece off and put a piece back on. If you are working with a bike that has the plastics on it already work your way from the front to the back. If its already torn down start where you please.
If its an Ebay set don't expect a perfect fit I have experience with two of them and both had minor fitment issues had to bore out some holes some where not drilled at all. Minor paint blemishes but nothing major. No real advice other than expect some minor blemishes and and missing boltn holes
Originally Posted by Kiid-_-Buru View Post
Installing the kit
Devita818 is offline   Reply With Quote
Old May 14th, 2015, 07:52 PM   #5
Are the holes predrilled? If not, to a test fit and get a marker to mark the holes. You may need another hand to hold stuff in place for a flush fitment. While not perfect, they can be done well.
Old May 15th, 2015, 01:46 PM   #6
Kiid-_-Buru
The holes are pre drilled. Yeah there was some adjustment needed to be made. But overall looks well to me. I have a question for y'all. The aftermaket fairings didn't come with the insulation and heat protection as found on the stock fairings. What would you recommend ? I've been told about dynaliner. But I wanted to make sure before purchasing it
Old May 15th, 2015, 02:16 PM   #7
Devita818
Any type of heat shield will help prevent the fairings from warping due to the heat of the headers. Just go to your local auto parts dealer and pick some up. Use the stock set for a template and you cant go wrong.
Old May 17th, 2015, 09:13 AM   #8
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
Old May 19th, 2015, 09:13 PM   #9
Kiid-_-Buru
Hey. Wanted to show how it turned out. There was only few minor fitments. But it turned out well in my opinio. Only thing left is to paint the gas tank to match the fairings. I'm planning to have a professional do it. I'm not at that level.
Old May 20th, 2015, 06:44 AM   #10
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
I like that 70's color scheme.
My Cafe Racer Build
My intro post
Need help and advice please? Kiid-_-Buru 2008 - 2012 Ninja 250R Tech Talk 7 January 17th, 2015 03:56 PM
Need some advice... KrazyWalle 2008 - 2012 Ninja 250R Tech Talk 3 June 30th, 2013 08:02 PM
Need Advice ryan.chin General Motorcycling Discussion 17 August 28th, 2012 08:25 PM
Could this be the one?!... Advice please Prime General Motorcycling Discussion 4 June 9th, 2011 02:39 PM
need some advice tinng321 Off-Topic 12 July 29th, 2009 06:44 AM
