Old March 7th, 2016, 07:12 PM   #1
Elusivepotato
Motorcycle(s): 1995 Kawasaki ex250
New problem
So got the bike to start, kind of. It will start up, but it makes a knocking sound and does not stay running.
https://www.youtube.com/watch?v=ikxNct6JnO4
Elusivepotato is offline   Reply With Quote
Old March 7th, 2016, 07:32 PM   #2
greg737
Motorcycle(s): -
Holy crap, that video... it was like a bigfoot sighting or UFO tape.
Seriously, the bike really didn't run long enough to diagnose anything. One "knock" that's relatively common on the Pre-Gen EX250s is the clutch basket which has hard rubber bumpers in it rather than metal springs like most bikes have. These hard rubber bumpers will disintegrate if the bike it treated rough, shifted hard. Usually there will be evidence in the oil and the oil filter when these bumpers come apart, little flecks of hard, rubbery black stuff.
Old March 7th, 2016, 07:39 PM   #3
That knocking sound is not uncommon.
Sounds like it ran out of gas.
Old March 7th, 2016, 08:00 PM   #4
Elusivepotato
it isn't just one knock though, its consistent and it wont stay running here is a longer video right under the engine
https://www.youtube.com/watch?v=eP-gWj3FLww
Old March 7th, 2016, 08:02 PM   #5
Elusivepotato
also that sudden dying happens whenever I let go of the throttle and or the starter
Old March 8th, 2016, 07:43 AM   #6
Charge your battery.
When it's running it doesn't sound bad. Check your fuel supply. It still sounds like it's running out of gas. Where do you have the choke set?
Old March 8th, 2016, 09:11 AM   #7
HoneyBadgerRy
HoneyBadgerRy's Avatar
Also when the bike is hard starting (if the problem isn't a dead or almost dead battery) giving the carbs a good clean solves the problem.
Old March 8th, 2016, 10:44 AM   #8
verboten1
verboten1's Avatar
MOTM - June '15
sounds to me like you are running on one cylinder, you need to clean your carbs
Ride more, worry less.
Old March 8th, 2016, 10:52 AM   #9
Elusivepotato
I have cleaned the carbs very thoroughly and gone through them multiple times
Old March 8th, 2016, 11:03 AM   #10
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Did you drill out the pilot screw cover, remove the cap, then the screws and clean that passage?
Goin' fast on slow bikes!
Old March 8th, 2016, 11:49 AM   #11
An easy check would be comparing the temps of the pipes when it's running.
Old March 8th, 2016, 11:53 AM   #12
verboten1
verboten1's Avatar
MOTM - June '15
I did the same, and then I bought an ultrasonic cleaner, and new jets, all of a sudden my bike ran just fine.
I even ran some copper wire through the jets, still didn't run right
Old March 8th, 2016, 02:22 PM   #13
Elusivepotato
well i got it to start and idle at speed without assistance but a loud ping sounded and locked up the engine
Old March 8th, 2016, 02:26 PM   #14
greg737
Motorcycle(s): -
wow, that sounds bad. I've never heard of an EX250 engine doing that at idle speed (I've heard of high-RPM failures that ended in seizure, but not at idle).
Old March 8th, 2016, 02:53 PM   #15
Hmm...what does it do now?
Do you get lights and nothing when you hit the button? Do they dim or go out?
Any idea where the sound came from? Have you checked the oil level lately?
Have you charged the battery at all?
Old March 8th, 2016, 06:15 PM   #16
Elusivepotato
the lights dim, and I hear the starter relay click and the electric starter click, but nothing happens. I can move the flywheel with the socket three quarters clockwise, but then it stops and it can move it back to where it was, but I only have three quarters of a turn of play. I dropped down the engine and mounted it on a table and tomorrow I am going to start exploring to see if I can find the cause
Old March 8th, 2016, 06:24 PM   #17
Oh man... my mind is not going fun places right now. Hoping for the best for you. In for pictures.
Old March 8th, 2016, 07:06 PM   #18
Bummer.
Pull the valve cover and see if there are any clues as to what's going on.
Old March 9th, 2016, 09:46 AM   #19
Elusivepotato
I think I found the issue, I pulled of the head cover and took out the camshafts and when I was taking off the rocker arms i noticed one had a gouge in it. I looked over and the two halves of the collar that keeps the valves in place with the spring were gone and I think they worked their way down into the engine. Also the knocking sound makes sense if there is a loose valve freely moving.
Old March 9th, 2016, 10:25 AM   #20
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Um, that's really bad news. This means that, with 95% probability, there is a valve hitting a piston.
Pull the head and have a look. Hope the damage isn't too......explodey.
Old March 9th, 2016, 11:05 AM   #21
Old March 9th, 2016, 11:15 AM   #22
Elusivepotato
At the moment it looks like it is going to be a parts bike, or I will just replace the engine. I got it from the guy for $300. But at the moment I am looking for another one that only needs the sprockets and chain replaced and the engine was recently replaced.
Old March 9th, 2016, 11:29 AM   #23
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Well, for 300 bucks you didn't do too bad! Should be able to find another motor for a few hundred bucks and have yourself a runner for $750 tops.
Old March 9th, 2016, 12:21 PM   #24
Elusivepotato
Just wanted to share what I found when I took off the cylinder cover
Old March 9th, 2016, 12:23 PM   #25
Elusivepotato
They punched a hole straight through the cylinder head
Old March 9th, 2016, 12:39 PM   #26
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
WOW!
Old March 9th, 2016, 04:08 PM   #27
Yepp, that's right where my mind was going when you said it stopped running completely.
Dang son!
Old March 10th, 2016, 08:01 AM   #28
Well, that sucks. What a mess.
Glad you weren't into it much.
Old March 10th, 2016, 11:13 AM   #29
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
My Cafe Racer Build
My intro post
Old March 10th, 2016, 02:58 PM   #30
Elusivepotato
Well I have a new hope with the bike, there was a salvage yard that had an engine with a couple things missing for cheap off of a 2005. I'm going to swap over parts and hopefully bring it back to life
Old March 10th, 2016, 03:47 PM   #31
Jetfoi
Jetfoi's Avatar
Motorcycle(s): 2013 zx6r and 1995 250r
I had an issue similar. Take the carbs out and clean them
spend all the spare time on two wheels
Jetfoi is offline   Reply With Quote
Old March 10th, 2016, 03:56 PM   #32
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
I highly doubt dirty carbs would fix the above issue.
Scroll up a couple posts....there are valves stuck in the pistons.
Old March 10th, 2016, 04:58 PM   #33
Jetfoi
Jetfoi's Avatar
Whoops missed that part sorry
Old March 10th, 2016, 05:02 PM   #34
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
I bet the OP wishes it was a simple carb issue though!
Old March 10th, 2016, 06:10 PM   #35
Elusivepotato
Yeah I wish it was that simple. A local motorcycle shop should have the tools to remove a flywheel right?
Old March 10th, 2016, 06:14 PM   #36
HoneyBadgerRy
Most likely.
Old March 11th, 2016, 12:32 PM   #37
Old March 11th, 2016, 01:29 PM   #38
Baron
Urban Legend
Baron's Avatar
Motorcycle(s): 09 Ninja 250R SE - Circe
The bloody hell?!?!?!
That's going to give me nightmares now.
"Life is like riding - You can either tear the fastlane in half or stay in the slipstream trying to play catch up."
-Baron
Baron is offline   Reply With Quote
Having a problem Teasnuts 1986 - 2007 Ninja 250R Tech Talk 16 April 21st, 2012 11:34 AM
