Old January 12th, 2015, 09:34 PM   #1
DanteCoal
DanteCoal's Avatar
Motorcycle(s): 2016 Ninja 300 ABS, R.I.P 1986 Ninja EX250
Cool 1986 Ninja 250 Update
Hey all, been a long time since I posted. Here's an update on how the Ninja is doing:
New fork seals and oil
- Don't think they'd ever been done.
New Chain
- Was the original chain. There was so much gunk in the front sproket case that I'm shocked the chain could move.
New Brakes Pads
- Both front and rear brake pads were the original pads on the bike. No joke. Back was work down to just bare metal, Front was... well, the inner pad was bare metal, the outer pad was gone and just the caliper piston was hugging the brake pad for stopping... -shudder-
New Meters
- Old ones were spun out so bad that the needles just spun, popped off, speed was reading all over the place, and the RPM was the only thing you could count on... until that needle popped off as well. The temp gauge still worked though. lol
Changed Oil
- Had to buy a new oil filter bolt since the old one was round. As in smooth, round. I had to use a pipe wrench to take it off. Filter was nasty dirty, and green. Didn't know an oil filter could turn green.
Cleaned. Everything. Twice. (Or more)
- Wheels were nearly black when I first got it due to the amount of oil and grime caked on, engine was coated about 1/4" thick in places with grit and grime that was just baked on. Plastics looked like someone had tried to keep them in as bad of shape as possible. And the rust. Spent a day just sanding rust off of the headers, exhaust pipes, and random parts.
Fairing Repair
- Sanding, ABS Cement, Modeling Clay, Sanding, molding, sanding, creating new fairing tabs, sanding, etc, etc. In the pic, where the left side turn signal is, there used to be a hole, approx 2" x 3" big. Haven't bothered with the sanding and painting yet, but it's a plan.
Painting
- Just minor stuff. The rear signal brackets, the rear plastic mount for the signals & plate, experimenting and trying to make it look better than the faded, rusty mess it was.
New Gas Tank
- Old one had a hole in it where the left front fairing mounts to, where the previous owner had put too long of a screw in it... over, and over, and over...
Misc Other Things
- Rebuilt the petcock, new air filter, new handlebars (old were bent), replaced almost every bolt on it, most with Stainless.
To-Do
- New right control switch (old is corroded to the point of uselessness)
- New Tires
- New Swingarm (Someone tried to drill / tap the old one... *facepalm*
- Replace some wires that are old / brittle.
- Rebuild Carbs (I have no idea... I'm hopeless with carb work for some reason)
Either way, it's looking better every day, and rides like a dream whenever I get the chance to take it out. =)
DanteCoal is offline   Reply With Quote
Old January 14th, 2015, 11:13 PM   #2
DanteCoal
DanteCoal's Avatar
Got a new right control and replaced it. But now I think I saw some rust forming in the tank while I was emptying it. >_<
Anyone have any suggestions of tank sealing kits? About to go get some tank gravel and my duct tape. lol
Old January 15th, 2015, 03:07 AM   #3
c-dog
c-dog's Avatar
Motorcycle(s): -
Your bike looks really nice! All that work has really paid off.
c-dog is offline   Reply With Quote
Old January 15th, 2015, 07:23 AM   #4
DanteCoal
DanteCoal's Avatar
Thanks! It's really been a labor of love. I just can't figure out how the previous owner could let it get into such bad shape.
Also good news, worked on the wiring a bit more last night and it starts now! Well, I assume it starts. Everything makes good contact and the voltage is right. Haven't turned it over yet just in case there's rust in there waiting to kill my engine. >_>
Old January 15th, 2015, 08:20 AM   #5
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
thanks for the update, shes looking great!
My Cafe Racer Build
My intro post
Old January 21st, 2015, 11:09 PM   #6
DanteCoal
DanteCoal's Avatar
Well I finally got it all sorted out into good running shape. Got the new right control on and working, drained and replaced the old gas, and replaced some wires while I had the tank off and everything apart.
Took it around the block a few times, around the neighborhood, and it's working like a dream. Even took it to school tonight (Highway speeds (approx 65-80)) and it was amazing. So glad to have it up and running again.
Still really need to get the carbs rebuilt, new swingarm, new tires, and some cosmetic stuff (Powdercoat wheels, etc)
Old January 21st, 2015, 11:54 PM   #7
c-dog
c-dog's Avatar
Motorcycle(s): -
Great to hear, glad you have it all sorted out. Have fun cruising around on it.
Old January 31st, 2015, 12:00 PM   #8
ducatiman
ducatiman's Avatar
you have PM
Old January 31st, 2015, 12:09 PM   #9
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Congrats! If it's running well, you don't have to touch the carbs.
Old January 31st, 2015, 06:19 PM   #10
greenaero
Motorcycle Hypermiler
greenaero's Avatar
Motorcycle(s): 1999 & 2005 Kawasaki Ninja 250R's
Good work! Well worth the effort.
235 MPG Hypermotorcycling to a better tomorrow
greenaero is offline   Reply With Quote
Old January 31st, 2015, 10:03 PM   #11
verboten1
verboten1's Avatar
MOTM - June '15
So much nicer looking than the 20 years of bikes that replaced it!
Ride more, worry less.
Old February 1st, 2015, 05:15 AM   #12
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
A really nice bike
Old February 1st, 2015, 06:26 AM   #13
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
nice looking ride, I likie
1986 ninja 250 james250ninja 1986 - 2007 Ninja 250R Tech Talk 17 September 5th, 2017 07:40 AM
1986-1987 ninja 250? 86ninja 1986 - 2007 Ninja 250R Tech Talk 41 August 28th, 2017 08:58 AM
1986 ninja 250 james250ninja Pictures 12 August 19th, 2014 05:58 AM
Houston TX 1986 ninja 250 poorfatjames New Members 10 June 30th, 2011 04:57 PM
