June 18th, 2014, 12:02 PM | #1 |
Join Date: Mar 2014 Motorcycle(s): 2003 Ninja 250r Posts: 212
Weird stall problem
Wasn't paying attention and I stalled while on a main road rolling to a traffic light. On my other bikes I would just hit the start button and be on my way. I tried this with my Ninja and nothing happened. I had the bike in 1st gear with the clutch pulled in coasting and the starter button was not working. I had to quickly put the bike in neutral and I hit the button and it started right up. Is this normal. This is the first time I have ever stalled this bike so a re-fire is a new thing to me.
June 18th, 2014, 12:04 PM | #2 |
Join Date: Jun 2013 Motorcycle(s): 2010 Ninja 250 Posts: 596
The kickstand/neutral sensors are kinda wonky on these bikes. Next time try flipping the kickstand even if its up.
Or just don't stall and take that as negative reinforcement. |
June 21st, 2014, 03:59 PM | #3 |
did it again toay. i stalled at a light and it wouldn't refire. i tried everything. kickstand down and up, clutch in and out, in gear, in neutral...i rolled into a parking lot, shut the key off, put the kickstand down and acted like it was the first time i was starting the bike. i put it in neutral, hit the button and it fired right up. i don't get it. If i was riding and the engine stalled i should be able to pull in the clutch and start the bike without having to stop right? What should I look for. I tested the kickstand switch. The bike stalls if I put it down. It won't start in gear without the clutch pulled in. What else should I check?
June 21st, 2014, 06:56 PM | #4 |
Down Under
Join Date: Jun 2014 Motorcycle(s): Kawasaki ZXR250C Ninja Posts: 296
I stalled at a red light this morning. The engine was cold as I was running late, and I had the choke off (didn't let it warm up enough). Idle was slowing down, as soon as I gave it a tiny amount of stick, it died.
Took me 3 tries to get it started again. Didn't use the choke. Just tried, let the battery do its recharge thing (manual states give it 5 seconds between each start attempt) and tried again. Lucky the light was red otherwyse I would have a lot of grumpy drivers behind me |
June 21st, 2014, 10:24 PM | #5 | |
Otherwise, take a look at these: http://faq.ninja250.org/wiki/Underst...afety_switches http://faq.ninja250.org/wiki/My_side...27t_work_right http://faq.ninja250.org/wiki/Checkin..._safety_switch http://faq.ninja250.org/wiki/Cleanin..._clutch_switch
June 22nd, 2014, 05:46 PM | #6 | |
it happened again today. this time it was dangeerous because i was in busy traffic. It stalled while sitting at a light idling. I tried everything and I couldnt get it to turn over. It waos as if the sidestand was down but it wasn't. I tried pulling in the clutch in gear and in neutral. I had to turn the key off, put the bike in neutral, turn the key on and as soon as I hit the button it fired right up. I did a test in the garage. I started the bike and I dropped the idle with the idle .knob so it would stall. I hit the button and it instantly started |
June 22nd, 2014, 06:01 PM | #7 | |
June 22nd, 2014, 06:38 PM | #8 |
June 22nd, 2014, 06:48 PM | #9 |
My clutch lever switch has acted up before requiring me to start in neutral.
June 22nd, 2014, 07:37 PM | #10 | |
The engine stalls only when hot and let to idle while in gear=> Lack or weak sparks at low rpms The engine cannot be re-started while in gear by clutching out while the bike is moving => Lack or weak sparks at low rpms Miraculously, the engine fires up when normal starting procedure in neutral. If you checked my previous links, you will see that either your kickstand or your clutch switches are defective, as evidently the neutral switch is working properly: http://faq.ninja250.org/wiki/Underst...unning_Problem The sparks fire up when: in neutral, with the side stand down and the clutch out in neutral, with the side stand up and the clutch out in gear, with the side stand down and the clutch in in gear, with the side stand up and the clutch in
June 22nd, 2014, 08:38 PM | #11 | |
What I am concerned about is a refire after a stall. Say for instance I can't hear the bike while I am stopped and I stall it in error. I should be able to pull the clutch in, hit the button and restart. One time when I first started riding back in 2007 I had a 2001 Ninja 250r. I was on the highway doing about 60 and the bike sputtered and died while I was on a bridge. I realized I had run out of gas so I pulled the clutch in, reached down while still coasting at about 40mph and I turned the petcock to reserve and hit the start button and she fired back up and I was able to make it home. It was scary but I was able to do it. With this bike.. once it stalls.. it won't restart unless I put it in neutral, release the clutch and hit the start button. That can't be correct. |
June 22nd, 2014, 08:42 PM | #12 |
It's not correct. Check your bits I got video of me just flicking the switch from off to on (free free to laugh) during a race and the bike refires and off I go. Yours should be the same.
June 22nd, 2014, 08:43 PM | #13 |
From what I read... it appears I have a faulty clutch switch. I tested my kickstand switch and the bike stalls if I put the kickstand down while its running. My neutral safety switch works because when I put the bike in neutral the light comes on. That leaves only one switch. The clutch switch. I will order a new one and see if that solves the problem.
June 22nd, 2014, 08:46 PM | #14 |
Hope so
June 22nd, 2014, 09:06 PM | #15 |
Well, its not a faulty clutch switch.
Again.. to be as clear as possible.. I am riding the bike and the engine stalls... I pull the clutch in and hit the start button and its dead.. nothing happens. The start button will not work until I turn the bike off with the key, turn it back on and hit the start button again. Then it starts right up. |
June 23rd, 2014, 05:52 AM | #16 |
Have you considered troubleshooting your electrical system?
June 23rd, 2014, 06:40 AM | #17 | |
The thing I can't understand is why.. if the bike stalls while at a stop light in gear with the clutch pulled in I can't just hit the start button and restart the bike. What would cause that? |
June 23rd, 2014, 07:00 AM | #18 | |
Have you checked every connection & switch (ignition included) ? Here's an idea....An intermittently working ignition switch could be losing contact in the run position, that's probably why toggling it off then back on, restarts the bike. |
June 23rd, 2014, 09:16 AM | #19 | |
That's the next thing I need to check. Thanks. |
June 25th, 2014, 05:30 PM | #20 |
OK, I think I have narrowed it down. My bike will not start if its in gear with the clutch pulled in under any circumstance. If I put it in neutral and release the clutch it starts right up. What would cause this?
June 25th, 2014, 05:54 PM | #21 | ||
June 25th, 2014, 06:36 PM | #22 |
Mine does this...
It will start with the side stand down, clutch in or out, in neutral It will start with the side stand up, clutch in or out, in neutral It will not start if the bike in in gear under any circumstances. If the bike is in gear and running and I put the kickstand down it stalls. If the bike is in neutral and running and I put the kickstand down it stays running. So? Whats the verdict? |
June 25th, 2014, 07:15 PM | #23 |
As stated before: bad or broken clutch lever switch. Mine got dusty on Glendora Mountain Road and stopped working for a while.
June 25th, 2014, 08:08 PM | #24 | |
Down Under
The bike should start in gear, kickstand up, clutch in. |
June 25th, 2014, 08:52 PM | #25 |
I'm crazy,your excuse is?
Next time jiggle the clutch switch and should start. Crimp the connectors so you have a tight fit at the lever. Mine does the same thing.
June 25th, 2014, 09:15 PM | #26 |
No, because then it would kick off as soon as he puts in in gear and not when he drops the kickstand. It's the clutch lever switch.
June 25th, 2014, 09:46 PM | #27 |
Fresh Deli Meat
Join Date: Feb 2014 Motorcycle(s): 2009 250R Ninja -Neener- Posts: 678
so I started parking the bike in gear (shortcut being just roll up to you rparking spot with the clutch in and put your kickstand down) about 30% of the time, the bike doesnt shut off. This is in gear, clutch pulled in, attempt the kill engine with kickstand.
We shall call thee "Seahorse." -Antiant on Couvade Syndrome |
June 26th, 2014, 05:41 AM | #28 |
If my bike is in gear... it won't start with the clutch pulled in or out regardless of whether the kickstand is up or down. If it is running in gear and I put the kickstand down it stalls as it should. If I try to start it in gear with the kickstand down it will not start. The bike MUST be in neutral in order for it to be started.
June 26th, 2014, 06:06 AM | #29 |
Down Under
I've started mine in first with the stand up and clutch in
June 26th, 2014, 06:09 AM | #30 |
Here are your options- Replace or Repair the faulty switches. After more than 10 years of being exposed to various conditions and extremes, they may need a little TLC or Total Replacement
Cleaning and servicing the clutch switch-"If the contacts get clogged up with dust, the clutch switch could stop working. Most of the time, it just starts making really annoying grinding sounds and the switch starts offering resistance to the motion of the clutch. But if you get enough guck in the switch, the bike won't start with the clutch pulled in." SWITCH,CLUTCH,BLACK 27010-1094 SWITCH,SIDE STAND 27010-1223 |
June 26th, 2014, 09:29 AM | #31 |
Seems pretty clear that it's the clutch switch. Have you looked at it to make sure that it is pressing that little nubbin correctly? Is it pressing in and out when the clutch lever is pulled and released?
June 26th, 2014, 10:11 AM | #32 |
Yea, it is smooth and set up correctly. I need to test it today. I am going to take it apart too and test it with my Fluke Multimeter to see if the switch is working correctly. My guess is it must be broken internally because externally it looks and works perfectly.
June 26th, 2014, 09:24 PM | #33 |
Well, I disconnected the plug and checked the switch with my meter. It appears to be working fine. When I squeeze my brake lever I hear a little click. When I squeeze my clutch lever I hear nothing. I couldn't remove the switch because the 2 screws that hold it in are so soft they stripped the second I put pressure on them.
June 27th, 2014, 08:29 AM | #34 | |
June 27th, 2014, 09:11 AM | #35 |
Seems to me that this clutch safety switch is just plain stupid. I have owned probably 30 different motorcycles since I started riding and the Ninja 250r is the only one I ever owned that couldn't be accidently started in gear. I would never think of trying to start a bike that wasn't visibly in neutral with the clutch released or in 1st gear with the clutch pulled in.
I can understand it being important for a new rider but after you have started motorcycles 20,000+ times over the years it doesn't seem to have any value. I will try to trace the issue but if I can't find it easily I am going to just jump the two contacts together and not worry about it anymore. |
June 27th, 2014, 10:52 AM | #36 |
Every street motorcycle has these same lockouts, and has for many years now. It's not a Kawi choice; they are DOT requirements.
What is somewhat unique to Kawis is how often the cheapo switches fail, and cause weird behavior like you're experiencing. It's not limited to the 250/300's, the same parts fail just as often on the more high dollar bikes (10R's, 14R's, older 12R's, etc.)
June 27th, 2014, 12:52 PM | #37 | |
June 27th, 2014, 01:04 PM | #38 | |
June 27th, 2014, 01:26 PM | #39 |
June 28th, 2014, 01:17 PM | #40 |
UPDATE!!! Fixed. I removed the switch, took it apart, it was spotless inside and worked perfectly. I added some dialectric grease for good measure. What I noticed was when the clutch lever was completely squeezed in the plunger on the switch still had about 1/8" of travel left in it. That 1/8" of travel was what was preventing the switch to work correctly. I removed the switch, got out the dremel and removed about 1/8 of the plunger. Now.. when the clutch is completely squeezed in its not hitting the plunger. It works perfectly. Now.. the bike will start in gear as long as the clutch lever is squeezed in all the way.
Weird Gas Tank Paint Problem | Scattcatt | General Motorcycling Discussion | 19 | May 21st, 2012 12:45 PM |
weird starting problem | dbking321 | 1986 - 2007 Ninja 250R Tech Talk | 10 | April 19th, 2012 04:12 AM |
Weird Fix it Ticket problem. California | Gurk | General Motorcycling Discussion | 13 | March 22nd, 2012 04:53 AM |
Ninja died on me, weird problem | Liist | 2008 - 2012 Ninja 250R Tech Talk | 7 | January 17th, 2012 07:56 PM |
solved the weird blinker bulb problem | jax | 2008 - 2012 Ninja 250R Tech Talk | 1 | December 11th, 2010 04:05 PM |
