May 17th, 2013, 01:05 PM | #1 |
Join Date: May 2013 Motorcycle(s): 2012 Kawasaki Ninja 250r Posts: 7
Bike won't start, just need quick assistance
OK, so my bike has been in storage all winter, and when I came back from college I could not get the bike started. I did pretty much everything to winterize it, but I know now I didn't do it right. I did add stabile, but I never drained the carbs. I am guessing what I have here is a carb problem, but I would just like to make sure it is before I go taking it off.
To answer some questions, the battery is fully charged, spark plugs are good, and tried putting in fresh gas. In the video below the first two tries are with choke, and second two are without choke where the bike does seem to start but stalls shortly after. http://youtu.be/qfdYYCIYeoo I'm sure it's just the carbs, but I would just like to make sure. I would appreciate any help. Thanks ladies and gents! |
May 17th, 2013, 01:22 PM | #2 |
Ninja Noob
Join Date: Jul 2011 Motorcycle(s): 2008 Ninja 250R Candy Plasma Blue Posts: 128
your carbs need to be cleaned
try some seafoam 1st |
May 17th, 2013, 01:40 PM | #3 |
Welcome Jason!
Keep at it, she will run and good luck!
May 17th, 2013, 02:00 PM | #4 | |
I would expect more cranking to come out of hibernation.
May 17th, 2013, 02:02 PM | #5 |
I'm crazy,your excuse is?
def the carbs, nothing else has changed since you put it away.
May 17th, 2013, 06:14 PM | #6 |
Thanks guys, I'm gonna start with the Sea Foam, then pull out those carbs if I need to.
May 17th, 2013, 06:25 PM | #7 |
Join Date: Aug 2010 Motorcycle(s): 2010 Ninja 250R Posts: 54
In the video it looks like you are going from no choke to full choke. When you're at full choke, you might be dumping way too much fuel into the carburetors. This might sound stupid, but have you tried putting the choke at a quarter or half way on just to have it idle without dying?
May 18th, 2013, 12:15 AM | #8 | |
May 18th, 2013, 06:59 AM | #9 |
Although you did not respond my previous question, here goes the second one:
How did you do it? Just pouring some Sea Foam into the gas tank will not make it reach inside the bowls; you will need to drain those bowls first, then crank the engine some more, so the SF can reach and wet the internal passages of the carb (if they are not fully clogged) driven by the vacuum of the engine. Then, you will need to wait. Also, are you sure that fuel is delivered by the petcock and that it is reaching and filling the bowls of the carbs? After so long, the o-ring of the petcock and/or the float valves could be stuck in the closed position. Again, draining the bowls is the only way to find out.
May 18th, 2013, 08:34 AM | #10 |
Ok to answer your first question, I had been trying 15-20 minutes every day for the past week to try cranking it with and without choke. I never got anywhere with it either, always ended the same with what happens in the video.
For the second question, I drained the bowls yesterday before ever thinking about putting sea foam in. Later on I went out and got some Sea Foam. When I did use the sea foam I added it and then spent at least 10 minutes cranking the engine to try to get some of the solution into the carbs. Should I maybe drain them again just to make sure? Again I appreciate your help. |
May 18th, 2013, 08:40 AM | #11 |
Jason,
You have done the right things before jumping into carbs' surgery. Try again later today, but be gentle with the choke. You could try some starting fluid through the air intake.
May 18th, 2013, 02:20 PM | #12 |
Any chance you played around with the idle adjustment knob or idle screws prior to storing the bike for winter?
I had similar issues when I was riding in 40 degree weather, but I was fiddling around with idle adjustment. |
May 22nd, 2013, 07:18 PM | #13 |
To answer the last question, no I never touched the idle adjustment.
And as a status report, I have decided its time to take out those carbs and clean em. Do you guys recommend doing anything with any of the mechanisms in there as long as I have the carbs out? (Such as to increase performance or anything) |
May 22nd, 2013, 08:49 PM | #14 |
Join Date: Jul 2012 Motorcycle(s): 09' Ninja 250R Posts: 48
Didn't read all the posts in full above, but I had the same problem recently. I know you said the plugs are good but double check the gap just to be 100%, leave them out when you try to start the bike twice to shoot out excess sitting fuel. Then put them back in, open air box, two squirts of starter fluid straight into the air box with no filter full choke and twist throttle on/off/on/off. That gets it going. Once it kicks you'll need to feather the throttle to keep her going for a few seconds and you're gold.
May 24th, 2013, 08:04 PM | #15 |
I cleaned the carbs and bike runs great, thanks for all the help.
May 24th, 2013, 08:08 PM | #16 |
Great, Jason; you are welcome
May 25th, 2013, 07:11 AM | #17 |
May 25th, 2013, 09:00 AM | #18 |
They weren't too bad at all. I still cleaned every part to be sure, but it shows that even the smallest bit of clogging could cause problems.
Bike Won't Start | momoru | 1986 - 2007 Ninja 250R Tech Talk | 6 | June 18th, 2014 08:34 AM |
Bought first bike and 1 day later it won't start: do I have a junk bike? | brendandubs | 1986 - 2007 Ninja 250R Tech Talk | 43 | May 11th, 2014 07:59 AM |
Bike won't start | cuong-nutz | 2008 - 2012 Ninja 250R Tech Talk | 23 | January 17th, 2013 10:56 PM |
Won't start. Quick help please!! | ChiefKeif | 2008 - 2012 Ninja 250R Tech Talk | 12 | November 11th, 2012 07:56 PM |
