Old February 12th, 2015, 07:34 PM   #1
psykown
Motorcycle(s): 2007 Ninja 250 "sold" 2014 ninja 300 "Gold" 2000 DRZ400S (Sold the POS) K7 GSXR600 (Also POS...see a pattern?
Winter Withdrawal
All right, so I am going through winter withdrawel and have been taking care of that by doing some work to my baby, Last night I swapped out the front and rear sprockets along with the chain.
The next step I was looking at was a pod filter (KN R-0990)
and the appropriate new jets. From what I understand the stock jets are 106(keihin)
With a the pod filter and a slip on (Musarri) do you think I would need more then the 108 with some washer under the needle? (all riding is done near sea level) I know this will be a multi try process to get it right I just want to make sure I can order what I need without spending to much extra. The fun of college life lol
psykown is offline   Reply With Quote
Old February 12th, 2015, 07:43 PM   #2
psykown
Would there be any need to change the pilot jet? I have not read anywhere about needing to but I may have missed it.
Old February 15th, 2015, 02:20 AM   #3
Singh2jz
Singh2jz's Avatar
Motorcycle(s): '07 ex250-F/J
Hey yooo, head over to the FAQ site. There's A LOT of info there.
The Bike | The Truck
Old February 15th, 2015, 06:53 AM   #4
psykown
I have actually been spending quite a bit of time over there and feel pretty comfortable with my choice I was just trying so See if there was anything else that others have done that might make this smoother lol
(Yes the stock jets are 105 that was a typo earlier)
Old February 16th, 2015, 07:22 AM   #5
agentbad
agentbad's Avatar
Check out the jetting database to get and idea of what others are running.
https://www.ninjette.org/forums/showthread.php?t=10208
Old February 16th, 2015, 09:10 AM   #6
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
I was running stock pipes, pod filters and the FactoryPro jets I believe 110 mains and whatever pilots they come with (one size) at just about sea level. I had to buy the washers to get the exact tune I wanted though. After I put on my Muzzy full exhaust the tune didn't need any mods.
You will definitely have to pull the carbs a few times during this process mind you but 108 isn't a bad start.
Mods: Offset clutch pressure plate
Old February 16th, 2015, 09:13 AM   #7
FvnnyL3tt3r1ng
It would be wise to do your valve adjustment now because after you get the tune dialed changing the clearances will likely effect your tune.
Old February 16th, 2015, 09:23 AM   #8
psykown
@agentbad Sweet! thanks! that is a thread I hadnt found yet.
@FvnnyL3tt3r1ng I Just finished the valves laaaaate friday night
I was actually pleasantly surprised how easy it was even if time consuming. They were super tight as well I couldnt get an .002 in feeler in there.
The pod filter should be here in another day or two along with the jets so updates will be soon
Old February 21st, 2015, 02:30 PM   #9
psykown
All right so I finished the other four valves that just happen to be in the engine this afternoon and was just getting ready to pull the air box out when I noticed a tube coming from the bottom of it and going into the transmission case.
Is this just a vent to get fluids out of the air box? or is this a bit more important?
Old February 21st, 2015, 04:50 PM   #10
psykown
So I was in the process of removing the air box when I realized I have this Fuel Evaporative system on my bike, apparently it was a california bike because it has the three openings on the back of the tank as well. Have any of you cali guys switched to pod filters and if so what did you do with all of that extra crap? Lol
And I thought I would have this done tonight lol
Old February 27th, 2015, 09:18 AM   #11
psykown
How the !$#*@& Are you supposed to get these KN R 0990 filters on? They are !#@%$ impossible!!!!!!!
Old February 27th, 2015, 11:21 AM   #12
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
Put some spit around the lip to make it slide, still gonna be tight but keep at it, you will get it in, and be extremely satisfied after you are done.
My Cafe Racer Build
My intro post
Old March 1st, 2015, 02:53 PM   #13
psykown
That helped a ton @crazymadbastard, I still couldnt get both sides to get on however, after spending the last few days fighting with it i took an exacto knife a made ever so slight of a bevel along the inside edge. It didnt drop right in, but I did manage to get it to fit with much less verbal lubrication.
Who knew this would be more frustrating then the valve adjustment lol
Old March 10th, 2015, 07:39 AM   #14
psykown
Talking
All right, so I have finally had a (relatively) warm day here and a good chance to test the changes I made. I was a bit apprehensive pulling out of the drive way but it turns out it was all for naught. She ran amazingly! I put the 110 jets with four washers to start with as that seemed to be the most common setup with what I am running, and she pulled hard to redline and idled beautifully. Even started right up with no problems! Oh how I missed that! I cant wait for the rest of this week now!
[motorcyclenews.com - news] - TT Withdrawal? Ninjette Newsbot Motorcycling News 0 June 7th, 2013 12:40 PM
[motorcyclenews.com - news] - TT Withdrawal? Ninjette Newsbot Motorcycling News 0 June 7th, 2013 09:40 AM
[motorcyclistonline] - Winter Riding Gear | Winter Is As Winter Does Ninjette Newsbot Motorcycling News 0 January 23rd, 2013 01:10 PM
Winter-Withdrawal Bob2010 Videos 6 December 7th, 2012 06:36 PM
how do you dealing with withdrawal during bike hibernation BFisher244 General Motorcycling Discussion 28 November 8th, 2011 07:41 AM
