Old April 5th, 2016, 02:03 PM   #1
Brother Michigan
Motorcycle(s): 2013 Ninja 300
I've got my fairings off, what should I do while I'm in here?
Now that it's warm, I'm finally getting around to installing the heated grips my wonderful fiance got me for Christmas (makes sense, eh?) and I'm wondering if there are any general maintenance tasks or cheap upgrades you'd recommend I do while I've got the fairings off.
On my list already are a few things that don't really require the fairings to come off, including an oil change + pickup screen cleaning and replacing a disintegrated clutch cable boot. Thinking about grabbing a battery tender, but my battery has held up like a champ without one and it just doesn't get that cold down here.
So, any suggestions?
DISCLAIMER: I generally have no idea what I'm talking about.
Old April 5th, 2016, 02:05 PM   #2
allanoue
allanoue's Avatar
MOTM - Sep '14
radiator flush
Old April 5th, 2016, 02:23 PM   #3
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Mileage? This will tell you what you should do.
Goin' fast on slow bikes!
Old April 5th, 2016, 02:31 PM   #4
Brother Michigan
Ah yes, forgot to add that. I'm only at ~4500 miles (don't judge :P), so I can't think of any major maintenance that needs to occur like a valve adjustment or anything.
Old April 5th, 2016, 02:35 PM   #5
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Coolant flush should do it then.
Check the air filter.
Check for leaks.
Give your plug caps a quick push to be sure they're seated fully.
Flush your brake fluid! This way if you spill any from the front it won't get on the fairings.
Old April 5th, 2016, 03:19 PM   #6
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
<<<-----<< Cafe racer conversion.
My Cafe Racer Build
My intro post
Old April 29th, 2016, 05:40 PM   #7
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Clean and add a drop of grease to the bushings the plastics snaps into.
Old April 29th, 2016, 05:42 PM   #8
MrAtom
MOTM - July '15
Go on instagram and make a million posts "hay guise i have a motorcycle xD #wrenching #diy #giftfromgod #mechanic"
Really though. Go on Instagram and look at motorcycle posts and you'll eventually see someone changing their oil who thinks they're hot ****.
Old April 29th, 2016, 07:06 PM   #9
HoneyBadgerRy
HoneyBadgerRy's Avatar
Oil, plugs, valves, brake fluid. H*ll, miss well adjust the chain, clean the air filter, and adjust throttle cable slack while your there.
Old April 29th, 2016, 07:07 PM   #10
HoneyBadgerRy
I consider this every time I take the fairings off.
Old April 29th, 2016, 08:12 PM   #11
What to do with the fairings off?!?!?!? Take photos duh!!!
Old April 30th, 2016, 02:51 PM   #12
toEleven
Slower than you.
toEleven's Avatar
Motorcycle(s): CBR600RR, CB750, EX300 (半蔵)
MOTM - May '16
I like where this is going.
DISCLAIMERv1.0: There may be more info on the topic than this forum post. Conduct your own research.
If another thread is linked or quoted, go read it yourself.
toEleven is offline   Reply With Quote
Old April 30th, 2016, 08:15 PM   #13
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
They're ugly naked....don't do it!!!
Old May 3rd, 2016, 09:10 PM   #14
Its_Scott
Motorcycle(s): 2009 Kawasaki Ninja 250R, 2014 Kawasaki Ninja 300 SE ABS
How often should the coolant be changed? I could be wrong but doesn't some coolants have long interval changes?
Its_Scott is offline   Reply With Quote
Old May 3rd, 2016, 09:32 PM   #15
toEleven
Slower than you.
toEleven's Avatar
MOTM - May '16
Depends on the coolant. Engine Ice, for example, recommends yearly changes. The Ninja 300 manual is 3 years or 36,000 kms. In my opinion, it's such an easy thing to do that you might as well do it regularly.
Fairings - Picture of these fairings on a bike bbjminardo Pictures 15 February 22nd, 2013 02:07 PM
