Old March 12th, 2016, 07:38 AM   #1
HoneyBadgerRy
HoneyBadgerRy's Avatar
2 into 1 pregen yoshi Scored
$129 later I have the pregen 2 into 1 that let's you keep the center stand (which I prefer to the kickstand). Going along with my diy ported head and pod filter, I can't wait to get on a dyno.
Old March 12th, 2016, 07:45 AM   #2
Old March 12th, 2016, 10:32 AM   #3
xXecuterXx2
ChocolateMilk Addict
xXecuterXx2's Avatar
Motorcycle(s): '05 EX-250 "Kallie" 85 KLT 110 ATC "Murdock"
Pics right? RIGHT?
Burn Rubber, not your Soul.
xXecuterXx2 is offline   Reply With Quote
Old March 12th, 2016, 10:37 AM   #4
HoneyBadgerRy
I just ordered it, but once I get it on, along with the new paint job and zx2r graphics I'll post some pics.
Old March 21st, 2016, 03:15 PM   #5
HoneyBadgerRy
The yoshimura is so much lighter than stock which is the main reason I bought it, that and it should make better power, but idk until I dyno it. The Yosh mounts on the rear brake master cylinder which is weird, but it kept the exhaust out if the way when cornering which is a huge plus. And it sounds amazing, loud but amazing.
So far I have 38 pilots, 2.75 turns out on the mixture screws, dj114 mains (~120) and Dynoget needles 4 from the bottom 3 from the top. The jetting seems nice, I am not positive on the main yet, but I only went around the block, and I focused on the mixture screws. There is a dead spot between the pilots and mixtirescrews I'm not sure if its lean or rich, pilots or mixturescrews, but playing around in the garage I got it to act like it had slight hanging idle which makes me think lean, but it wasn't very noticeable. What do you guys with 2:1s on a pregen run?
Old March 21st, 2016, 03:17 PM   #6
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
Pics or it did not happen.
My Cafe Racer Build
My intro post
Old March 21st, 2016, 03:24 PM   #7
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Anything more than 3 turns out on a mix screw means you need a bigger pilot. You are very close to that.....
If you have not done so, tune the pilot circuit using the idle-drop method on the mixture screws.
Pilots and mixture screws are the same circuit...there is no transition between the two, therefor there cannot be a dead spot between the two. However, there can be a dead spot between the pilot circuit and the needle or needle jet.
Goin' fast on slow bikes!
Old March 21st, 2016, 03:51 PM   #8
HoneyBadgerRy
I know that they are the same circuit, but I have played with 40's and 38's a lot, and I swear they are. When I run 40s it acts lean off idle, hits a suddenly rich spot, then is mixed properly once I get just before 1/4 throttle and its fairly smooth till wot. When I run 38s it seems fairly mixed, lean, then at or just after 1/4 throttle its mixed properly and fairly smooth till wot. This doesn't make any sense, but that's how it responds.
I was running like 1 turn on 40s or 2.75 turns on 38s.
Old March 21st, 2016, 03:57 PM   #9
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Perform the idle drop procedure with the 38's or whatever is in there and leave it.
If there is a transition hitch, raise or lower the needle.
Old March 21st, 2016, 03:59 PM   #10
HoneyBadgerRy
I just wanted to add this photo, its basically the same one you shared, but I find it a little easier to read, and its a big help when figuring out jetting systems that are way off.
Old March 21st, 2016, 04:48 PM   #11
HoneyBadgerRy
I can't get 40s to a point j like them, 2.5 on 38s and it has hanging idle, 2.75 a hair hanging idle and a bit boggy with the throttle, 3 and it no longer has hanging idle, but its very bogy and liked to die when given throttle at idle.
I set her to 2.5 turns out, I will take it to school and PT tomorrow, and bring a screwdriver. Hopefully I can get it figured out by the weekend and I'll put on the zx2r graphics and take some pics.
Old March 21st, 2016, 04:56 PM   #12
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Please don't tune the pilot circuit by boggy this or hanging that. You'll end up chasing your tail, as you are finding out.
Idle drop. It's the only way to fly.
Then vacuum carb sync.
Double check idle drop.
Then tune your off idle performance by needle position.
Old March 21st, 2016, 05:00 PM   #13
HoneyBadgerRy
Isn't idle drop getting it rich enough that the idle doesn't hang and lean enough it revs up when you give it throttle?
Old March 21st, 2016, 05:04 PM   #14
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
No.
Get the bike warmed up and idling decently. Note the number of turns your mix screw is currently at. Screw it in until it starts to drop idle. Note number of turns. Screw it out until the idle drops. Note number of turns.
Exactly in the middle is where your mix screw should be. Example:
idle drops at 1.5 turns from full stop
idle drops at three turns out from full stop
proper mix screw position is 2.25 turns from full stop
Old March 21st, 2016, 05:06 PM   #15
HoneyBadgerRy
No.
2.5 out to start.
idle drops at 1 turn from full stop
idle drops at three turns from full stop
proper mix screw position is two full turns from full stop.
Thanks, I'll try that tomorrow night.
Old March 21st, 2016, 08:04 PM   #16
verboten1
verboten1's Avatar
MOTM - June '15
Good thing you bought it, if I hadn't just gotten the KLR shock, and the second set of wheels for the versys, that was the next purchase, lol
Ride more, worry less.
Scored a Muzzy Pregen header on eBay! Yamahawk Ninjettes At Speed 13 March 12th, 2016 12:52 PM
Heck yea scored my self a new bike. Proto The Ex-Ninjetters Lair 7 May 12th, 2013 09:39 PM
Scored Rear rotor FvnnyL3tt3r1ng 1986 - 2007 Ninja 250R Tech Talk 8 February 24th, 2013 04:07 PM
Scored Free Indy MotoGP Tickets! Goom General Motorcycling Discussion 14 August 19th, 2012 06:23 PM
Badly scored rotors headshrink 2008 - 2012 Ninja 250R Tech Talk 11 June 15th, 2009 11:00 AM
