Old February 22nd, 2015, 02:40 PM   #6361
Originally Posted by NevadaWolf View Post
Got her high.
Finally got those tires!
Old February 22nd, 2015, 02:48 PM   #6362
Originally Posted by Ghostt View Post
The carburetors do have consumable items, like the needle float valve, float bowl seals, and idle mixture needle screw O-rings, etc.... Which are all included in a K&L rebuilding kit.
Great reminder! thanks.
Recently discovered a sticky float valve and cracked fuel lines. Already replaced the fuel lines, cleaned everything thoroughly. Forgot to order replacement float valves. Just ordered the whole kit. May as well do it all at once.
Old February 22nd, 2015, 06:40 PM   #6363
C-Bass
C-Bass's Avatar
Motorcycle(s): Currently own: 98 Honda VTR1000, 02 Suzuki's DR200 & DR650, 04 & 08 BUSA's, 05 Ducati SS1000, 12 Ninja 250R SE
Went for a ride! (last Sunday, sorry a bit belated). Getting a mild spell here - the mid afternoon temperature was 46 F. Another month or so until the snow completely disappears -
C-Bass is offline   Reply With Quote
Old February 22nd, 2015, 07:57 PM   #6364
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Stripped her down, fussed with the speedo canle, changed the oil, and checked the chain. An artic wind came from somewhere so since she's already nekkid, trying to figure out what else to muck with.
<-- Linky
Old February 24th, 2015, 08:19 AM   #6365
cuong-nutz
cuong-nutz's Avatar
Attempted to contort myself and see if I could replace the gauge cluster bulbs with LED units without taking anything off. Managed to only replace two until I realized I was installing the wrong color. FAIL..
HalfFast Racing Team
Old February 24th, 2015, 04:13 PM   #6366
ftheshack
ftheshack's Avatar
Motorcycle(s): 09 Ninja 250 & 1984 Harley Ironhead 1000
I started ordering parts for the upcoming 7500 mile service. It's only 1300 miles shy of the mark now. I also received my Rapid Transit Recon 19L magnetic tank bag with hydration pack today. With all the 100+ days we get here in TX, I figure the hydration pack will be a bonus during the summer months.
Last futzed with by ftheshack; February 24th, 2015 at 04:19 PM. Reason: left out a word!
ftheshack is offline   Reply With Quote
Old February 24th, 2015, 06:07 PM   #6367
Kept working on my projector retrofit. Mounting plate is done. Time for a cosmetic plate, trimming the shroud, and finishing my vacuum table to make my lens.
Not pretty, but it works:
Old February 26th, 2015, 05:35 PM   #6368
YORCHI
n00b
YORCHI's Avatar
Motorcycle(s): Blue 2010 Ninja 250
Tried to turn it on with no luck. Killed the battery instead.
Guess leaving it parked in the driveway for a few months without ever turning it on was a horrible idea... I always wanted to learn how to clean the carburetor anyways.
Facebook YouTube
#KCCO
YORCHI is offline   Reply With Quote
Old February 26th, 2015, 05:38 PM   #6369
cuong-nutz
cuong-nutz's Avatar
Get yourself a trickle charger. They're worth it.
Old February 26th, 2015, 05:40 PM   #6370
YORCHI
n00b
YORCHI's Avatar
I ordered the battery tender junior from Amazon so it should be here by Saturday. I plan on taking it apart on Saturday and taking the carburetor out. A buddy of mine is helping me clean it on Sunday and then hopefully it starts up fine so I can do a tune up on it and get it ready to sell or at least ride again.
Facebook YouTube
#KCCO
Old February 26th, 2015, 05:41 PM   #6371
YORCHI
n00b
YORCHI's Avatar
Be careful with the magnets on that bag. I have the same one and I wasn't careful taking it off of the tank one time and it took a little bit of paint off with it. Great bag though!
Facebook YouTube
#KCCO
Old February 26th, 2015, 05:47 PM   #6372
Not if you do the right things before you park it. Just starting it up occasionally isn't doing any good - it's actually doing harm.
To store it so it will start when you are ready to ride again you need to do a few things. Add a fuel stabilizer and fill the tank to the top. Drain the floatbowls. Remove the battery and charge it occasionally or use a tender.
If you want the best protection from internal rust and corrosion, change the oil and filter, then start it and run it for 30 seconds before draining the floatbowls. That circulates the fresh oil and protects against corrosion. Don't start it again until you are ready to ride.
Old February 26th, 2015, 05:48 PM   #6373
cuong-nutz
cuong-nutz's Avatar
I have some nice scratches in the paint from my tank bag because dirt had gotten under them.
Old February 26th, 2015, 05:53 PM   #6374
YORCHI
n00b
YORCHI's Avatar
Yea I definitely didn't do anything right, my fault completely. I parked it and then a whole bunch of life things happened and when I finally realized it had been so long, it was too late.
Facebook YouTube
#KCCO
Old February 26th, 2015, 06:08 PM   #6375
Suki2003
Ninjette Lurker
Motorcycle(s): 2003 Ninja EX250 (Cafe, Naked, Wreckurrected)
Put the freshly painted plastics and exhaust back on. and started it up for the first time since December.
had to crank it and let it sit for a little, but it ran!
Suki2003 is offline   Reply With Quote
Old February 26th, 2015, 09:49 PM   #6376
NevadaWolf
NevadaWolf's Avatar
Took her out on a quick 40 mile ride to make sure the speedometer is working again after cleaning and lubing the cable.
Yay no more goofy readings!
<-- Linky
Old February 27th, 2015, 07:16 AM   #6377
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
thought about her...
My Cafe Racer Build
My intro post
Old February 27th, 2015, 07:19 AM   #6378
LittleRedNinjette
Certified Troublemaker
LittleRedNinjette's Avatar
+1
Hopefully pulling the wheels to get the new tires on this weekend....
Raven's Rejuvenation
Old February 27th, 2015, 04:31 PM   #6379
cuong-nutz
cuong-nutz's Avatar
Pulled the fairing to replace the gauge lights with LEDs. I kept the regular bulbs in the water temp and the turn signal light. the water temp lens was just too near the the led bulb to light it up properly and the turn signal indicator only blinked for one side and not the other probably because I didn't have the front turn signals hooked up.
Old February 27th, 2015, 04:36 PM   #6380
cuong-nutz
cuong-nutz's Avatar
O'Reilly's tested my battery and it came out to be a bad. I plan to keep using it until it really can't crank over anymore even with push starting it.
Also the motor is making an odd noise. Can't make out if its the cam chain slappin or the tensioner going out. I'm due for a valve check anyways.
http://youtu.be/S3Z6RM5no6s
Old February 27th, 2015, 07:27 PM   #6381
ryker
chaos theory
ryker's Avatar
Motorcycle(s): 2012 Ninja 250r SE ; 2007 ZZR600
Received some new farkles for the bike today....black rear foot pegs, OEM rear seat cowl, shorty black brake/clutch levers
ryker is offline   Reply With Quote
Old February 27th, 2015, 09:04 PM   #6382
Ghostt
Ghostt's Avatar
Some more pieces and parts showed up today, just waiting for some warmer weather, which is coming shortly.
Stay tuned for some different, inexpensive, and easy modifications.
violente et ignorantia
ZX-2R BLOG
Old March 2nd, 2015, 06:35 AM   #6383
cuong-nutz
cuong-nutz's Avatar
Lost my Sport Touring windscreen this morning on my way into work. Hit a big bump in the road and it flew up into my visor. Aparently I forgot to put back in the screws when I pulled the fairings off. Fail once again.
Old March 2nd, 2015, 07:13 AM   #6384
Ghostt
Ghostt's Avatar
ZX-2R BLOG
Old March 2nd, 2015, 07:29 AM   #6385
LittleRedNinjette
Did you go back for it?? Not sure how it would have held up to that...
Old March 2nd, 2015, 07:46 AM   #6386
cuong-nutz
cuong-nutz's Avatar
I would be real lucky to find it whole when I get out of work. It was dark and I couldn't even see it when I looped back. It doesn't help that there was traffic too so it could have been in pieces.
Old March 2nd, 2015, 07:56 AM   #6387
LittleRedNinjette
Maybe you'll get lucky. I'll keep my finger crossed for you.
Old March 2nd, 2015, 02:41 PM   #6388
cuong-nutz
cuong-nutz's Avatar
I found it.... in pieces. At least I still have the stocker.
Old March 2nd, 2015, 03:14 PM   #6389
Ghostt
Ghostt's Avatar
I would write the manufacturer, and complain that it broke, I just would leave out how. Maybe get another one free, of discount
ZX-2R BLOG
Old March 2nd, 2015, 03:18 PM   #6390
Ghostt
Ghostt's Avatar
Went for a short ride since I'll be taking her to the shop tomorrow. Played in the twisties around Virginia City, then rode home towards an epic lightning storm. Pulled over to get a better view, and was approached by a young man who thought I was a cop (white modular helmet). Sat and chatted with him and his girlfriend for a long time about my long distance travels. Apparently he thought sportbikes weren't really good for anything as a friend of his whined about riding from Fallon to Reno - 60 miles.
Then headed home and saw I was approaching something very very cool.
When I first glanced at the mileage, I said HOLY CRAP!!! A HALF MILLION MILES!!!!, then I saw the decimal point
ZX-2R BLOG
Old March 2nd, 2015, 04:38 PM   #6391
NevadaWolf
NevadaWolf's Avatar
Haha yeah no not that many miles. I am curious when I reach 100k, if the decimal will just vanish or if it will "roll over" back to zero.
<-- Linky
Old March 2nd, 2015, 04:43 PM   #6392
Skullz
Skullz's Avatar
Cuong, mine sounded like that also and i replaced the tensioner with the ape manual CCT, which is a breeze to install.
Old March 3rd, 2015, 05:13 AM   #6393
LittleRedNinjette
Good you have one. Sorry it was busted.
Thats bad karma.
It will just say "TOO MUCH!!!"
Old March 3rd, 2015, 06:59 PM   #6394
jenkem
jenkem's Avatar
Motorcycle(s): 2007 ninja 250
Finally got around to properly installing the new master cylinder and bleeding the lines. Had some trouble introducing brake fluid into the new system but I sort of figured it out eventually. I ended up reverse bleeding the line to force fluid into the mc when my hose popped off...
The brakes are still super spongy and pretty much ineffective but at least there's pressure now. I'm just going to finish up with the rest of the bike and then come back to it. I'm sure there's just a ton of air cached away in little places.
jenkem is offline   Reply With Quote
Old March 3rd, 2015, 07:12 PM   #6395
Ghostt
Ghostt's Avatar
Added hazard flashers via OEM part, plug-n-play, no cutting.
Removed carburetors to replace float valves, due to one got stuck open, read link below.
The pictures below shows the benefits of using a fuel filter. All pictures were taken just after I removed the bowls, no cleaning was done. Also are pictures of the float valves new/old, as you can see the old ones are shot.
I know what your thinking, "Hey Ghostt we thought you rebuilt those back in the spring time last year?"
Confession: I didn't, and don't ask me why, when I did everything else on the bike. I did my full meticulous carburetor service minus the consumables, I still have no idea why I didn't???
ZX-2R BLOG
Last futzed with by Ghostt; March 3rd, 2015 at 10:00 PM.
Old March 4th, 2015, 05:15 AM   #6396
06blackpearl
The Powder Coater
06blackpearl's Avatar
Motorcycle(s): Kawasaki ZX-14R '2012
This years mods for my 2012 14R
Include ...
OZ Wheel Set
Rad Guard
Alien Motion Battery
Brake lines
Galfer rotors
GALFER pads
Alien Head2 exhaust
ASV levers
And probably more..........
Anyhow here's the wheels
Radguard
Rotors/pads
Authorized Dealer:
Core Moto Brake Lines,ASV Inventions,Driven
Racing,Galfer USA, Stahlbus-USA,RK EXCEL,Alien Motion
06blackpearl is offline   Reply With Quote
Old March 4th, 2015, 04:54 PM   #6397
What parts are needed for this?
I was thinking of swapping my left-hand controls for those off of the 300. The intent here is the flash-to-pass trigger. If they include an emergency flasher function, I'd be even happier.
Old March 4th, 2015, 05:42 PM   #6398
Ghostt
Ghostt's Avatar
It's something I pick up from the EX-500.COM world, you just use a left control from a 94~97 EX500, the Kawasaki part #46091-1665, which is used on other models as well,
This Kawasaki 46091-1665 HOUSING-ASSY-CONTROL, is used on these models and components:
1993 ZX600-E1 Ninja ZX-6 HANDLEBAR
1994 EX500-D1 Ninja 500 HANDLEBAR
1994 ZX600-E2 Ninja ZX-6 HANDLEBAR
1995 EX500-D2 Ninja 500 HANDLEBAR
1995 ZG1000-A10 Concours HANDLEBAR
1995 ZX1100-E1 GPZ 1100 HANDLEBAR
1995 ZX600-E3 Ninja ZX-6 HANDLEBAR
1996 EX500-D3 Ninja 500 HANDLEBAR
1996 ZG1000-A11 CANADA ONLY HANDLEBAR
1996 ZX1100-D4 Ninja ZX-11 HANDLEBAR
1996 ZX1100-E2 GPZ 1100 HANDLEBAR
1996 ZX600-E4 Ninja ZX-6 HANDLEBAR
1997 EX500-D4 Ninja 500R HANDLEBAR
1997 ZG1000-A12 Concours HANDLEBAR
1997 ZX1100-D5 Ninja ZX-11 HANDLEBAR
1997 ZX1100-E3 GPZ 1100 HANDLEBAR
1997 ZX600-C10 Ninja 600R HANDLEBAR
1997 ZX600-E5 Ninja ZX-6 HANDLEBAR
1998 ZG1000-A13 Concours HANDLEBAR
Or you can use part number 46091-1857, this one just has symbols, no text
This Kawasaki 46091-1857 HOUSING-ASSY-CONTROL, is used on these models and components:
2002 ZX1200-B1 Ninja ZX-12R HANDLEBAR
2003 ZG1000-A18 Concours HANDLEBAR
2003 ZR1200-A3 ZRX1200R HANDLEBAR
2003 ZR750-H3 ZR-7S HANDLEBAR
2003 ZX1200-B2 Ninja ZX-12R HANDLEBAR
2003 ZX600-E11 ZZR600 HANDLEBAR (E10~E12)
2003 ZX900-F2 Ninja ZX-9R HANDLEBAR
2004 ZG1000-A19 Concours HANDLEBAR
2004 ZR1200-A4 ZRX1200R HANDLEBAR
2004 ZR750-H4 CANADA ONLY HANDLEBAR
2004 ZX600-E12 ZZR600 HANDLEBAR (E10~E12)
2005 ZG1000-A20 Concours HANDLEBAR
2005 ZR1200-A5 ZRX1200R HANDLEBAR
2005 ZR750-H5 CANADA ONLY HANDLEBAR
2005 ZX600-J4 ZZR600 HANDLEBAR
2006 ZG1000A6F Concours HANDLEBAR
2006 ZX600J6F ZZR600 HANDLEBAR
2007 ZX600J7F ZZR600 HANDLEBAR
2008 ZX600J8F ZZR600 HANDLEBAR
I must give credit to @InvisiBill for coming up with this in the first place over on THE EX-500.COM, http://www.ex-500.com/index.php/topi...tml#msg1014450
It was truly was a PnP install, and it works perfectly. I got mine off eBay for $14.00 USD shipped
Below are my pictures of the installation.
SIDENOTE: When using the hazard feature, the turn indicator on the gauge cluster does NOT blink , why? I have .I idea, but this is only in hazard flasher mode.
After looking at the left and right controls, I should have gotten an matching set, because now my are very mismatched, due to sun faded, etc.... Something to think about in the future.
ZX-2R BLOG
Old March 4th, 2015, 05:54 PM   #6399
Werd, thanks Ghostt!
Old March 4th, 2015, 06:01 PM   #6400
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
No flash-to-pass trigger on any of the 500 controls. I've thought it would be nice to have too, but didn't get much further than that since I've never in my life flashed anything in any way related to a pass (only to signal "go ahead" at a 4-way stop or something). The trick is finding another model that has FTP and carbs, so that you get a control made to work with the choke lever. Or just add in your own momentary switch soldered to the high-beam contacts.
The indicator is actually hooked to the +12V wire on each side. It uses the active side's wire for power and the off side's wire for ground, as there's a voltage differential between the two. With the flashers on, both sides have +12V, so there's no voltage differential, so the indicator doesn't light up. Since the power flows in opposite directions depending on which side is on, that also means an LED bulb for the indicator will only work for one side (and only for the other side if you reverse the polarity).
Discovered something scary about my Ninjette today... kjohng General Motorcycling Discussion 28 October 15th, 2021 01:40 PM
Sold the 2006 Ninjette today :( Renner General Motorcycling Discussion 31 October 16th, 2014 11:46 PM
Today I Gave My Ninjette Wings! BlueHairSar Pictures 5 June 20th, 2013 07:38 AM
my bro went down today on his ninjette richierich781 !%@*#$%!)@#&!%@ I crashed! 46 January 18th, 2013 11:59 AM
Ninjette. org hacked today CC Cowboy Off-Topic 9 April 3rd, 2011 08:55 AM
