Old March 27th, 2015, 11:34 PM   #1
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
Bleeding brakes - simple and easy
This is valid for the 300 (plus every and each bike) also.
Stahlbus bleeder valves, please look here: http://www.stahlbus-us.com/
Old March 28th, 2015, 06:16 AM   #2
Old March 28th, 2015, 06:47 AM   #3
Ghostt
Ghostt's Avatar
I have those auto bleeders, but I still use the hand vacuum pump, still the fastest, best way.
violente et ignorantia
ZX-2R BLOG
Old March 30th, 2015, 05:53 AM   #4
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
Sorry to thread jack, but this seemed appropriate thread. Quick question: are the front brakes typically hard to bleed? Even using the conventional method? Before removing old pads, ousted the old pad to apply pressure to caliper Pistons, and cracked the bleeder valve to allow them to compress, closed bleeder valve before removing pressure. Ended having to remove brake line as the caliper slides were stuck. When re-assembling, had to continue bleeding air out, which is rather difficult given the small master cylinder size. Using a bleeder bottle, I feel I have all the air out, and have run a fair amount of fluid through, but have little or no lever stiffness. Lever retracts all the way to handle bar. Caliper moves and grabs rotor, but I can still spin wheel by hand. Any help appreciated.
Thanks~
Old March 30th, 2015, 07:20 AM   #5
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
The best way I have bled systems that are hard to bleed, is to tap a hole on a spare brake reservoir cap and put a air valve on that -or a quick air connect and pressurize with air up to 10psi and- watch that fluid level- crack bleeder open and be done in a few moments.
My Cafe Racer Build
My intro post
Old March 30th, 2015, 07:24 AM   #6
Ghostt
Ghostt's Avatar
Best and easiest way to bleed brakes,
HFS Brand 2 in 1 Brake Bleeder & Vacuum Pump Test Tuner Tool Kit New https://www.amazon.com/dp/B00NP60URE..._3Xvgvb0PPV82B
ZX-2R BLOG
Old March 30th, 2015, 07:37 AM   #7
Thanks~
Yes, bike brakes can be very difficult to bleed. The old school method of hand pumping while loosening, then retightening the bleeder can be near impossible. If you don't have the "proper tools" , then you can use the "poor mans" way.
Honestly, even though I have a vac pump, I still use this method most of the time, especially trackside as I don't take my bleeder with me. I aint sure when it became improper to do it like this, but no air... is just that, no air.
Old March 30th, 2015, 08:06 AM   #8
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
At $40+ EACH, those Stahlbus valves are a bit spendy... but then on the Ninjette you only have the one caliper up front. I don't recall if the M/C has a bleeder on it... IIRC it doesn't.
Stahlbus points out something that I think catches people. When you crack the bleeder, it's supposedly possible for air to seep in through the threads.
I've read elsewhere of putting plumber's teflon tape on the threads to help prevent this:
http://www.gixxer.com/forums/showthread.php?t=283074
Side note: Since brake fluid is hygroscopic (absorbs moisture) there is no reason to use just part of a bottle when replacing your fluid. That's false economy... by the time you need the rest of the bottle it'll be no good.
Side note #2: Hydraulic fluid is basically oil. It's okay to chuck it in with your waste engine oil for proper disposal.
(Pet peeve: Instructions that say "dispose of properly" with no guidance whatsoever on how to do that.)
Old March 30th, 2015, 08:20 AM   #9
Thread tape... when nothing else will seal it, it's most likely a leaky thread.
Old March 30th, 2015, 08:47 AM   #10
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
On the upper sealing threads near the hex flats in the right direction specifically. I have seen people tape it all the way to the bottom of the threads and get little pieces ripped off and stuck in brake system.
Old March 30th, 2015, 08:57 AM   #11
crazymadbastard
If the bleeder leaks something else is amiss. Either the breeder is bad or could be rust or scale getting in the way, or the caliper is now junk.
For the bleeding noted above that will work- just don't rely on for sealing a leaking bleeder.
My Cafe Racer Build
My intro post
Old March 30th, 2015, 07:28 PM   #12
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
Finally got it. Seemed that I had air behind one of the pistons, and the caliper slide was hydro locked, not allowing the caliper pistons to move. Had to disassemble the caliper slide bracket, clean out gunk I missed. Re-lubed, little less this time, pushed pistons all the way in with the bourse hose off, which cleared the air. From there, hooked up my $8 bleeder bottle from Advanced Auto, pumped a few cycles of fluid through, and that was it. Great lever pressure. Pulled about 35-40 miles of bedding the pads. All is well again. Thanks for the help.
Old March 30th, 2015, 07:42 PM   #13
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
Thanks for the info. I didn't realize you can't bleed the brakes the way you do in a car (2 person job).
Person 1 pumps and holds the brake pedal & tells person 2 to open the nipple
Person 2 opens the nipple and lets the fluid out.
Person 2 closes the nipples and informs Person 1 to release
Person 1 releases brake pedal
Keep repeating until all old fluid is out and no more bubbles.
Sometimes I take a small mallet and gently tap the calipers.....real gently.
Now.....why can't we do it the same way with the bike? How would air be introduced to the line?
Old March 30th, 2015, 08:07 PM   #14
Brother Michigan
Motorcycle(s): 2013 Ninja 300
You can absolutely do it this way (I just recently did it when installing my stainless lines), but it's a 1-person job on a bike.
DISCLAIMER: I generally have no idea what I'm talking about.
Old March 30th, 2015, 09:34 PM   #15
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
Wait....if you can do it this way and especially since it's a 1 person for the 250/300 (since calipers are on the right side of the bike), why spend money for a vacuum device???
Old March 30th, 2015, 09:38 PM   #16
agentbad
agentbad's Avatar
I just use a cut up plastic bottle as a catch, gloves, dirty shop towels, and my thumb. If you really want speed bleeders murphskits has them. I think the part number is
SB8125L for the newgen at $7 a piece.
Old March 30th, 2015, 10:21 PM   #17
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
Just remember, if you do this with a mtn dew bottle your brakes will stop you quicker afterwards
does anyone ever reuse the brake fluid afterwards? I always put new fluid in but I'm wondering if it can be done safely
Old March 30th, 2015, 10:33 PM   #18
i gotta one up ya
get a hose long enough that it will reach all the way up to the MC res.... pump the fluid out of the caliper, back into the res... circulate it for 5 minutes. aint no ****in bubs left after that ****!
Old March 30th, 2015, 11:58 PM   #19
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
i gotta one up ya
Genius!!! For a bike, it's definitely doable. 4ft of tubing would be enough. There's no sense of throwing away the fluid since it's all new fluid anyway! And at the very end, just pour new fluid in the MC if it makes you more comfortable!
Old March 31st, 2015, 03:29 AM   #20
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
And you don't have to refill the master cylinder after 3 pumps...wish I would have thought of that....
Old March 31st, 2015, 07:09 AM   #21
Brother Michigan
Because it takes forever. I took about two hours to replace my brake lines, and about an hour and a half of it was bleeding.
Old March 31st, 2015, 07:41 AM   #22
i gotta one up ya
omg duh, soooo simple
Old March 31st, 2015, 07:45 AM   #23
Hero Danny
Inline 4!!!
Hero Danny's Avatar
sorta unrelated: My car's brakes really need to be done soon.... I've been putting it off for a while now.. Not sure if the system needs to be bled or not. pads have some meat to them, but the pedal feels so squishy. So I guess there must be air, funny cause the brake level has been near full the entire time I've owned the car.
Be careful. Remember you are
invisible
Old March 31st, 2015, 08:00 AM   #24
Yep, you got air or the fluid needs flushed. I need to do my durango fronts, again....
Old March 31st, 2015, 08:02 AM   #25
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
zip tie the brake lever into the brake position overnight before, makes it easier or so I'm told
Old March 31st, 2015, 08:11 AM   #26
crazymadbastard
worn pads will give you an iffi feeling too. Suggest new rotors and pads. Rock auto.com is excellent. Buy best you can afford.
What I do is pinch brake lines after protecting them with an old hose and vice grips- crack bleeder open and try caliper apart. This does 3 things- gets rid of old fluid in calipers and prevents same crap old gunk from finding its way back up the system and makes getting caliper retracted easier. suck out old brake reservoir fluid with a turkey baster and fill with fresh- continue to bleed as normal.
My Cafe Racer Build
My intro post
Old March 31st, 2015, 08:21 AM   #27
agentbad
agentbad's Avatar
Old March 31st, 2015, 08:25 AM   #28
Brother Michigan
Oh, I did that, too; it took me that long just to get the big bubbles out.
Old March 31st, 2015, 12:10 PM   #29
Hero Danny
Inline 4!!!
Hero Danny's Avatar
We checked my brake pads 6 months ago and they had some good life left to them.
invisible
[RoadRUNNER] - MotoMojo: Bleeding Brakes Ninjette Newsbot Motorcycling News 0 April 15th, 2014 09:40 AM
Bleeding brakes but lever doesn't stiffen after pumping? chsonnu 2008 - 2012 Ninja 250R Tech Talk 12 August 8th, 2013 01:46 PM
SS lines and bleeding the brakes Aggrotech 2008 - 2012 Ninja 250R Tech Talk 13 July 16th, 2013 08:31 PM
DIY Bleeding Brakes - A new method g21-30 2008 - 2012 Ninja 250R Tech Talk 7 December 30th, 2009 08:51 AM
Bleeding Brakes. Possible air in my system? Ken 2008 - 2012 Ninja 250R Tech Talk 16 March 25th, 2009 03:07 PM
