Old January 3rd, 2013, 07:20 PM   #1
toomanyproblems
Motorcycle(s): ninja 250 03
just cleaned carb now it bogs down and dies
My bike will idle but when I give it throttle between 2 and 5000 rpms it bogs down and dies anyone got any ideas?
I'm stuck with no solutions
toomanyproblems is offline   Reply With Quote
Old January 3rd, 2013, 07:29 PM   #2
Joshorilla
Bass Master General
Joshorilla's Avatar
ORLY?
http://www.ninjette.org/forums/showthread.php?t=100215
http://www.ninjette.org/forums/showthread.php?t=85023
http://www.ninjette.org/forums/showthread.php?t=66131
http://www.ninjette.org/forums/showthread.php?t=26887
Old January 3rd, 2013, 07:46 PM   #3
himynameisjoe
himynameisjoe's Avatar
Motorcycle(s): 2012 Ninja 250(Totaled)
I feel like every day for the past 2 weeks there has been a "HELP I DID SOMETHING THAT I WASN'T ENTIRELY SURE HOW TO DO, AND NOW MY BIKE STALLS!" thread.
"I am a creationist, I believe man created god."
himynameisjoe is offline   Reply With Quote
Old January 3rd, 2013, 07:52 PM   #4
.......I'm stuck with no solutions
Welcome to the site, Richard !!!
Could you give us some story about the bike's performance before the service?
Did you do the work yourself?
Old January 3rd, 2013, 08:36 PM   #5
toomanyproblems
it ran a little rich now its just running really rich back fires with flames and bogs down and dies idles fine it has a muzzy exhaust on left side its an 03 sorry about the punctuation or lack there of
Old January 3rd, 2013, 08:48 PM   #6
lgk
If you have a clear hose handy, then i would check the fuel level inside the carb first.
Old January 3rd, 2013, 09:19 PM   #7
toomanyproblems
we turned the fuel mixture all the way up and it no longer bogs down it just wont get going is that to lean or to little rich new to working on motorcycles
Old January 3rd, 2013, 09:26 PM   #8
toomanyproblems
i just open my gas tank and started the bike, after a few seconds it would i gave it gas and it worked any solutions?
Old January 3rd, 2013, 09:53 PM   #9
toomanyproblems
bike bogs with any throttle given and backfire with actual fire any ideas
Old January 3rd, 2013, 09:58 PM   #10
lgk
Did you turn the mixture screws all the way in then 2.5 turns out?
Old January 4th, 2013, 05:27 AM   #11
n4mwd
n4mwd's Avatar
Ok, about that Muzzy exhaust. Did you rejet the carb for the Muzzy? And Do you mean that the bike has a single exhaust? With a 2 into 1 header? You also said it was on the "left" side which is strange because those kits are normally installed on the right side.
My Ninja Blog
Old January 4th, 2013, 08:18 AM   #12
toomanyproblems
Yes it's a two into one and your correct about the side it's on the right, it has been rejetted I'm starting to think it is a vacuum leak maybe
Old January 4th, 2013, 08:29 AM   #13
n4mwd
n4mwd's Avatar
Try covering the mixture screw holes with you finger. Sometimes the leak if they aren't perfect.
My Ninja Blog
Old January 5th, 2013, 09:57 AM   #14
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
Curious if OP tried this?
N4MWD- How many revolutions do those idle mix screws have before they fall out?
Old January 5th, 2013, 12:42 PM   #15
n4mwd
n4mwd's Avatar
Not sure, but what happens is that the gasket in there gets loose or leaky. The OEM carbs have a metal plug over the holes.
My Ninja Blog
Old January 26th, 2013, 03:25 PM   #16
FvnnyL3tt3r1ng
Thread resurrected. What happened?????????????
Old January 26th, 2013, 03:46 PM   #17
ninja250r81
ninja250r81's Avatar
Motorcycle(s): 2012 ninja 250r se
spark plug fouled with carb cleaner
ninja250r81 is offline   Reply With Quote
Old January 27th, 2013, 11:09 AM   #18
DaBlue1
DaBlue1's Avatar
What kind of carb cleaner was used?
Old February 7th, 2013, 10:55 AM   #19
GlassAnkles
GlassAnkles's Avatar
Motorcycle(s): 02 zx-12r, 13 zx-10r abs
carb cleaners suck in general. ive seen a few brands eat o-rings a few seconds after being sprayed with it. stick to manual cleanings, its good to know how to take them apart anyways.
GlassAnkles is offline   Reply With Quote
Old February 7th, 2013, 12:23 PM   #20
Originally Posted by CZroe View Post
Old April 23rd, 2015, 04:11 PM   #21
ducatiman
ducatiman's Avatar
"Missing needle seats"
old thread, but here goes anyway...
not possible....seats are pressed in, no? explain?
Old April 23rd, 2015, 04:37 PM   #22
cookiebug79
n00b with the b00bs
cookiebug79's Avatar
Motorcycle(s): 2007 EX250, 2008 EX250, 2001 ZR-7S, 2010 ZX-6R
Seats are not pressed in. They're held in place by the main jet. If you unscrew the main jet, the needle seats come out.
cookiebug79 is offline   Reply With Quote
Old April 23rd, 2015, 05:40 PM   #23
ducatiman
ducatiman's Avatar
you are incorrect
the main jet screws into (and is held) by the *emulsion tube* (aka main jet holder, main nozzle whatever you'd like to call it)
the (float valve) *seats* are, in fact, pressed in
I believe you are referring to needle *jets*, which reside under the emulsion tubes.
Old April 24th, 2015, 06:30 AM   #24
agentbad
agentbad's Avatar
you are incorrect
So I don't think I've ever actually taken my jet collars (silver pieces) out. I've taken the main jets out lots of times but the jet collars don't seem to want to come out.
Last futzed with by agentbad; April 24th, 2015 at 08:19 AM. Reason: I love lamp.
Old April 25th, 2015, 03:19 PM   #25
ducatiman
ducatiman's Avatar
agent-
by silver pieces you are referring to needle jets....after removing emulsion tubes (aka main jet holders) and the diaphragms and needles...the needle jets can then be carefully tapped *downward* and out of the carb body. Don't use any jagged or sharp object...a light tap with a small wooden dowel should be all thats required. Give them a bath...obviously the inner circumference is the "working" surface...I pull most of the cotton off a q-tip, douse it with carb cleaner and spin it in there and treat ultrasonically. ummm, wipe clean the actual slide needle too...you want no "film"....the mixing holes and inside of the emulsion tube as well....these parts actually comprise a mixing chamber.
Also the air correction jet on the intake bell....which meters air into this main mixing chamber.
I use soda blast equipment for like-new surfaces (pic) These were brown-green before blast.
Sorry for run-on...could go on for hours re micro cleaning.
Old May 18th, 2015, 05:52 AM   #26
These things (quote from another thread):
Just curious, but did they give you a new pair of these things in the jet kit or did they use something different? Or do you just use the old ones?
Old May 18th, 2015, 06:50 AM   #27
(SNIP)
Those parts do look nice...
One thing to consider when you have really corroded brass carb parts is interior corrosion - the kind you can't see or get to.
If the parts are heavily corroded on the outside I will replace them instead of trying to clean them. Any amount of pitting or corrosion left inside the tiny passages of a fuel-metering part can disrupt flow and cause running problems that are hard to diagnose and isolate.
Old May 20th, 2015, 05:58 AM   #28
agentbad
agentbad's Avatar
agent-
Thanks good info.
Bike bogs down at 9K stubshaft 2008 - 2012 Ninja 250R Tech Talk 7 May 5th, 2014 05:41 PM
Carb problem... dies when on the gas jboyd12 2008 - 2012 Ninja 250R Tech Talk 43 April 9th, 2014 03:31 PM
Throttle problem? Bike bogs and dies MikeBudd 2008 - 2012 Ninja 250R Tech Talk 12 September 8th, 2011 09:02 PM
Engine Bogs and dies? xlatinox 1986 - 2007 Ninja 250R Tech Talk 4 February 19th, 2011 12:24 AM
08 dies on idle now, is the carb cleaning covered in warranty? novak2k9 2008 - 2012 Ninja 250R Tech Talk 7 September 6th, 2009 08:33 PM
