Old August 29th, 2013, 03:42 AM   #1
arnoldc6
arnoldc6's Avatar
Motorcycle(s): 09 ninja 250r
I put diesel in my engine.
I think.
Was at 76, super tired and i reach for the far left button without even checking.
Is this gonna cause engine damage?
And do you guys know if is diesel higher density than unleaded? I put in 4.2 gallons of diesel in there, if diesel floats on top i can always pull it in the shop and have them drain it.
Man i am ****ing retarded.
Oh and since the ****ing gas station isn't picking up phone calls, is yellow diesel? Haven't fill up my bike in almost a month.. was doing maintenance.
"trust me, I am not a lawyer."
arnoldc6 is offline   Reply With Quote
Old August 29th, 2013, 03:54 AM   #2
Possible but unlikely unless you tried to ride it for a long time afterwards. Flush and fill and see where your at but I bet your gunna be fine.
Old August 29th, 2013, 04:01 AM   #3
arnoldc6
arnoldc6's Avatar
So unlike Fi system diesel DOES burn on a carburetor engine?
Old August 29th, 2013, 04:09 AM   #4
j98sprint
Motorcycle(s): '02 Ninja 250, '98 Triumph Sprint 900, '69 H-D Sportster XLCH 900
Drain the tank. Drain the float bowls. Put gasoline in the tank. Ride your motorcycle.
j98sprint
j98sprint is offline   Reply With Quote
Old August 29th, 2013, 04:13 AM   #5
ForceofWill
Blind 250 Loving Whore
ForceofWill's Avatar
Since you say you pushed the far left button I'm assuming the pump had multiple buttons for 1 pump hose. If that's the case all the buttons for that hose will be Gasoline. They won't mix diesel and gas like that. Diesel will be a seperate hose/handle and it's always GREEN.
Old August 29th, 2013, 04:26 AM   #6
arnoldc6
arnoldc6's Avatar
I hope so man. I called that place and guess what? She doesn't ****ing speak English. When i try to explain and ask she said it's diesel. I don't think she even knows what diesel is tho...
Man i am depressed. This is one of the shittest day in a few months.
Old August 29th, 2013, 04:41 AM   #7
Well, say you were not 100% OUT of gas when you filled with diesel. So with that assumption, the bike "could" run on whatever % of mix for a while. FI or carbed, it's possible to to burn a bit of diesel but it's gunna run like crap.
Also, I have seen;
No colors on the pump
Color for gas only
Color for diesel only
1 hose/handle for both gas and diesel
Back to your issue though...
So if you pressed the far left button on the pump, lets assume you got lowest grade gas. Is the bike running fine or do you just think you put diesel in it and want to be preemptive?
Old August 29th, 2013, 04:48 AM   #8
arnoldc6
arnoldc6's Avatar
Also, I have seen;
Color for gas only
Well the lowest grade in my state i've seen is 87...which is for our bike.
I am just not sure if it's diesel or not..i have about .3-.5 gallons left but the time i few it up.
So far it runs fine but even so it could've been the last drip of last tank.
Not enough for me to drive back there to check it myself..
I think i am gonna stay up until is 8am in central time just to call their HQ and ask.
Old August 29th, 2013, 06:05 AM   #9
I think.
And do you guys know if is diesel higher density than unleaded?...........
Cheer up, Arnold !!!
Diesel and gas will mix perfectly.
I have seen engines working with that mix in countries where gasoline is scarce.
It will not damage your engine.
Start ups with a cold engine will be hard, but once it starts up, you will see plenty of white smoke coming from the exhaust pipes at all times.
If the mix is so high on Diesel, you will not be able to start the engine.
Try starting it up and look for that white smoke and verify if you actually filled it up with Diesel or gasoline.
Old August 29th, 2013, 06:10 AM   #10
arnoldc6
arnoldc6's Avatar
Good idea!
Thanks!
Well it's too late to change things now, but at least i learnt not to stare at ceiling lights for no reason.
Old August 29th, 2013, 06:15 AM   #11
If you did put diesel in it I would completely drain the tank and float bowls.
I'm don't think it will run at all if you added a large amount of it.
The fuels are completely different. They flow, meter, and ignite differently.
Old August 29th, 2013, 06:24 AM   #12
MR2Aaron
Motorcycle(s): 2003 Kawasaki Ninja 250
It's ok, it won't hurt nothin'.
I'd get a sample out of tank into a clear container. Diesel is bright greenish yellow, and looks like the brine left over from a jar of sandwich peppers. Brighter than pickle brine. Gasoline is more yellow than green and appears mostly clear unless you have a huge container of it. It also smells different from diesel. You'd have had to use the special diesel handle, though, to actually buy diesel. If it's one of those pumps that has four handles, I could imagine that happening, but otherwise, that seems unlikely.
The good news is, this is relatively easy to fix, if you do in fact have diesel in there. Just drain the tank and carbs into something (a diesel can?), and refill with gasoline. A little bit of residue left in the tank won't hurt anything.
MR2Aaron is offline   Reply With Quote
Old August 29th, 2013, 06:43 AM   #13
DaBlue1
DaBlue1's Avatar
On most newer gas pumps, the far left hose is gas, the far right hoses are usually either diesel or E15+ (depending on the pump, some are on the far right). Most of the diesel hoses I've seen have a green handle and the E15+ have yellow. Some of the gas handles range from black, silver, gold, blue (for race gas E100+) even seen some red ones on much older pumps.
The newer selection buttons on the pumps are yellow for gas and orange (some white with green letters) for E15+.
If you got diesel fuel in your tank you will definitely know it by it's smell and color. With most gasolines they will be translucent, diesel is a little more opaque (darker in color). One other thing to note is that the metal tip of the diesel hose is much bigger in diameter than the gas hose in most cases and will not fit in a newer gas filler neck.
Old August 29th, 2013, 07:14 AM   #14
Good idea!
Thanks!
You are welcome
Feel better yet?
You have not been the first biker:
http://answers.google.com/answers/th...id/592587.html
http://auto.howstuffworks.com/fuel-e...n-unleaded.htm
"In any car manufactured in the last 25 years or so, there's a plate under the gas cap that prevents anything but the small unleaded-gasoline nozzle from fitting into the tank. When unleaded gasoline first appeared, this plate helped to prevent drivers from putting the leaded gasoline nozzle in -- the unleaded and leaded nozzles were different sizes. The diesel nozzle is even bigger than leaded nozzles were, so it would never fit in the gas tank of most cars. However, most motorcycles and trucks don't have this plate, so it's easy to make this mistake if you're driving one of those vehicles. And if you're driving an older car, there's no plate either."
Old August 29th, 2013, 07:16 AM   #15
If you put 4.2 gallons of diesel in, the bike would stop running in a few miles. Yes, a bike or car can run (poorly) on a mix, but you had an almost empty tank, so it's almost entirely diesel now if that's what you filled it with. Seeing how you were able to ride home, I doubt you filled it with diesel in the first place.
Old August 29th, 2013, 08:41 AM   #16
diesel wont ignite properly by itself simply from the spark. if there is gas in the mix the gas will burn first, igniting the diesel. also i think the ninja 250 gas tank does have the little plate with a hole in it, and i'm pretty sure the diesel nozzle would not fit in there.
Old August 29th, 2013, 09:47 AM   #17
n4mwd
n4mwd's Avatar
Maybe just go back to the station in the daytime and check that exact same pump to see what the far left dispenses. Or you could just smell your gas tank. Diesel is an oil which smells totally different from gas. It may also be possible that you got E85 instead. In that case, it will smell like a bar.
Did you get a receipt? Sometimes the pump prints what you got on the receipt.
I would be more worried about E85 than diesel. E85 can actually damage your bike and diesel at worst would simply not run and would need to be flushed out.
Worst case, drain the tank and refill with known good stuff (87 octane).
My Ninja Blog
Old August 29th, 2013, 10:26 AM   #18
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
simply look inside the tank witha match, if it blows up and kills you it was gas. If it simply catches on fire it is diesel.
Dont do that!!
I agreee if it was diesel your bike would not run right.
My Cafe Racer Build
My intro post
Old August 29th, 2013, 04:46 PM   #19
kslane
kslane's Avatar
Motorcycle(s): 2003 Ninja
Dont do that!! I agreee if it was diesel your bike would not run right.
My uncle would mix some Diesel in with gas once a year on his farm truck. IT ran like crap during this time but truck lasted him for years. I do not recall his reason for doing this
kslane is offline   Reply With Quote
Old August 29th, 2013, 05:20 PM   #20
Whiskey
Pop the tank open & have a good sniff, petrol & diesel smell different, if you smell diesel then you ****ed up, if you smell petrol all's good.
I've no idea of what E85 smells like, booze has an 'alcohol' smell, but the very pure stuff (<99.997% pure molecular biology grade EtOH) has a very weak odour. E85 should reek of booze, but I've not seen it anywhere, let alone used it.
Old August 29th, 2013, 05:49 PM   #21
BlueRaven
BlueRaven's Avatar
Motorcycle(s): '09 Ninja 250 Black
I'm not small, I'm fun sized
BlueRaven is offline   Reply With Quote
Old August 29th, 2013, 08:02 PM   #22
n4mwd
n4mwd's Avatar
It lubricates the valves and rings.
My Ninja Blog
Old August 31st, 2013, 04:59 PM   #23
MR2Aaron
Wouldn't you need to do that like, all the time for it to make any difference?
Old August 31st, 2013, 05:02 PM   #24
kslane
kslane's Avatar
Aww that explanes it, his farm truck ran forever and it was a FORD lol
Old August 31st, 2013, 05:26 PM   #25
GREY NINJA
Motorcycle(s): 2002 ninja 250
GREY NINJA is offline   Reply With Quote
Old August 31st, 2013, 05:40 PM   #26
n4mwd
n4mwd's Avatar
Probably. But people put kerosene in their cars all the time and kerosene is a kid brother to diesel. Kerosene aka injector cleaner.
My Ninja Blog
Old September 6th, 2013, 07:17 AM   #27
rabies
time is running out....
rabies's Avatar
Motorcycle(s): pregen ninjari
diesal and pump gas wont come from the same hose(law)
you most likely did flexfuel E85...and no it wont harm your bike...but it wont run on it. E85 is 105 octane.......put higher comp pistons in your bike and rejet and enjoy it
The King
rabies is offline   Reply With Quote
[crash.net - WSBK] - Camier to put new-spec engine through paces Ninjette Newsbot Motorcycling News 0 January 18th, 2013 05:00 AM
[crash.net - WSBK] - Camier will put new-spec engine through paces Ninjette Newsbot Motorcycling News 0 January 18th, 2013 04:40 AM
wd40 or diesel?? ryuusnow General Motorcycling Discussion 12 August 5th, 2011 05:39 AM
[visordown.com] - Diesel Moto Guzzi? Ninjette Newsbot Motorcycling News 0 February 7th, 2011 02:00 PM
[motorcycledaily.com] - Diesel Motorcycles Ninjette Newsbot Motorcycling News 0 July 9th, 2008 05:56 AM
