Old June 6th, 2013, 06:41 PM   #1
verboten1
verboten1's Avatar
MOTM - June '15
Spark plugs, they DO matter!
Nobody had the NGK plugs here and I needed new plugs to get the ninja on the road.
I picked up the equivalent Autolite plugs, and it finally started up and idled well and ran GREAT. 50 miles on back roads, not a single hiccup. The next day I did my 40 mile expressway commute, and a few miles into the trip, I started getting a miss and less power. By the time I got to the office, it would barely run!
Pulled the plugs and found both were white, and one of them had some pitting on the electrode, and the insulator. Today I put in the NGK plugs, ran the bike up to expressway speeds + and had no issues for 10 miles.
So, I'm just confirming the "use NGK plugs only" recommendation!
Ride more, worry less.
Old June 6th, 2013, 07:32 PM   #2
Running lean?
Old June 6th, 2013, 07:56 PM   #3
verboten1
verboten1's Avatar
MOTM - June '15
It seems fine, no real indications of it being lean, (As in how it runs) the plug was showing indications of possibly being too high of a heat range. Compared to the NGK the Autolite was a tiny bit longer, which could have been the issue.
The ninja 250 FAQ says to not to use anything but the NGK, because the others have been known to melt at expressway speeds. I got lucky
I will do a plug chop tomorrow to see how she looks though just to be sure
Old June 6th, 2013, 10:01 PM   #4
i melted a spark plug one time
Old June 8th, 2013, 08:51 AM   #5
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
Yeah please chop it. I use autolites ln my turbo car but only revs to 6000 and its done making power by then.
My Cafe Racer Build
My intro post
Old June 10th, 2013, 05:38 PM   #6
verboten1
verboten1's Avatar
MOTM - June '15
Sorry, haven't been out on the bike, but we will be doing some riding this weekend, I hope to do it then!
Old June 10th, 2013, 07:12 PM   #7
beren
beren's Avatar
http://faq.ninja250.org/wiki/Changin...rands_to_avoid
I wonder if the autolite have the same isue as the champions?
if so get them out asap.
Shhhhh, don't tell Jiggles I am using the [ you ] tag.
beren is offline   Reply With Quote
Old June 10th, 2013, 07:15 PM   #8
verboten1
verboten1's Avatar
MOTM - June '15
They are out, that's the reason for this thread.
After some highway miles, they started to disintegrate!
Which spark plugs? Runeknight95 2008 - 2012 Ninja 250R Tech Talk 2 July 23rd, 2013 09:13 PM
Removing spark spark plugs? tsdexter 2008 - 2012 Ninja 250R Tech Talk 3 June 26th, 2013 03:48 PM
spark plugs postie1686 2008 - 2012 Ninja 250R Tech Talk 7 June 7th, 2011 04:52 AM
Spark plugs? demp 2008 - 2012 Ninja 250R Tech Talk 4 May 20th, 2011 02:42 PM
What spark plugs... cbowman78 2008 - 2012 Ninja 250R Tech Talk 5 December 8th, 2010 06:36 AM
