Old April 28th, 2014, 04:27 PM   #1
RogerPapaMike
RogerPapaMike's Avatar
Motorcycle(s): 2007 250r
Downshifting woes
I am a new rider, and i suck at downshifting. yesterday while out riding i decided to practice. After being less than gentle with my clutch and transmission I came home. Later I came out and noticed an oil leak under my bike. Then today I started the bike and got it warmed up. I turned it off and no more leak. I went on another ride, practiced some more downshifting, and later i noticed the leak again. i have no idea what it is from. could it be a problem with my clutch?
RogerPapaMike is offline   Reply With Quote
Old April 28th, 2014, 04:31 PM   #2
Welcome Philip!
Did you just recently oil your chain? I ask because I have beat the crap outta my clutch without issues. But I did oil my chain and noticed some dripping from excess lube.
Last futzed with by csmith12; April 28th, 2014 at 07:00 PM.
Old April 28th, 2014, 04:48 PM   #3
RogerPapaMike
no, the chain hasn't been lubed recently. I went out and took some pics. as far as i can tell the leak is between and slightly above the kickstand and exhaust.
Old April 28th, 2014, 04:55 PM   #4
looks like chain fling
Old April 28th, 2014, 05:12 PM   #5
RogerPapaMike
i thought chain fling would leave a larger puddle (or more spread out) it just seems like it's coming form one area.
Old April 28th, 2014, 06:28 PM   #6
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
Get some engine degreaser from Walmart- $2, spray it good in there and wash it off. The leak looks pretty substantial. Hard to tell but may be from the front sprocket area maybe the output seal? Check your engine oil level first before riding it more.
My Cafe Racer Build
My intro post
Old April 29th, 2014, 07:51 AM   #7
jgcable
Motorcycle(s): 2003 Ninja 250r
Doesn't look like chain fling to me. Looks like a seal. Good advise here. Clean it completely with some engine degreaser and take it for a ride and check to see where its leaking. If its the seal behind the front sprocket its not that bad of a repair.
jgcable is offline   Reply With Quote
Old April 29th, 2014, 07:52 AM   #8
jgcable
Where in Connecticut are you, you crazy mad bastard!
Old April 29th, 2014, 08:19 AM   #9
crazymadbastard
I am in Ansonia, I see you are in MILF land.
My Cafe Racer Build
My intro post
Old April 29th, 2014, 12:31 PM   #10
quarterliter
Motorcycle(s): 2004 Ninja 250
Get some better tires Phil! Stock ones blow!
Old April 29th, 2014, 01:31 PM   #11
RogerPapaMike
i was planning on it i dont think the previos owner got any new ones in the last 7 years
I just keep taking it apart. I can't help myself!
Old April 29th, 2014, 01:41 PM   #12
Originally Posted by RogerPapaMike View Post
........Later I came out and noticed an oil leak under my bike. Then today I started the bike and got it warmed up. I turned it off and no more leak. .........and later i noticed the leak again. i have no idea what it is from. could it be a problem with my clutch?
Could it be that you have put too much oil in your engine while the bike was on the side-stand?
The level of oil should be around half and top of the glass visor by the right side, when the bike is perfectly vertical and supported on both tires.
Check if it is coming from the crankcase's breather by the carbs.
Poor downshifting, oil leaks and clutch are all non-related.
Old April 29th, 2014, 02:39 PM   #13
RogerPapaMike
what is the breather?
Old April 29th, 2014, 02:53 PM   #14
It is normally connected to the airbox:
Old April 30th, 2014, 10:20 AM   #15
quarterliter
Get some pirelli's either the Diablo scooter, MT75, or Sport Demon. Can't go wrong with any of them.
Downshifting Probs indr 2008 - 2012 Ninja 250R Tech Talk 15 June 30th, 2013 09:43 AM
Downshifting for turns dcx4610 Riding Skills 106 October 24th, 2012 01:31 PM
Downshifting akshay11 Riding Skills 17 March 18th, 2012 02:52 PM
Downshifting for a right turn. clintalmighty Riding Skills 21 January 20th, 2011 11:27 AM
proper downshifting? heylookitsfranco Riding Skills 23 October 31st, 2010 06:31 PM
