Old December 12th, 2012, 01:41 PM   #1
thisisbenji
thisisbenji's Avatar
Motorcycle(s): 2009 Ninja 250r (Sold), 2009 FZ6, 2015 Honda Grom
Oil Leak
You guys think I just need a new plug? I'v already made sure it's tight.
My Old Bike
My New Bike
thisisbenji is offline   Reply With Quote
Old December 12th, 2012, 01:50 PM   #2
Hard to tell.... Try new crush washers first.
Old December 12th, 2012, 01:55 PM   #3
thisisbenji
Do you know if there's a specific one to use?
My Old Bike
My New Bike
Old December 12th, 2012, 02:33 PM   #4
this video is useless... can't see anything
from what i gather, its leaking from the drain plug... is there something wrong with the drain plug? did you just do an oil change? it just started leaking on its own?
maybe put it up on a stand and take photos where you can actually see the thing you're taking a photo of... maybe like with a light or something.
Old December 12th, 2012, 02:37 PM   #5
thisisbenji
It started shortly after an oil change. So I'm hoping it's the plug, I think I might just add a little oil to keep it filled and put a new plug in it when I change the oil.
My Old Bike
My New Bike
Old December 12th, 2012, 03:17 PM   #6
loz944
loz944's Avatar
Motorcycle(s): Green 2012 Ninja 250SE and a Yamaha fino scooter (my wife's really)
When you changed the oil did you replace the crush washer they should be changed every time
Be safe ride smart .....a dumb rider is a dead rider
loz944 is offline   Reply With Quote
Old December 12th, 2012, 03:29 PM   #7
lgk
whens the last time you changed the crush washer?
did you use a torque wrench to install the plug?
Old December 12th, 2012, 05:04 PM   #8
DaBlue1
DaBlue1's Avatar
Originally Posted by thisisbenji View Post
.... I'v already made sure it's tight.
If it is torqued correctly, just make sure you verify that the oil filter cover as well as the drain threads are not stripped or cracked. There have been cases of both.
http://www.ninjette.org/forums/showp...89&postcount=5
http://www.newninja.com/forums/f97/d...ange-5267.html
Old December 12th, 2012, 06:35 PM   #9
thisisbenji
I didn't use a torque wrench when I changed the oil I also put a new crash washer on. When I checked after I noticed it leaking I tried tightening it with a torque wrench. I guess I'll just buy a new crush washer and check that again.
Can I just drain the oil out and check an then reuse the oil I drained out?
My Old Bike
My New Bike
Old December 12th, 2012, 06:57 PM   #10
DaBlue1
DaBlue1's Avatar
....Can I just drain the oil out and check an then reuse the oil I drained out?
You can drain the oil and reuse it it, but if you've got a cracked or stripped oil drain make sure there are no pieces of metal in it.
Old December 12th, 2012, 06:59 PM   #11
94fiveohvert
Motorcycle(s): ninja 250r, crf 50
maybe it's just me, doesn't look seated properly.. like it's cross threaded. Can you take a picture of it with flash?
94fiveohvert is offline   Reply With Quote
Oil leak.... skilletmo 2008 - 2012 Ninja 250R Tech Talk 13 October 24th, 2014 09:31 PM
Oil leak Xaero 1986 - 2007 Ninja 250R Tech Talk 11 November 16th, 2013 06:58 PM
Oil Leak? Fakker 1986 - 2007 Ninja 250R Tech Talk 5 September 6th, 2013 06:38 AM
possible oil leak? Monkeytofu 1986 - 2007 Ninja 250R Tech Talk 17 August 21st, 2012 01:35 PM
Oil Leak Help sjc88 1986 - 2007 Ninja 250R Tech Talk 7 December 29th, 2011 04:13 PM
