Old March 26th, 2015, 08:04 AM   #6521
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
Originally Posted by Kruse08 View Post
It does not, it was on link short even with the master link. Ubless it was because i did not move the wheel up to meet the chain. Well a new longer chain has been ordered so we will see what happens.
So when you get this longer chain do you plan to not move the wheel back to meet the chain this time ether? You don't need a 108 chain to fit a 15t sprocket and any time you change sprockets or chains you'll need to move the wheel to adjust the chain slack, it's a must. Since you've already ordered a 108 then go ahead and use it, both options work fine. Id suggest dropping the rear a few teeth to a 43 because 15-45 still feels way to high in the rpms at hwy speeds. I run 15-41 setup on my bike and I like it a lot but that's just my opinion.
Old March 26th, 2015, 08:14 AM   #6522
cuong-nutz
cuong-nutz's Avatar
Redoing my HID RETROFIT. It doesn't look like I have much left of the Chinese 7" round. I need to reform the headlight lens to clear the projector lens. I have the hid housing as far back in the reflector as I possibly can and will have to cut out the rear headlight housing. Hope I have enough room back there.
HalfFast Racing Team
Old March 26th, 2015, 08:25 AM   #6523
DEFY
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
DEFY's Avatar
double toning my windscreen, black on outside white on inside.
Old March 26th, 2015, 05:02 PM   #6524
Kruse08
Kruse08's Avatar
Motorcycle(s): 99 Ninja 250
The chain is on and with 108 links. Having the 15t front sprocket requires having one more link on the chain. I also could not move the wheel closer to the swingarm as I have 90 series sidewall tires. No room to run a short chain. Maybe some people have had luck running the stock 106 chain but it did not work for me. Not trying to argue with anyone.
Everything you’ve ever wanted is on the other side of fear. –George Addair
Kruse08 is offline   Reply With Quote
Old March 26th, 2015, 05:48 PM   #6525
Definitely can run 106 links with 15/45 gearing and a 90 series tire.
The 90 tire has no problems going to either extreme of the adjustment range in my experience. And 15/45 works fine with 106 links. So I don't have direct experience with that combination of tire size and gearing, but they're independent variables.
Old March 27th, 2015, 08:53 AM   #6526
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
Worked on some wires.
Old March 27th, 2015, 02:47 PM   #6527
cuong-nutz
cuong-nutz's Avatar
Now I got to make longer headlight brackets to clear it.
Old March 27th, 2015, 06:30 PM   #6528
LittleRedNinjette
Certified Troublemaker
LittleRedNinjette's Avatar
*yesterday*
Got the wheels on and the balance beads in so the the bike is ready to rock!
Raven's Rejuvenation
Old March 27th, 2015, 07:30 PM   #6529
cuong-nutz
cuong-nutz's Avatar
Originally Posted by LittleRedNinjette View Post
*yesterday*
What are the benefits? How much do you need?
Old March 27th, 2015, 07:33 PM   #6530
Ghostt
Ghostt's Avatar
Read,
http://www.innovativebalancing.com/index.php
violente et ignorantia
ZX-2R BLOG
Old March 27th, 2015, 07:56 PM   #6531
LittleRedNinjette
it varies by tire size. check with the bead manufacturer. think I have 2oz in the front and 3 in the back but I have to check...
Old March 27th, 2015, 09:45 PM   #6532
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
Trying to find some universal plugs so I can wire up my tail and head light properly, like OEM style. Auto parts stores? Walmart?
Old March 27th, 2015, 11:11 PM   #6533
EternalNewb
EternalNewb's Avatar
Motorcycle(s): 2012 Ninja 250R, 2007 Ninja 650R, 2001 F650 Dakar
New rear tire, because the old one was killed by too many commuter miles.
EternalNewb is offline   Reply With Quote
Old March 28th, 2015, 12:45 AM   #6534
corksil
Motorcycle(s): A lot.
Thanks for the reminder. I need to change mine out.
Just batshit crazy. All his posts are endless diatribes. Some are actually entertaining but mostly batshit crazy.
Old March 28th, 2015, 07:20 AM   #6535
cuong-nutz
cuong-nutz's Avatar
Radio Shack, Fry's, or any major electronics store, You may get lucky at the autoparts store too.
Old March 28th, 2015, 12:21 PM   #6536
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
Couldn't find anything anywhere all the RadioShack are closed too).
Old March 29th, 2015, 09:53 PM   #6537
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Went on a ride with my Mom, stepdad, and friends.
Saw two Bing street view cars (or the same one twice) and am now going to be glued to their maps waiting for the updates!!!
<-- Linky
Old March 29th, 2015, 10:17 PM   #6538
Ghostt
Ghostt's Avatar
1oz=front, 2oz=rear per Dynabeads chart, is what I have in both Ninjette and EX500
http://innovativebalancing.com/mobil...pec.php?moto=1
ZX-2R BLOG
Old March 30th, 2015, 04:47 AM   #6539
LittleRedNinjette
I don't have dynabeads but this it what I put in. I was thinking my boyfriends bike.
Old March 30th, 2015, 05:40 AM   #6540
ryker
chaos theory
ryker's Avatar
Motorcycle(s): 2012 Ninja 250r SE ; 2007 ZZR600
New Michelin front tire mounted. What a beauty!
ryker is offline   Reply With Quote
Old March 30th, 2015, 01:16 PM   #6541
Road Dawg1
Motorcycle(s): 04 Ninja 250
Rode her for a quick trip to the grocery store.
She runs well after sitting up over the winter and I find myself much more confident than last year when I started riding.
Road Dawg1 is offline   Reply With Quote
Old March 30th, 2015, 01:27 PM   #6542
Ghostt
Ghostt's Avatar
I have Dynabeads in the EX and CBC in the Ninjette
ZX-2R BLOG
Old March 30th, 2015, 06:05 PM   #6543
gantt
gantt's Avatar
Motorcycle(s): 2019 Ninja 400, Sold 2012 Ninja 650, Sold 2009 Ninja 250r, Sold 2007 DRZ400s
I gets stickers today!! Not sure about the size. Left a pack of cigs in view for size reference. Wanted to put them on the tail, but at first glance they look too big. Might contact the seller and see if he can size down 20% smaller of so.
gantt is offline   Reply With Quote
Old March 31st, 2015, 01:22 AM   #6544
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
I adjusted the valve clearance in my klx140l.
Old March 31st, 2015, 04:40 PM   #6545
gantt
gantt's Avatar
Too big???? Maybe its because its different, but it almost looks too big. What are your opinions?
Old March 31st, 2015, 04:44 PM   #6546
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
Looks fine, put the seat on to realy see what's up.
My Cafe Racer Build
My intro post
Old March 31st, 2015, 05:08 PM   #6547
gantt
gantt's Avatar
Its all tossed on but you get the idea. It kinda overpowers the Kawasaki decal on the tank. Might see if a local person can match it up and size it down
Last futzed with by gantt; March 31st, 2015 at 06:52 PM. Reason: spelling
Old March 31st, 2015, 06:20 PM   #6548
cuong-nutz
cuong-nutz's Avatar
Ats all tossed on but you get the idea. It kinda overpowers the Kawasaki decal on the tank. Might see if a local person can match it up and size it down
Yeah, it looks too big.
That exhaust so sexy.
Old March 31st, 2015, 06:50 PM   #6549
gantt
gantt's Avatar
Yeah, I will scale it down soon. I haven't heard the exhaust yet, but it looks soo good!!!
Old March 31st, 2015, 07:19 PM   #6550
crazymadbastard
Meh you ruined the bike. Give it to me.
i still think looks fine.
My Cafe Racer Build
My intro post
Old March 31st, 2015, 07:30 PM   #6551
Ghostt
Ghostt's Avatar
@gantt
that tank graphics are under the clear coat, to change those are going to be a bit of a PITA
Another option is to have ones made to match the scale.
Try contacting eBay seller 69CAM, He did mine, and even in reflective silver.
Or try contacting yellowdoggraphics.com, they also made my SERENITY graphics as well, and go custom orders.
https://picasaweb.google.com/1006527...Iz7pKC8lo6CiAE
https://www.ninjette.org/forums/blog.php?b=8341
https://www.ninjette.org/forums/blog.php?b=8347
ZX-2R BLOG
Old March 31st, 2015, 08:04 PM   #6552
gantt
gantt's Avatar
Yeah, I didn't mean change the kawi decal
Old April 1st, 2015, 08:44 AM   #6553
Ghostt
Ghostt's Avatar
Okay, personally I think it looks good.
ZX-2R BLOG
Old April 1st, 2015, 11:23 AM   #6554
gantt
gantt's Avatar
[QUOTE=Ghostt;1000253]Okay, personally I think it looks good.[/QUOTE im just going to rock it for a while. should be able to get a set of tires for it very soon. I hate looking at the bike every day and not riding it. I brought the ninja650 out last week for the season. it helped ease the pain, but the 250 is what im looking forwards to riding! I wouldn't mind it being smaller, but its growing on me like it is. thanks for your input
Old April 1st, 2015, 01:37 PM   #6555
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
Got my klx finally started. However, valves are clacking, so I need to go back and check my clearances.
Old April 2nd, 2015, 04:14 PM   #6556
ryker
chaos theory
ryker's Avatar
I added shorty clutch/brake levers today and black screws for the windscreen.
Old April 4th, 2015, 12:29 PM   #6557
allanoue
allanoue's Avatar
MOTM - Sep '14
spools
lifting with rear stand is so much smoother
Old April 4th, 2015, 07:01 PM   #6558
gantt
gantt's Avatar
Flushed and filled the coolant. Threw the tail farings and tank on. Tossed on the seat and blasted through the neighborhood. I love this exhaust! With clean carbs, exhaust and jet kit, this bike feels so much better! Still need to sync the carbs and tidy up a few things. This bike wants to turn! With the gsxr shock it feels much better. Now it makes the front feel like doo doo. Raised the rear 1.5 inch's as well. I will have to get used to the bike again. Its definitely different than it was 10 months ago when I stopped riding it.
Old April 4th, 2015, 07:18 PM   #6559
cuong-nutz
cuong-nutz's Avatar
I found a local HID retrofit supplier!
Old April 5th, 2015, 05:48 AM   #6560
LittleRedNinjette
Got out for a nice long, albeit windy, ride yesterday.
Discovered something scary about my Ninjette today... kjohng General Motorcycling Discussion 28 October 15th, 2021 01:40 PM
Sold the 2006 Ninjette today :( Renner General Motorcycling Discussion 31 October 16th, 2014 11:46 PM
Today I Gave My Ninjette Wings! BlueHairSar Pictures 5 June 20th, 2013 07:38 AM
my bro went down today on his ninjette richierich781 !%@*#$%!)@#&!%@ I crashed! 46 January 18th, 2013 11:59 AM
Ninjette. org hacked today CC Cowboy Off-Topic 9 April 3rd, 2011 08:55 AM
