Old August 16th, 2020, 07:09 AM   #1
Badapplesrepair
Motorcycle(s): 2008 Ninja 250
Post Greetings from Florida
Just got a 2009 ninja 250 a couple of months ago. I have mechanical knowledge as I did a 4year A&P course in high school. I never went to work in aviation but have rebuilt multiple car engines over the past 15 years, I also work with electronics so I feel like i am more than capable of rebuilding this bike. So this bike was purchased in running condition by my brother about 2 years ago, however it was full of ugly stickers ran like crap and had random bits and pieces missing from all over the place. It barely turned on but it ran pretty good considering conditions, fairings kept flying off while driving so bike had about half the fairings missing the rest where all in pretty rough shape. so bike was stolen and ditched a few blocks away probably after thieves realized they stole a pile of junk. It was found two days later a new ignition was purchased but bike never turned back on. I got the bike from him for about $500 and started reading around. This site truly has a ton of invaluable information which I am using in my journey to rebuilding, I have taken the bike apart and short of disassembling the entire engine I知 replacing all exterior seals (has huge oil leak) checking condition of parts and doing a few things here and there to make the bike sportier, I understand the limitations of the bike so I am not here expecting to make this into a super sport but if i can improve on some of its weaknesses why not if the bike is apart anyways right? Anyways I値l attach a picture of this mess.
File Type: jpg 0C4397A9-F25B-4C1D-9E87-1FE458BBEAD3.jpg (143.3 KB, 1 views)
Badapplesrepair is offline   Reply With Quote
Old August 16th, 2020, 07:31 AM   #2
LittleRedNinjette
Certified Troublemaker
LittleRedNinjette's Avatar
Badapplesrepair! Glad to have you aboard...
Raven's Rejuvenation
Old August 17th, 2020, 09:57 AM   #3
Hi Carlos and welcome to Ninjette!
Don’t forget about 100-ohm resistor in ignition-switch. Not present in aftermaket ignitions and prevents bike from starting.
Also send carbs to ducatiman and bike will run like brand-new! Do search for “clean carbs ducatiman” for photos of what’s involved in restoring carbs to factory-fresh condition.
Last futzed with by DannoXYZ; August 20th, 2020 at 11:18 PM.
Old August 17th, 2020, 05:20 PM   #4
ducatiman
ducatiman's Avatar
ty for kind words @DannoXYZ
wanted to offer suggestion to badapple...prioritize...to get engine running tiptop first and foremost before spending time/effort on further mods.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old August 17th, 2020, 05:31 PM   #5
Ceeloo Yello
Motorcycle(s): 250
Welcome
Old August 18th, 2020, 06:07 PM   #6
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Welcome
Old August 19th, 2020, 05:25 PM   #7
Badapplesrepair
Thanks everyone, @DannoXYZ thanks for the tip, I didn稚 know about that. I figured I would tackle electronics when I was done with the mechanical side of things. I see allot of badly spliced wires and corroded connectors. I see grounds that are barely attached and other things. My plan was to go through every circuit one by one checking and replacing all connectors And testing and cleaning sensors and such. My job consists of diagnosing and repairing failing, failed and catastrophically damaged complex electrical circuits. Even with all my experience I知 sure you saved me a head scratcher and needless time diagnosing a circuit I知 not too familiar with. I bought this because I enjoy fixing things, I love engines and tearing things apart, I had the carburetor completely in pieces the week after I bought it. I sit on my balcony smoke cigars and work on the bike, I知 already getting a ton of joy from this bike and I haven稚 gotten to ride it yet. That being said @ducatiman, I see your name allot. I have allot of respect for your work I知 sure you have mad skills, if I get overwhelmed I know you are the guy to turn to. it痴 been my plan from the start to get the bike running then I知 going to jet the carbs, I値l pull them a few times until I get everything running right. I知 replacing the cracked rusting muffler with one of those knockoffs for 50 on eBay. If the muffler is really that bad I値l look into something more expensive. I致e already budgeted enough on the bike, its going to be almost 1500 in total. I知 not trying to go too far Over that. I知 also removing the damaged airbox And replacing with some pod filters. I figure I値l have to pull the carbs several times in order to get it all running right but I知 prepared to do that. I知 draining and cleaning the tank and petcock. I知 replacing all fuel hoses, silicone hose kit for cooling system, new radiator, new chain and sprockets, new carb and throttle cables, new grips and assemblies for throttle and such, new disks and pads, steel braided brake lines, and a couple of other mostly cosmetic items like fairings. With the amount of information on this site alone I知 confident I can tackle this whole project.
Old August 19th, 2020, 05:33 PM   #8
Badapplesrepair
Thanks to everyone for the warm welcome, @DannoXYZ thanks for the tip, I didn稚 know about that. I figured I would tackle electronics when I was done with the mechanical side of things. I see allot of badly spliced wires and corroded connectors. I see grounds that are barely attached and other things. My plan was to go through every circuit one by one checking and replacing all connectors And testing and cleaning sensors and such. My job consists of diagnosing and repairing failing, failed and catastrophically damaged complex electrical circuits. Even with all my experience I知 sure you saved me a head scratcher and needless time diagnosing a circuit I知 not too familiar with. I bought this because I enjoy fixing things, I love engines and tearing things apart, I had the carburetor completely in pieces the week after I bought it. I sit on my balcony smoke cigars and work on the bike, I知 already getting a ton of joy from this bike and I haven稚 gotten to ride it yet. That being said @ducatiman, I see your name allot. I have allot of respect for your work I知 sure you have mad skills, if I get overwhelmed I know you are the guy to turn to. it痴 been my plan from the start to get the bike running then I知 going to jet the carbs, I値l pull them a few times until I get everything running right. I知 replacing the cracked rusting muffler with one of those knockoffs for 50 on eBay. If the muffler is really that bad I値l look into something more expensive. I致e already budgeted enough on the bike, its going to be almost 1500 in total. I知 not trying to go too far Over that. I知 also removing the damaged airbox And replacing with some pod filters. I figure I値l have to pull the carbs several times in order to get it all running right but I知 prepared to do that. I知 draining and cleaning the tank and petcock. I知 replacing all fuel hoses, silicone hose kit for cooling system, new radiator, new chain and sprockets, new carb and throttle cables, new grips and assemblies for throttle and such, new disks and pads, steel braided brake lines, and a couple of other mostly cosmetic items like fairings. With the amount of information on this site alone I知 confident I can tackle this whole project.
Old August 20th, 2020, 10:22 AM   #9
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Welcome!
Old August 24th, 2020, 10:48 AM   #10
Welcome!
Old August 24th, 2020, 01:54 PM   #11
Here's good supplier for electrical connectors. I think they have replacements for everything on bike. https://www.corsa-technic.com/
I wouldn't use silicone hose for coolant though. Coolant will "steam" itself through and you'll loose half your coolant within a week! It's really only good for intake-plumbing.
Old November 15th, 2020, 08:42 AM   #12
Snake
Snake's Avatar
I’m a little late but ....hello and welcome !
New in Florida with a '96! Jahjahwarrior New Members 12 June 19th, 2015 07:53 PM
[roadracingworld.com] - CCS Florida Racing In West Palm Beach, Florida This Coming We Ninjette Newsbot Motorcycling News 0 October 3rd, 2013 10:10 AM
[roadracingworld.com] - CCS Florida Racing This Coming Weekend In Jupiter, Florida Ninjette Newsbot Motorcycling News 0 July 24th, 2013 10:20 AM
[topix.net] - Florida's Turnpike: South Florida drivers will do a lot to beat tolls | Ninjette Newsbot Motorcycling News 0 June 23rd, 2011 07:10 PM
Except where otherwise noted, all site contents are ゥ Copyright 2022 ninjette.org, All rights reserved.
