Go Back   ninjette.org > General > Off-Topic
Old February 20th, 2015, 06:59 AM   #1
swarfman64
Master modder
swarfman64's Avatar
Motorcycle(s): TURBO gpx250 99 CB250/500rs Sherco290 Trials Indian 1911big base (replica)
Dyno build
I must be crazy, another project!
For those interested keep your eye on my blog for a motorcycle dyno build.
http://swarfman64.blogspot.com.au/20...rtia-dyno.html
This one won't go as fast as the turbo gpx build but I will try to keep it rolling.
Most if not all will be built at work so actual paying jobs will hinder its progress and I'm limited in after hours time (that family/life thing).
Basically I'm building an inertia dyno with Performance trends logging. I've got almost everything gathered and time is really the only limiting factor.
[B]Come and see my turbo ninja build, dyno build and other stuff at http://swarfman64.blogspot.com.au/20...rtia-dyno.html
swarfman64 is offline   Reply With Quote
Old February 20th, 2015, 11:22 AM   #2
Old February 20th, 2015, 11:39 AM   #3
cuong-nutz
cuong-nutz's Avatar
What's a roundabout cost? I have tossed the idea around
HalfFast Racing Team
Old February 20th, 2015, 02:01 PM   #4
swarfman64
Master modder
swarfman64's Avatar
1000 for logger, 1200 steel (hollow bar was 800 bucks alone) another 1000 for bearings,computer, paint etc etc, I'm thinking 3000 to 4000 doing everything myself. It will add up if you have to pay someone to build the roller. There's probibly 2000 in machining that alone. All Aussie dollars.
dyno session is about 350 buck here, so by the time I've tuned my bike (about 10 tunes) and I've covered the cost
Last futzed with by swarfman64; February 20th, 2015 at 02:43 PM. Reason: i'm a tool
Old February 20th, 2015, 04:22 PM   #5
Originally Posted by swarfman64 View Post
............. Basically I'm building an inertia dyno with Performance trends logging............
Copied from
http://en.wikipedia.org/wiki/Dynamometer
"An 'inertia' dynamometer provides a fixed inertial mass load, calculates the power required to accelerate that fixed and known mass, and uses a computer to record RPM and acceleration rate to calculate torque. The engine is generally tested from somewhat above idle to its maximum RPM and the output is measured and plotted on a graph."
Does that mean that the equipment will only measure power output during acceleration?
Old February 20th, 2015, 05:21 PM   #6
swarfman64
Master modder
swarfman64's Avatar
Originally Posted by Motofool View Post
Copied from
Correct, it does not have an rpm hold feature. A typical run depending on dyno design and engine HP will be 6-10 seconds. There are advantages and disadvantages to both types. In reality an inertia dyno will do everything I want and the cost and setup is a fraction of a braked dyno. Also calibration is easy, you only need to know the moment of inertia of the rotating mass and rpm.
Old February 20th, 2015, 05:27 PM   #7
Very interesting!
I have never seen one of that type.
Thanks
Old February 22nd, 2015, 07:08 PM   #8
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Old February 22nd, 2015, 07:47 PM   #9
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
Andrew again a good plan and project from you but may I ask if you plan the usage of a 'CO-Gas Analyzer' also?
Old February 22nd, 2015, 08:52 PM   #10
swarfman64
Master modder
swarfman64's Avatar
Not at this stage, just a wide band through the logger. As time, need and money show themselves I will option it with some good accessories. For now I'll get away with the basics.
Old February 26th, 2015, 11:28 PM   #11
swarfman64
Master modder
swarfman64's Avatar
A little update is posted on the blog. I spent some time today building the chassis.
Last futzed with by swarfman64; February 28th, 2015 at 05:59 PM. Reason: always a tool
Old March 1st, 2015, 01:49 AM   #12
swarfman64
Master modder
swarfman64's Avatar
Lazy Sunday making some swarf
More on the blog
Last futzed with by swarfman64; March 1st, 2015 at 01:50 AM. Reason: I'm a forgetful tool
Old March 1st, 2015, 05:59 AM   #13
garth285
KAWASAKI GURU
garth285's Avatar
Your a dick, go away........
Seriously that is badass!!!! I fortunately have a dynojet dyno I can use but its at my buddys shop, would be nice to have one in the back yard!
Old March 3rd, 2015, 12:04 AM   #14
swarfman64
Master modder
swarfman64's Avatar
This dyno isn't doing work productivity any good. Oh well.
IMG_4318.jpg Roller is assembled,260kg, almost 12kg/m2 inertia, 600Hp capable, should just be big enough for tha turbo ninja.
Old March 5th, 2015, 02:54 AM   #15
swarfman64
Master modder
swarfman64's Avatar
Old March 12th, 2015, 04:22 AM   #16
swarfman64
Master modder
swarfman64's Avatar
Its all here on the blog http://swarfman64.blogspot.com.au/20...rtia-dyno.html
Old March 12th, 2015, 04:43 AM   #17
Somchai
Freedom for Germany
Fantastic
Old March 14th, 2015, 06:18 PM   #18
swarfman64
Master modder
swarfman64's Avatar
Old March 14th, 2015, 06:20 PM   #19
garth285
KAWASAKI GURU
garth285's Avatar
I hate you so much.....
Hey I just bought my first lathe the other day! Maybe someday I'll catch up to you with tools!
Old March 14th, 2015, 06:29 PM   #20
swarfman64
Master modder
swarfman64's Avatar
I spend everything I can on income producing assets from hand tools to big machinery, Once the cycle starts it just keeps growing.
Old April 1st, 2015, 03:35 AM   #21
swarfman64
Master modder
swarfman64's Avatar
A little more progress, Work is keeping me busy but I'm getting there slowly.
I'm at the point in the turbo 250 where the dyno is needed, see what Easter brings
As always, more here....http://swarfman64.blogspot.com.au/20...rtia-dyno.html
Old April 1st, 2015, 04:40 AM   #22
Somchai
Freedom for Germany
I don't say nothing no more before the dyno is completed, I'm speechless...
Old May 29th, 2015, 03:15 AM   #23
swarfman64
Master modder
swarfman64's Avatar
Another update. I found a little time in a hectic life to begin the data logger installation. I'm waiting on a few cables but should have the wiring complete in a week or so. There's a UPS in a drawer and a dock to take the laptop. I have a portable two plane dynamic balancer on its way from Europe which I can use to can check the roller balance in situ.
The banners are made and off to the signwriter, they are fastened at the top but clipped on the bottom to give good access when strapping. That will leave only the brake disk and master cylinder (for slowing down between runs) to do.IMG_4732.jpgIMG_4736.jpgIMG_4731.jpg
Old May 29th, 2015, 07:58 AM   #24
Damn yo... that's hot.
Old May 29th, 2015, 08:03 AM   #25
DEFY
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
DEFY's Avatar
Spoiler for topic:
It might just be the [you] tag
Old May 29th, 2015, 08:33 AM   #26
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
Impressive! wish you were close by to break that bad boy with my 12ft/lb of torque!
I actually brag about my 144 inch lbs
My Cafe Racer Build
My intro post
Old July 25th, 2015, 03:40 AM   #27
swarfman64
Master modder
swarfman64's Avatar
I'm back. well not really....As you get older "stuff" gets in the way of a good project. The turbo is on hold until the dyno is buit and the dyno's on hold till the balancer is built and its all gotta happen in between Kids, work etc etc money permitting. So, what I have managed to do is build the dynamic balancer for the dyno inertia roller.[ATTACH]IMG_5124.jpg[/ATTACH] I still have the electronics to sort out but the mechanics is done. I've built it so it can be used at work for other things like spindles and shafts (my excuse/justification to build it). The dyno is 100% complete now with the brake fitted and the wiring finished, I've even fired the computer and the two screens up. The roller balancing is the last thing to do. Its all here if your interested. http://swarfman64.blogspot.com.au/20...-balancer.html
Old July 25th, 2015, 11:30 AM   #28
might want to have a top half bearing that can close over your shaft. Just saying, you don't want to see what happens when that shaft hops off of your balancer at speed.
Our balance machine at work has top half bearings that clamp over your shaft. It's also got a brick wall built around it... Just in case. Then again, we balance impeller/shaft combos that weigh upwards of 100 lbs at anywhere from 300-5000 rpm soooooo... Idk what your setup weighs that's being balanced but if you're going to use this thing at work, I'd hazzard a guess that OSHA rules about machine guards and safety measures should be followed.
Old July 25th, 2015, 12:55 PM   #29
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Not gonna use Dynabeads to balance it?
(kidding, of course...)
Old July 25th, 2015, 04:12 PM   #30
swarfman64
Master modder
swarfman64's Avatar
yer, I have the top safety hoops fitted, the photos were taken befor I fitted it.
Your rite, there limb smashing/wall removing energy in this thing.
Old September 3rd, 2015, 04:16 AM   #31
swarfman64
Master modder
swarfman64's Avatar
Dyno up and running. pics and video soon
First test to 150kph with my 500cc café racer strapped on, no vibrations and good clean data
Last futzed with by swarfman64; September 3rd, 2015 at 04:18 AM. Reason: i forgot stuff
Old September 3rd, 2015, 05:06 AM   #32
Somchai
Freedom for Germany
Hey Andrew, nice to see you back again and congrats for your running dyno
Old January 2nd, 2016, 04:19 AM   #33
swarfman64
Master modder
swarfman64's Avatar
I had forgotten about this thread, oops.
Here's a couple of pics for you. I'm trying to get some video over the next week.
Cheers
Want: dyno runs alex.s Items Wanted 22 February 27th, 2015 11:27 AM
Going to the Dyno.... headshrink General Motorcycling Discussion 5 April 2nd, 2011 06:00 PM
Some Time On The Dyno HKr1 General Motorcycling Discussion 5 December 26th, 2010 04:52 PM
To dyno or not to dyno OldGuy 2008 - 2012 Ninja 250R Tech Talk 13 May 17th, 2009 06:02 PM
Dyno stroked59 General Motorcycling Discussion 0 January 8th, 2009 08:20 PM
