Old June 14th, 2013, 08:34 PM   #1
IHateMountingTires
Motorcycle(s): 2009 Ninja 250
Did I just mess up my new tire?
Hey guys. I've been a long time lurker...long story short, I decided to mount/balance my own tires since a local shop was going to charge me $100 just to mount/balance my tires, even though I had already taken the wheels off the bike.
Anyways I followed the wiki and managed to mount the front tire ok but when it came to the rear tire i couldn't do it, I had about 1/4 of the second bead to put over the rim and I was done, but the mother****er kept coming off no matter how much weight I put on it trying to keep it down. So I decided to heat up the tire with a heat gun. I heated it up enough I thought and it wasn't that hot to the touch (I could keep my finger on it as long as I wanted to) and BAM, this happend when I used the tire iron to try and get it over.
Is my tire done for?
IHateMountingTires is offline   Reply With Quote
Old June 14th, 2013, 08:39 PM   #2
Relevant username. I'm not sure that tire's still usable at this point, whether the bead will seat or if it will stay airtight once seated. The hints are to use as much tire soap/lube as you need. Heat guns aren't part of the equation.
Old June 14th, 2013, 08:41 PM   #3
Welcome!
Oh dear, my gut tells me your ok but my brain is telling me otherwise. Not sure which to trust. Hoping someone will chime in for you with experience in this area.
Old June 14th, 2013, 08:49 PM   #4
Asspire
Fix It Till Ya Break It
Asspire's Avatar
Motorcycle(s): 08 250RRrrrr
take a pic of inside the rip for us. if you can see the cords (looks kinda white) you fubar'ed the tire. if its just rubber then you might be ok as there's a little bit of extra rubber before you hit the bead. Always use lube when mounting, NEVER use motor oil or the likes as lube. If your doing it your self, leave the tire outside on your drive way in the sun for a bit, easiest way to soften it up.
Old June 14th, 2013, 09:03 PM   #5
IHateMountingTires
I used a lot more on the rear than I did on the front :/
Welcome!
Thanks but I think I just found out my answer...
I guess this answers the questions. I'm ****ed. Is there any way that they would take this tire back? I can't believe I would have saved money had I just paid the damn $100
Old June 14th, 2013, 09:11 PM   #6
Asspire
Asspire's Avatar
Old June 14th, 2013, 10:09 PM   #7
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
Take the $100 you would have saved and make one of these.
http://www.ninjette.org/forums/showthread.php?t=121625
If it were me I mount it and see if it held an exact pressure for a hour, if it did then go for a short ride and check again. If it's still good then go for a longer ride and repeat. If my tire went flat on me I'm confident enough in my skills to not crash so I'd test it, if your not so confident then go with a new tire.
Old June 14th, 2013, 10:55 PM   #8
cuong-nutz
cuong-nutz's Avatar
This. Maybe slap on some rubber cement?
HalfFast Racing Team
Old June 15th, 2013, 05:50 AM   #9
Reyno2ac
Reyno2ac's Avatar
Motorcycle(s): Red 2009 Ninja 650r
At the very least throw it on and do a burnout...
Reyno2ac is offline   Reply With Quote
Old June 15th, 2013, 06:16 AM   #10
Welcome to our site, T !!!
That is a painful picture.
You hate mounting tires, because you don't know how to do it properly; it doesn't really requires that brute force or any heating.
Read this:
http://www.dansmc.com/tires1.htm
That tire is not tubeless anymore, because the seal is not repairable.
Don't discard it, maybe somebody could use it with an inner tube for non-sport riding.
Micro Fiber mess eddiekay General Motorcycling Discussion 15 September 22nd, 2014 09:12 PM
Did I mess up my clutch? Insane Pie 2008 - 2012 Ninja 250R Tech Talk 4 April 25th, 2014 05:07 AM
Don't mess with Danica CC Cowboy Off-Topic 10 December 9th, 2013 06:53 PM
Cars can mess up brains !!! Motofool General Motorcycling Discussion 4 April 9th, 2013 06:09 PM
Don't mess with cagers!!! Z300 Videos 122 December 26th, 2012 12:46 PM
