Old July 7th, 2013, 01:31 PM   #1
BoKing
Dropped bike at low MPH, drained float bowls, still won't start.
About a year ago I had a similar problem and this helped me resolve it:
http://faq.ninja250.org/wiki/How_to_...he_float_bowls
2 nights ago I was coming home in the rain, turned the corner into my driveway and hit a sediment deposit. I must have been going less than 2 or 3 mph, was a light drop. When I pulled it up and tried to start it, I felt it having trouble trying to start (as happened a year prior, so I knew what it was).
I stripped the fairings/plastics off the front for good because they were looking a bit ratty after a few drops, and to give me direct access to the carburetors to drain the float bowls.
I drained them both last night, it wouldn't start. I drained them again and gave it until today to maybe dry out or something, wouldn't start.
Everything looks fine on it, normal power, the battery feels like it's kicking as it should, the engine makes the appropriate noises, it just never turns over.
What else should I be looking at?
Thanks.
BoKing is offline   Reply With Quote
Old July 7th, 2013, 05:52 PM   #2
j98sprint
Motorcycle(s): '02 Ninja 250, '98 Triumph Sprint 900, '69 H-D Sportster XLCH 900
My guess is that you are not filling them all the way before you try to start the bike. Suggest you apply vacuum (slightly suck on a length of vacuum hose attached to the nipple on the petcock) to the petcock but leave one of the float bowl drain screws open.
When you see gas coming out of the drain hole it will verify that the gas is reaching the bowls. Close the drain screw and give the bowls a couple of minutes to fill then give her a try. Should start.
j98sprint
j98sprint is offline   Reply With Quote
Old July 7th, 2013, 05:59 PM   #3
Try setting the petcok to prime?
Old July 7th, 2013, 06:06 PM   #4
tc.young
Motorcycle(s): '89 klr 650, '00 250r
no prime on our pre-gens, crank that sucker for 5 seconds at a time, i think i did it twice or three times before mine went from empty to running. is the vacuum hose still hooked up?
tc.young is offline   Reply With Quote
Old July 7th, 2013, 06:27 PM   #5
BoKing
I had my brother come over (who used to be a mechanic, I'm very much not a mechanic) and take a look at it.
He said the engine was turning over, it just wasn't starting. I thought if it didn't "turn over" that meant it wasn't starting so I apologize for the misinformation. I drained the bowls several times and tried both quick starts and prologed 5-10 second rev-starts - nothing.
My brother thinks it may be the spark plugs, but he didn't have the tools to address them. We removed the gas tank and he's going to dig into it tomorrow. If its not the spark plugs (getting replacements tomorrow in preparation for his visit), then we have no idea what it is.
Old July 7th, 2013, 06:28 PM   #6
pimpybra
Motorcycle(s): Yellow 2002 Ninja 250
When I dropped my bike in the parking lot a number of months ago, I had to have a buddy push start me and I had to pop start it.
Once it did, it revved pretty high for a bit. Buddy said the engine got flooded and it just needed some help to work it out with the mechanical push.
pimpybra is offline   Reply With Quote
Old July 7th, 2013, 06:51 PM   #7
tc.young
it's even easier if you just pull out the spark plug wire and hook a spare to it. that way you don't have to fiddle getting the spark plugs out of the engine and you can check for spark. but dropping it would have nothing to do with the ignition system.
safety switch maybe?
Old July 7th, 2013, 09:40 PM   #8
BoKing
It's a 2007 Ninja 250. I don't think there's a safety switch on it. I could be wrong.
Old July 7th, 2013, 10:05 PM   #9
baxtc1
baxtc1's Avatar
Motorcycle(s): '92 GPX 250 (Gone and replaced with '08 V-Strom), 2005 Suzuki C50.
Kill switch? (sorry, but)
baxtc1 is offline   Reply With Quote
Old July 8th, 2013, 01:30 AM   #10
BoKing
The killswitch is not engaged. It's off. Power is flowing normally.
Old July 8th, 2013, 10:33 AM   #11
PEN25
Motorcycle(s): 2001 ex250
are you trying it with the clutch pulled in or not? try it with the clutch pulled in. if it starts it might be the kickstand sensor.
PEN25 is offline   Reply With Quote
Old July 8th, 2013, 11:09 AM   #12
cuong-nutz
cuong-nutz's Avatar
Make sure the throttle is closed, choke engaged, and let her fire up. Could try manipulating the throttle a bit while starting the bike.
It's possibly that your carbs are dirty since you said that draining the bowls worked for you a while back. When you dropped your bike it's possible it could have dislodged something and clogged a jet.
Hows the air filter looking?
HalfFast Racing Team
Old July 8th, 2013, 11:10 AM   #13
cuong-nutz
cuong-nutz's Avatar
Those are fine since his motor is turning over but not starting. If it wasn't, then the starter would not engage and turn the motor over.
Old July 8th, 2013, 11:18 AM   #14
tc.young
not necessarily, though my case was different, i friend my ignition switch so when i jerry rigged one up, it would crank all day but because there's a resistor between two wires, there would be no trigger for the spark, even if it's cranking. not that it's the case here.
Old July 8th, 2013, 11:21 AM   #15
cuong-nutz
cuong-nutz's Avatar
I'm aware of that but OP didn't state he hotwired his bike
Old July 8th, 2013, 12:08 PM   #16
tc.young
hehe, more like it was a temporary key.
back to the op, any news on the spark test? you only have to remove the fairings, tank and seat.
Old July 8th, 2013, 01:14 PM   #17
Why have drained the bowls and done all of the above after a simple tip over?
I see no relation among these things.
Plugs are fine, no need to mess with them (the less you disturb them the better).
There is no tip-over safety switch in your model.
Suggest your brother to focus on the level of fuel inside the bowls, which is what gets disturbed after a fall like that more frequently.
Your bike needs to have certain level of fuel inside the bowls to work properly.
This is what happens: one or both floats-valves get out of position and somehow jammed against the cast aluminum body doing one of two things: keeping the flow of fuel closed or open regardless the level of fuel inside the bowls.
The common remedy is to tap the bodies of the carbs with the handle of a heavy screwdriver in order to liberate the float(s) and valve(s).
Charge you battery or use an auxiliary battery for the attempts, or you may end up with an additional problem: a dead or damaged battery.
Also check the level of oil, because some fuel could have flown down into it: too high level + gas smell in oil = bad
Old July 20th, 2013, 07:07 PM   #18
BoKing
Long overdue update. Bother took a few weeks to get around to changing the spark plugs.
Here's what we did tonight:
1) Change the spark plugs
2) Test the coils
We saw successful sparks coming out of each spark plug (the new and the old).
My brother says everything looks good with the ignition stuff, and it has to "be fuel related". He doesn't know much about the bike though, so I"m waiting for a friend who works on bikes for a living to come by. I just wanted to update him with what has been tested to save him any time. We also tested the fuel valve thingy in different positions.
Same thing. The engine turns over, just never starts. My brother said he never smelled fuel anywhere at anytime so he thinks fuel isn't getting somewhere it needs to be. We tried tapping the things holding the fuel as suggested above in the prior post, no dice.
Any guesses would be good, I can pass them on to my bike friend.
Thanks again.
Parked bike fell in mud and now idles low/won't start. BoKing 1986 - 2007 Ninja 250R Tech Talk 9 December 15th, 2014 03:28 PM
Dropped Bike Won't Shift KnockoutJ 2008 - 2012 Ninja 250R Tech Talk 10 March 23rd, 2013 08:57 PM
My bike is stuck at 65 mph and won't go any faster? untdavid 2008 - 2012 Ninja 250R Tech Talk 10 April 2nd, 2010 05:01 PM
