Old July 26th, 2013, 07:13 AM   #1
peterpayne
peterpayne's Avatar
Motorcycle(s): Pregen body with a newgen engine.
Previous owner said "anything other than amsoil and it will make weird noises"
I recently got this bike, I went for it, because it was really cheap and it seems to be in very good condition and I'm a beginner.
So I'm thinking about changing oil and oil filter, but then I remembered I heard the previous owner saying to use amsoil, and I also noticed it has excess oil, don't know how much, can't tell since it goes I'd say at least 2cm above the oil level window.
Should I heed his recommendation/warning and get amsoil oil only?
Bike has 22,000 miles and well, I'm wondering...
The bike starts smoothly and idles well in about 20 seconds, I have nothing to compare with, but it feels strong, I'm 300lbs and I can very easily accelerate well beyond my ability to control, so I'm not worried about carbs right now.
I've seen that Rotella t6 is one of the most liked oils for the ninjettes, and I think I'll give it a try and pay good attention to how the engine sounds afterwards.
Thanks!
peterpayne is offline   Reply With Quote
Old July 26th, 2013, 07:21 AM   #2
fishdip
fishdip's Avatar
Motorcycle(s): 250/300
Thanks!
Id be more worry about having to much oil then what oil you are using.
Old July 26th, 2013, 07:31 AM   #3
Some people are goofy like that. Run whatever oil you want as long as it meets specs, your choice not anyone else's. And yea, proper levels only.
Old July 26th, 2013, 07:43 AM   #4
LittleRedNinjette
Certified Troublemaker
LittleRedNinjette's Avatar
That's almost as good as the guy that says "only use shell (or whatever brand) gas or the motor will blow".
Not saying that some oils aren't better then others but as long as you use the rite weight and type you should be good. My boyfriend has Amsoil in his bike rite now and i have Rotella T in mine.
Raven's Rejuvenation
Old July 26th, 2013, 08:16 AM   #5
peterpayne
peterpayne's Avatar
Got it, oil brand is not that important as long as it's changed regularly and levels are proper... makes sense...
THANKS!
Old July 26th, 2013, 09:48 AM   #6
JASO-MA2 10w40
Old July 26th, 2013, 10:50 AM   #7
peterpayne
peterpayne's Avatar
So what do we think about a product like this? http://www.amazon.com/Kawsaki-EX250F...sim_sbs_auto_2
Old July 26th, 2013, 10:54 AM   #8
fishdip
fishdip's Avatar
Its what I use. Don't for get to clean the screen when you change the oil.
Old July 26th, 2013, 11:01 AM   #9
overpriced by about $10.
get any jaso-ma2 oil. the kn-401 oil filter can be found at most cycle shops.
Old July 26th, 2013, 11:05 AM   #10
fishdip
fishdip's Avatar
http://faq.ninja250.org/wiki/Main_Page
Old July 26th, 2013, 11:07 AM   #11
blasphemer, linking to "THAT SITE"!
Old July 26th, 2013, 11:11 AM   #12
fishdip
fishdip's Avatar
It has the most info in one place on how to work on the 250.
Old July 26th, 2013, 12:44 PM   #13
TonyKZ1
TonyKZ1's Avatar
Motorcycle(s): 1975 Kawasaki KZ400D (Sold), 1989 Kawasaki Ninja 250 (sold), 1997 Yamaha XJ600s Seca II
+1.. Exactly, a lot of info on the Ninja 250 along with good info on new or beginning riders too.
Tony
1997 Yamaha Seca II - mostly stock, Racetech upgraded forks, FZ6R rear shock, Oxford Heated Grips, Barkbusters Blizzard Handguards, a Scottoiler vSystem chain oiler. My Mileage Tracker Page.
TonyKZ1 is offline   Reply With Quote
Old July 26th, 2013, 03:50 PM   #14
quarterliter
Motorcycle(s): 2004 Ninja 250
If your willing to spend 37 bucks on kawi oil get Redline Motorcycle 10w40 it will outperform anything.
[superbikeplanet.com] - Soup "Zombie" Shirts. A Great Way To Make People Wonder About Ninjette Newsbot Motorcycling News 0 May 19th, 2014 01:00 PM
Bikes making weird noises.Why? Black knight General Motorcycling Discussion 6 April 5th, 2013 03:53 PM
[topix.net] - "The Fonz", "Ralph Malph" & "Potsie" are giving away Fonzie's motorcycl Ninjette Newsbot Motorcycling News 0 August 16th, 2012 04:30 PM
need help! weird noises madeink0rea 2008 - 2012 Ninja 250R Tech Talk 2 June 25th, 2012 11:51 AM
"new" ninja 250 owner in West Texas blueflash New Members 10 July 16th, 2011 02:36 PM
