Old April 22nd, 2014, 09:45 AM   #1
abhijitz
Motorcycle(s): Many Two Wheels ..
08+ Ninja 250 Flywheel Puller Questions
Why does the manual list 2 components... should be only 1, either M35x1.5 or M38x1.5
Special Tool - Flywheel Puller Assembly, M38 × 1.5/M35 ×
1.5: 57001-1405
Edit : Racer X has been kind enough to check his tool and get me the measurements.
[ex-AFM #828 | SMUSA #828 |
Sponsors : MotionPro | LeoVince | Insurrection Racing Gloves | QstarZ Laptimers
+ OEM Parts @ 30-40% OFF : Harry @ 1-877-437-1631,17 harry@hondaeasttoledo.com
abhijitz is offline   Reply With Quote
Old April 22nd, 2014, 02:33 PM   #2
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
I don't know what is 38x1.5".all the flywheels I have are 35x1.50. I will check out the manual soon.
Worlds fastest 250 ninja
Old April 22nd, 2014, 02:53 PM   #3
cuong-nutz
cuong-nutz's Avatar
perhaps Kawi's is double threaded to work with both sizes?
HalfFast Racing Team
Old April 22nd, 2014, 05:32 PM   #4
Racer x
Racer x's Avatar
OK .. I found it in the book on page 16-26 I think the factory tool has two thread sizes. 38 and 35. Both have a 1.50 thread pitch. But for the. 250 ninja you only need the 35x1.50 size to remove your flywheel.
Old April 22nd, 2014, 07:38 PM   #5
abhijitz
Thanks Eric .... Mind measuring the depth? Do the 35x1.5 work for 2nd Gen (2007 and earlier as well?)
MotionPro has 2 options for the 35x1.5 and the one with depth of 75mm is listed for 2007 and earlier Ninja.
Old April 29th, 2014, 05:45 PM   #6
cuong-nutz
cuong-nutz's Avatar
MP has a 1 inch and 3 in depth.
The picture in the FSM has a 3 inch depth so that's what I went with.
Old May 8th, 2014, 08:20 PM   #7
abhijitz
Am i doing something wrong? With the 3" depth [75mm] MP one, the inner bolt is seated all the way in with no threads visible. How are you supposed to turn?
@cuong-nutz - were you referring to a pre-gen Ninja 250?
Old May 9th, 2014, 06:03 AM   #8
cuong-nutz
cuong-nutz's Avatar
I still had like an inch or so of thread depth left. I can take a look when I get home. Maybe @Racer x, or @mgentz can comment
Old May 9th, 2014, 06:38 AM   #9
abhijitz
that would be helpful. The inner bolt length (end-to-end) is 87mm for me.
Old May 9th, 2014, 06:40 AM   #10
mgentz
Board Member
I will look when I get home. However, I did find this:
Originally Posted by mgentz View Post
Old May 9th, 2014, 06:49 AM   #11
abhijitz
Thats what i have from MP. Also, do the inner bolt need to thread to crankshaft OR just rest on crankshaft end/tip?
Old May 9th, 2014, 06:52 AM   #12
mgentz
Board Member
the inner bolt pushes on the crank to pull the flywheel off.
Old May 9th, 2014, 06:56 AM   #13
abhijitz
Just to be clear, the inner bolt just rests on the crank end, correct? But then i have no threads left once i screw in the inner bolt all the way thru.
Either the outer barrel is longer OR the inner bolt is shorter. I did bolt back the crankshaft bolt and left it a bit loose {that way the inner bolt of the puller will show threads}. Hit with the hammer couple of times, took the impact, yet no movement on the flywheel. Dont know how much should i hit in order to not mess the crankshaft bolt threads.
Old May 9th, 2014, 07:05 AM   #14
Racer x
Racer x's Avatar
I need to look later today. Is it better to push on a bolt loosely threaded into the crank or the tip of the crank? It takes a lot of force to pull the flywheel. I don't want the crank tip or threads damaged.
Old May 9th, 2014, 02:31 PM   #15
cuong-nutz
cuong-nutz's Avatar
The puller I used is MP 08-0349. It doesn't thread into the crank bolt. I just looked at MP website and it's listed for the older 250s. 75mm of thread inner bolt.
End of inner bolt sits on the face of the crank snout.
Old May 9th, 2014, 04:56 PM   #16
.... striking a magnet makes it lose its' magnetism????
Old May 9th, 2014, 05:05 PM   #17
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
You could try putting a small 1/4 inch drive socket under that bolt so it can put pressure against the crank.
My Cafe Racer Build
My intro post
Old May 10th, 2014, 05:43 AM   #18
mgentz
Board Member
This is the same flywheel puller that I have.
Old May 10th, 2014, 07:19 AM   #19
abhijitz
With help of my friend @KazMan i was able to get it out. We had to apply some heat. The crank bolt was threaded in place for the inner bolt to rest on.
Thanks everyone for your inputs! , specially @Racer x
Old May 11th, 2014, 10:17 AM   #20
abhijitz
I am wondering what the OEM flywheel puller looks like? Does anyone have a flywheel puller to measure the outer barrel? MP is 75mm long.
08+ Flywheel Puller - Aftermarket one? abhijitz 2008 - 2012 Ninja 250R Tech Talk 2 June 12th, 2013 09:34 PM
Flywheel puller part # abhijitz 1986 - 2007 Ninja 250R Tech Talk 4 June 11th, 2013 01:29 PM
Need tool number for flywheel puller for an 2008 250R NorCal_250R 2008 - 2012 Ninja 250R Tech Talk 1 May 16th, 2011 11:28 AM
