Old June 9th, 2014, 08:43 AM   #1
jgcable
Motorcycle(s): 2003 Ninja 250r
How hard can you flog these bikes?
My 2003 has 4300 miles on it. It runs mint. Has new tires. Every maintenance item has been done. Anyway.. I shift normally at 8K. Yesterday I found myself shifting at between 10K and 12K many times. It seems to me that shifting around 8K is the perfect amount of RPMS. The clutch just slides into gear with little to know hesitation providing you match the RPMS as close as possible. Its almost like power shifting.
The other thing I notice is my bike feels the best when I am beating the snot out of it.. but that leads to the question.. am I or is what I am doing normal?
I have been riding for a long time but its a little hard to accept how great these motors are at the very high RPM range.
That leads me to another observation. A beginner rider with one of these bikes and after a few months they feel they have "graduated" up to a bigger bike is actually sad because most likely they have never even been over 6k rpms and the fun doesn't start until between 8K and 10K.
jgcable is offline   Reply With Quote
Old June 9th, 2014, 08:45 AM   #2
Flying
Motorcycle(s): 2010 Ninja 250
Perfectly normal for our bikes.
A combination of low-displacement with carburetors feeding our bikes gives us an almost turbo-like action without having to rev up to suicidal speeds on the street.
Old June 9th, 2014, 09:13 AM   #3
DaBlue1
DaBlue1's Avatar
Pretty damn hard. With a little tweaking, a mod or two here and there, You can easily set a bonafide land speed record of 123+ mph.
Old June 9th, 2014, 09:16 AM   #4
outasight20
outasight20's Avatar
Motorcycle(s): 2005 Yamaha FZ6
On the contrary, I think people who get bored with the power (like me) spend plenty of time in the upper RPM's. When they reach the bike's power limit, that is when they want to upgrade. I had my 250 for almost a year and 8K miles and the power really started to feel like it was lacking near the end of that time.
There isn't a day that I don't miss the light weight and flickability of the baby Ninja though.
outasight20 is offline   Reply With Quote
Old June 9th, 2014, 09:16 AM   #5
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
Hard
Old June 9th, 2014, 09:54 AM   #6
If you want the full potential from the little Ninja you need to shift it above 8000 - that's just where the fun starts! The engine is designed and tuned to make most of it's power near redline - especially a Pregen.
As long as you do the proper maintenance and keep everything in spec, you aren't doing any harm. If you are concerned about engine wear, use a top notch synthetic oil and change it regularly.
The fastest acceleration is almost always to shift at redline or very close (the exact RPM changes in every gear, but generally it's way up there close to redline - even if the dyno shows power tapering off). Each gear has more torque multiplication than the next, so you get a torque advantage by holding-off your shift until you have to. That translates to more acceleration. An exception would be if the engine falls flat on its face before redline - which isn't the case with the Ninja.
Old June 9th, 2014, 10:00 AM   #7
Old June 9th, 2014, 02:41 PM   #8
verboten1
verboten1's Avatar
MOTM - June '15
Before I got my gauges on the bike I was bouncing off the rev limiter quite often.
It loved it...lol
Ride more, worry less.
Old June 9th, 2014, 02:42 PM   #9
Keep the oil fresh and full and you can beat it as hard as you want and it will just ask for more.
Old June 9th, 2014, 02:44 PM   #10
flog her fast and hard till she spews fluids.
Old June 9th, 2014, 03:34 PM   #11
agentbad
agentbad's Avatar
How's the FZ6 in comparison?
Old June 9th, 2014, 03:48 PM   #12
fast1075
Motorcycle(s): 2006 Ninja 250, 2004 Buell XB12s, Honda 110 Elite
Smile How Hard?
13k, 13k, 13k, 13k, 13k repeat endlessly. Eventually stop to scape the bugs off your teeth and let your buddy on the 600 catch up.
"They don't pay me enough to ride this thing!" Kenny Roberts after winning the Indy Mile on the TZ750 powered Grand National bike.
fast1075 is offline   Reply With Quote
Old June 9th, 2014, 05:59 PM   #13
..........It seems to me that shifting around 8K is the perfect amount of RPMS. The clutch just slides into gear with little to know hesitation providing you match the RPMS as close as possible. Its almost like power shifting.
The transmission and the clutch don't know or care about how fast everything is rotating.
Your skill and timing are the source of any flawless shifting ...... up or down; .......... nothing else.
With more practice, your range of "perfect" rpm's will get wider.
Old June 9th, 2014, 06:55 PM   #14
Lol. Try a track day. The bike will never go below 8k and you'll both come back to the pits lusting for more.
Old June 9th, 2014, 07:02 PM   #15
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
these bikes are designed to run high revs.
TEAM ALFALFA
www.apexassassins.com
Old June 9th, 2014, 07:04 PM   #16
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
I'm green with envy.
Old June 9th, 2014, 07:07 PM   #17
supersport
Motorcycle(s): Ninja 300
I thought everyone ride these small bikes near the redline. Most people that want to upgrade are bloodthirsty after staying in the redline.
supersport is offline   Reply With Quote
Old June 9th, 2014, 07:36 PM   #18
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
If my babe ain't screaming, neither of us are happy! Bouncing off the rev limiter makes me happy!
Old June 9th, 2014, 09:26 PM   #19
ez12a
Motorcycle(s): 2009 Ninja 250R (Sold), 2007 SV650S
i think anyone who has taken the ninja on the freeway would be over 6k lol.
ez12a is offline   Reply With Quote
Old June 9th, 2014, 10:18 PM   #20
Kscreations08
Fresh Deli Meat
Kscreations08's Avatar
Motorcycle(s): 2009 250R Ninja -Neener-
We shall call thee "Seahorse." -Antiant on Couvade Syndrome
Kscreations08 is offline   Reply With Quote
Old June 10th, 2014, 06:17 AM   #21
outasight20
It's heavy, requires more effort to throw around, and sits a lot higher off the ground. But those same things make it more stable and comfortable for long distance riding. You can scrape pegs on it easily, but it takes serious balls compared to the 250. And it's fahkin fast too. 11.7 is my best in the 1/4 so far.
Old June 10th, 2014, 07:12 AM   #22
fishdip
fishdip's Avatar
Motorcycle(s): 250/300
Harder then you can flog a 2 dollar hooker before her pimp walks in.
Old June 10th, 2014, 08:21 AM   #23
capt_bugaloo
motorcycle rider
capt_bugaloo's Avatar
What's that song by Devo...?
Old June 10th, 2014, 06:27 PM   #24
Originally Posted by Kscreations08 View Post
Lol, now we know what @alex.s does to blow up his race motors.
Old June 10th, 2014, 11:11 PM   #25
forcibly over-revving it has always done it for me
Old June 11th, 2014, 02:12 AM   #26
Singh2jz
Singh2jz's Avatar
Motorcycle(s): '07 ex250-F/J
Cleaning up after isn't fun though.
The Bike | The Truck
Old June 11th, 2014, 02:27 AM   #27
Kscreations08
Fresh Deli Meat
We call that the Cuddle Puddle
Old June 12th, 2014, 03:48 PM   #28
mr2peak
Motorcycle(s): Hyper 821
Wonder how much longer it would have gone with proper cooling? That bike obviously overheated
mr2peak is offline   Reply With Quote
Old June 12th, 2014, 04:57 PM   #29
supersport
tissue and baby wipes are very handy
Old June 13th, 2014, 10:27 PM   #30
Hero Danny
Inline 4!!!
Hero Danny's Avatar
Call me a coward, but redlining always made me nervous.. like I was gonna break something in the engine :/
Be careful. Remember you are
invisible
Old June 13th, 2014, 10:51 PM   #31
corksil
Motorcycle(s): A lot.
I frequently ride the bike at 13.8krpm in 6th, WFO for 8 minutes at a time pushing the wind.
And by frequently I mean daily. For months now.
Just batshit crazy. All his posts are endless diatribes. Some are actually entertaining but mostly batshit crazy.
Old June 13th, 2014, 10:52 PM   #32
corksil
Edit, wrong forum. I have a 09.
Old June 14th, 2014, 07:59 AM   #33
mr2peak
Maintain it. Flog it. Repeat.
Why else would you own a non-classic bike?
How hard is it to sell bikes with over 100k miles? scorch General Motorcycling Discussion 18 September 17th, 2014 05:29 PM
[visordown.com] - eBay user hires bikiniclad models to help flog secondhand bike part Ninjette Newsbot Motorcycling News 0 September 9th, 2014 02:40 AM
[visordown.com] - How hard is Dunlop pushing? This hard Ninjette Newsbot Motorcycling News 0 June 7th, 2013 11:20 AM
[topix.net] - are these bikes hard to find a Ninjette Newsbot Motorcycling News 0 September 2nd, 2011 10:10 PM
[kropotkin thinks...] - Kawasaki: Why Flog A Dead Horse, When You Could Revive A Live Ninjette Newsbot Motorcycling News 0 February 11th, 2009 04:01 PM
