July 5th, 2014, 12:40 PM | #1 |
Rear Brake Question
I had my local shop replace my rear brake about a year and a half ago. Yesterday, it fell out of the rotor and it looked like it does in these pictures. In addition, the rotor was all discolored as you can see.
Before I replace the brake pad, should I clean the rotor? Should the shop replace it for me? I didn't think the brake pad should have worn out that quickly. |
July 5th, 2014, 12:49 PM | #2 |
Here are the pictures:
The first and third are the completely worn down brake pad. The second picture is of the rear rotor. |
July 5th, 2014, 01:14 PM | #3 |
Certified Troublemaker
Join Date: Oct 2012 Motorcycle(s): 2006 Ninja 250r "Pikachu", 2017 Ninja 650 "Epona" Posts: A lot.
If it was my bike i think i would replace the rotor, not just clean the old one...
Hell, if my cars rotors looked like that i would change them...
Raven's Rejuvenation A bruise is a lesson... and each lesson makes us better... |
July 5th, 2014, 01:20 PM | #4 |
Join Date: Jun 2009 Motorcycle(s): 2008 ninja 250 Posts: 271
Also check to make sure it is not sticking
Because of the Pistons are sticking it'll constantly wear mine was stuck and exhibited a slight pull to the right side.
Just make sure once you get the pads back in that it spins freely |
July 5th, 2014, 01:21 PM | #5 |
Measure the thickness of the rotor + compare to specs and check it's straightness. If both are good, the no replace. Just lightly sand with new pads w/ a good bleed and bedding and you should be straight.
July 5th, 2014, 01:31 PM | #6 |
Because if the Pistons are sticking it'll constantly wear your brake pads out.
My rear caliper was stuck and exhibited a slight pull to the right side with no pressure applied to either side of the handlebars. Just make sure once you get the pads back in that it spins freely. You can use the rear shock as a jack point. Then just spin it with your hand. |
July 5th, 2014, 06:59 PM | #7 |
http://en.wikipedia.org/wiki/Tempering_%28metallurgy%29 Too much heat has been there, probably damaging the parts of the caliper and the brake fluid. I would take it to a professional shop for evaluation of the disc and caliper and for a full replacement of the brake fluid. Check this thread out for replacements: https://www.ninjette.org/forums/showthread.php?t=186735
July 5th, 2014, 07:28 PM | #8 |
Captain 2 Sexy
Join Date: Apr 2014 Motorcycle(s): Kwaka EX250 Posts: 241
That's a lot of heat.
July 5th, 2014, 07:55 PM | #9 |
Down Under
Join Date: Jun 2014 Motorcycle(s): Kawasaki ZXR250C Ninja Posts: 296
Replace disc/caliper/pads/fluid.
Previous owner of my bike ran the rear brake down to metal on metal, requires new disc |
July 6th, 2014, 10:24 AM | #10 |
Wow.... that just looks delightful! Okay, thanks for y'all's help!
Gixxer rear shock question - rear stiffness too high | cookiebug79 | 2008 - 2012 Ninja 250R Tech Talk | 20 | January 17th, 2015 08:19 AM |
Rear Brake Lever Travel is Excessive and Rear Brake won't Lock Tire. | N-m | 1986 - 2007 Ninja 250R Tech Talk | 14 | July 17th, 2014 04:13 AM |
08+ rear wheel, right rear set, rear brake system, seat | cuong-nutz | Items Wanted | 2 | October 6th, 2013 05:37 PM |
Question about rear brake spring... | nliu314 | 2008 - 2012 Ninja 250R Tech Talk | 9 | August 27th, 2012 12:50 PM |
Rear Brake Line Question | kevheads | 2008 - 2012 Ninja 250R Farkles | 2 | June 28th, 2012 07:59 PM |
