Old January 15th, 2015, 12:08 AM   #1
Old_Six_Fitty
Old_Six_Fitty's Avatar
Motorcycle(s): DL1000 V-Strom, KLR650
Shopping for my Ninja
So being a cheap bahstadge and being familiar with wrenching, I'm shopping for an older the pregen Ninja 250R. Mostly as a project bike and occasional commuter. Ride to work is about 25 mi round trip and is 50/50 freeway vs city boulevard.
Shopping craigslist I see many cosmetically challenged bikes, but also see quite a few that may have title issues. I'm okay buying a low budget builder just to get the titled frame, then putting the best parts from two donors together to get a decent steed.
What are the typical issues to watch for?
> Frame weaknesses?
> Engine failures?
> Electrical failures?
> Cooling system failures?
Other than tune up & valve adjust, fresh fluids & lube, tires, brake pads / lines, repack wheel bearings - what else to expect when bringing the used and neglected Ninja back to optimal reliability and performance?
... or point the FNG to the FAQ / thread.
Old_Six_Fitty is offline   Reply With Quote
Old January 15th, 2015, 12:49 AM   #2
MrAtom
MOTM - July '15
https://www.ninjette.org/forums/showthread.php?t=70685
Old January 15th, 2015, 07:23 AM   #3
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
I would wait to get a good runner in need of cosmetics only. Titles can be a pita and better off passing imo. These frames are pretty simple. Best price I have seen for a very clean pregen was $1200 in my area. Parts are pretty cheap
you usually can get a whole wire harness for $30-50 so even if an electric mess
that can be tidied up on the cheap. Good luck out there!
My Cafe Racer Build
My intro post
Old January 15th, 2015, 07:28 AM   #4
DanteCoal
DanteCoal's Avatar
Motorcycle(s): 2016 Ninja 300 ABS, R.I.P 1986 Ninja EX250
I agree with crazymadbastard, but if you're wanting to get something cheaper that you're wanting to work on a bit to save money, go for it! It's a great feeling to bring an old(er) bike back to life.
As far as what to look for, if it's not too much trouble you should ask to see it w/o the fairings to get a good look @ the tabs, hidden rust pockets, etc. Also be prepared to invest time in CLEANING the hell out of the thing. In my experience all that caked on, baked on dirt and grime can really start to effect the life of a bike due to many owners not thoroughly (read: obsessively) cleaning their bikes. So engine cleaner, q-tips, and some pick tools may be in order. Possibly a chisel. (I wish I were joking about that last one)
DanteCoal is offline   Reply With Quote
Old January 15th, 2015, 10:00 AM   #5
spent_too_much
spent_too_much's Avatar
One with title issues could be the "donor bike", if you get two. I have seen complete wiring harnesses for around $20 - $25 on eBay recently. In my area, a good runner will cost around $1000 - $1200. It might be cheaper in the long run to spend a little more up front on a good runner, that to start with a project bike. For example I have seen one in my area that, according to the seller, has sat for 3 years and does not run $750. It is a complete bike, but I am staying clear of it because it has sat for so long.
I too enjoy wrenching, and a project. But, you don't want to spend $2000 to complete a bike that will be worth $1000 when comlpeted.
As for the title issues, I came accross this thread, but have not tried it. It seems too good to be true, but for less than $100, it might be worth finding out.
http://advrider.com/forums/showthread.php?t=655441
Old January 15th, 2015, 11:37 AM   #6
ninjunk
Lostcause enthusiast
Motorcycle(s): 2000 EX250F
YEP keep passing up those title-less bikes so i can get them even cheaper!!
I'd say 300-500 for a 'project' non running, cosmetically rough bike.
If you hound craig's you can pick up a pretty decent pre-gen with dirty carbs for less than a grand. For a grand it would have to be perfect, 90%+ cosmetics and less than 10,000 miles with maintenance history, and title (not running of course).
The <$500 bikes attract a lot of dreamers, wannabees and other idiots thinking they can fix it up. You gotta move fast and be decisive to snap them up, they usually disappear off CL within a couple hours.
I've been looking for 6 or 7 months now just waiting for the right bike to pop up at the right price. There are so many of these out there, it will pop up eventually, just don't expect to get a good deal checking once a week on sunday morning, you'll miss the choice-est nuggets.
I like to buy bikes that are greeeeeezzy, the greasier the better, that way you know there was oil in it and the grease protects the paint underneath. Its like I always say.. if its leaking oil, you know there is oil still in it... its when it STOPS leaking oil that you gotta worry.
oh yeah some changes got made in '99/2000 and i think there were some changes around 96, maybe just cosmetics. Just like with anything the tank rust, rubber condition, and other stuff that is affected by time and time alone will be better on a newer bike.
good luck!!
ninjunk is offline   Reply With Quote
Sold My Motocross Bike, Shopping For A Ninja 250! WilliamDaFrog New Members 23 September 11th, 2014 07:25 AM
Canadian Shopping broken neck General Motorcycling Discussion 5 July 10th, 2012 02:05 PM
Bike shopping Highalltheway Items Wanted 3 September 6th, 2011 08:58 AM
Let's go tire shopping!!! JLinde1339 1986 - 2007 Ninja 250R Tech Talk 21 August 17th, 2011 12:53 PM
Shopping spree today. Rassie 2008 - 2012 Ninja 250R Farkles 12 June 24th, 2011 03:51 PM
