Old May 8th, 2015, 03:37 PM   #1
basementmt
Smell of burnt plastic/wiring
Hey guys, lately I've been smelling a bad small of burnt plastic/wiring coming out from under the steering.
This evening I checked out what might be the problem but cannot really determine what's the problem yet. Bike rides ok, no problems whatsoever but it still bugs me to smell this burnt smell all the way.
On my lookout, I found what seen to me as black liquid on the exhaust rod connecting to the engine, could this be the problem? or does anyone has an idea what this could be? I took this pictures after 3 mins since I've started the bike... could be nothing or could be something but this is the first time I've seen this.
Your help is much appreciated
basementmt is offline   Reply With Quote
Old May 8th, 2015, 05:19 PM   #2
ninja250r81
ninja250r81's Avatar
Motorcycle(s): 2012 ninja 250r se
Picked up a plastic bag of some sort and has melted on the exhaust.
Just use wax and grease remover if not thinners/gun wash.
Soak the exhaust with the product on a rag and it should come off.
If you get some on the plastic farings just use carwash and wash off
ninja250r81 is offline   Reply With Quote
Old May 9th, 2015, 01:20 AM   #3
basementmt
that's very possible. thanks for your help mate
Old May 9th, 2015, 02:00 AM   #4
Singh2jz
Singh2jz's Avatar
Motorcycle(s): '07 ex250-F/J
yo, you should get a grille for that area..
The Bike | The Truck
Old May 11th, 2015, 02:09 AM   #5
basementmt
I should and I will mate, thanks all for your help
Old May 11th, 2015, 06:26 AM   #6
You can make one much cheaper than buying an aftermarket one. Just search for a piece of light mesh and cut it to shape and zip tie it in place. Paint as you see fit.
Targa signal burnt out Tigerpaw 2013 - 2017 Ninja 300 Tech Talk 4 December 18th, 2013 04:00 PM
Saved the bike..burnt my leg mustang5.0 !%@*#$%!)@#&!%@ I crashed! 25 February 28th, 2012 01:06 PM
burnt chrome exhaust Rayme 2008 - 2012 Ninja 250R Tech Talk 15 February 24th, 2012 11:46 PM
Headlight lo-beam not working; burnt bulb? HorizonXP 2008 - 2012 Ninja 250R Tech Talk 6 November 14th, 2010 02:39 PM
Burnt leg on tail pipe Anthony_marr General Motorcycling Discussion 32 August 7th, 2009 11:53 PM
