Old June 5th, 2015, 05:06 AM   #1
the big mike
the big mike's Avatar
Motorcycle(s): 2008 Ninja 250r, Fazer8
Need help, exhaust glowing red
Hi
My dear ninjette has been in an underground garage for about a year now. I didn't ride her anymore because I've bought another bike (Yamaha Fazer8). Every once in a while I fired her up and rode around until she was hot.
Lately the battery has been running down as well, so my solution was to jump start the bike by rolling down a level
Anyhow, it's been about a month since her last run and now I'm having troubles. She starts but either dies immediately or stays between 5k-7k when giving it gas. After a while I noticed the part of the exhaust tube just in front of the slip on was glowing red and suddenly my FI light turned on as well.
Also the sound is not normal: sputtering and moaning.
If I have to do an uneducated guess: only one of the cylinders is actually working and the second one just blows everything through the exhaust valve. Then, combustion happens in the exhaust tube due to high temperatures.
Is my assumption correct? Is there an easy fix? I don't have any tools over here and I was just about to make the 100km ride to home with this bike, for maintenance. Looks like I'm a day too late....
I can not be a true player by playing around.
the big mike is offline   Reply With Quote
Old June 5th, 2015, 05:38 AM   #2
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
Hey Michael,
maybe your problem is a spark plug or ignition cable.
But anyway check the FI-Errorcode and reset it, see the attached pdf.
And important: the battery MUST be fully charged.
Good luck
Old June 5th, 2015, 06:30 AM   #3
bruce71198
bruce71198's Avatar
Do these have catalytic converters over there?
Old June 5th, 2015, 10:13 AM   #4
Originally Posted by the big mike View Post
.......... If I have to do an uneducated guess: only one of the cylinders is actually working and the second one just blows everything through the exhaust valve. Then, combustion happens in the exhaust tube due to high temperatures.
I agree with Somchai's post above and disagree with your guess, because exhaust temperatures are unable to initiate a combustion.
That red glowing of the exhaust pipe only happens due to out of sync timing regarding either exhaust valve or spark.
Your valves-cams have not been adjusted recently; hence, I would focus on the electronics of your FI system that decide over the spark timing.
Old June 6th, 2015, 01:30 AM   #5
the big mike
Ok, thank you for your replies everybody
Old June 6th, 2015, 05:11 AM   #6
My question too. That area would be where the cat is and glow red if there is a blockage. Seems unlikely though no?
Old June 6th, 2015, 05:45 AM   #7
Somchai
Freedom for Germany
I hope it's ok when I answer the question about the catalytic converter.
Yes, the Ninja 250R FI-Model has one, since she is Euro-3 legal there must be one in the exhaust-system and normally the converter is always behind the 02-sensor (must be).
When you mount a slip-on exhaust in Germany this also must have a catalytic converter to be street-legal, what could mean the stock converter is in the muffler.
Old June 6th, 2015, 03:33 PM   #8
LittleRedNinjette
Certified Troublemaker
LittleRedNinjette's Avatar
Sounds like it's running dangerously lean...
Raven's Rejuvenation
Old June 7th, 2015, 08:56 AM   #9
bruce71198
bruce71198's Avatar
A miss fire due to spark in one cylinder will dump that cylinders air fuel mixture into the exhaust stream where it then will combust at the catalytic converter.
A glowing head pipe coming out at the head would indicate a lean fuel mixture.
Old June 7th, 2015, 09:56 PM   #10
Somchai
Freedom for Germany
Sorry but I don't understand why you'd answer this to me - do I have to understand?
Old June 8th, 2015, 08:30 AM   #11
bruce71198
bruce71198's Avatar
Wink
Sometimes I just feel the need to quote someone.
Last futzed with by bruce71198; June 8th, 2015 at 08:31 AM. Reason: left out info
LunaSee rim tape on ninja 250 Glowing dragono Videos 1 April 25th, 2015 05:36 PM
Red Hot Glowing Radiator Supports/Radiator Top bluebr65 2008 - 2012 Ninja 250R Tech Talk 10 March 10th, 2012 10:05 AM
[crash.net - MotoGP] - PIC: Rossi glowing in the dark. Ninjette Newsbot Motorcycling News 0 April 17th, 2009 04:30 AM
