November 29th, 2015, 06:22 PM | #1 |
Join Date: Nov 2015 Motorcycle(s): 2005 Ninja 250 Posts: 5
Gas leaking from carburetor - '05 Ninja 250
Have taken my carbs apart twice to remedy this issue to no avail. This last time I replaced the float valves, pilot screw and float gasket; it's still leaking, although, not as bad as it was before. Any thoughts and/or suggestions would be greatly appreciated. I love my bike...I don't love my carburetor right now.
November 29th, 2015, 07:41 PM | #2 | |
ChocolateMilk Addict
Join Date: Mar 2015 Motorcycle(s): '05 EX-250 "Kallie" 85 KLT 110 ATC "Murdock" Posts: 329
< ATGATT > Sweat you can wipe off, Road rash you can't. Burn Rubber, not your Soul. |
November 29th, 2015, 07:55 PM | #3 |
Float bowl seals. When mine were old, the bowls would leak the first time I put gas in them after being put away and/or drained for work. After a while, they'd swell up and seal again, but it would take a few hours of contact with gas to seal and they would drip once in a while.
Got new seals and the problem has been gone since. |
November 29th, 2015, 08:04 PM | #4 |
As the others have already said, you must find out where the leak is coming from, it could be a number of causes.
I suggest PM @ducatiman for all your carburetor needs, he's very affordable. https://www.ninjette.org/forums/showthread.php?t=226815
November 29th, 2015, 08:11 PM | #5 |
Welcome, Linda !!!
The seats (orifices in the aluminum body) of the float valves may have some hard deposits that interfere with the proper seal of the soft tip (neoprene) of the part that you replaced. If that is true, a cotton tip, a drill and some dental paste could help.
November 30th, 2015, 10:21 AM | #6 |
Thanks for the warm welcome! Really makes one feel the love!
Thanks for all of the suggestions too! I haven't started my bike again since yesterday but from what I remember the leak seems to be coming from somewhere at/around the carb stay plate/throttle screw area. I will try starting it again tonight when I get home and update but I'm pretty sure that's where it is. At first I did think it was from the drain screw or overflow area but realized it was dripping from somewhere higher up. @choneofakind - is the float seal the same as the float chamber 0-ring? If so, I changed that as well. Actually, that was one of the things my bike mechanic did before I pulled the carb off the first time months ago. Just put two new ones in this time because they came with the repair kit. @Motofool - how do I go about this cleaning with toothpaste, drill, and cotton swab? I'll definitely try it; at this point I'll try anything. |
November 30th, 2015, 12:36 PM | #7 |
Welcome Linda!
Good luck with your leak.
November 30th, 2015, 01:17 PM | #8 |
November 30th, 2015, 03:46 PM | #9 | |
December 11th, 2015, 12:01 PM | #10 |
Join Date: Jun 2014 Motorcycle(s): 2005 Ninja 250 Posts: 20
I was in the same boat this summer, taking the carbs apart twice trying to pinpoint the leak. In my case, it was torn tubing in between the two carbs. It was hard to see, given the location, even with the carbs off the bike. I had to use tweezers to remove the tiny hose clamp. I trimmed the tube down to excise the tear and reconnected the hose.
December 11th, 2015, 01:57 PM | #11 | |
December 11th, 2015, 02:20 PM | #12 | |
I changed my oil after the leak was fixed, just in case the dripping gas contaminated the oil. |
December 11th, 2015, 07:29 PM | #13 | |
April 18th, 2016, 03:19 AM | #14 |
I know this is an old thread but which hose exactly did yall have to replace? Can you post pics?
I have the same issue and still haven't resolved it. |
April 18th, 2016, 05:25 AM | #15 |
if not bowl orings leaking, possible the orings on the fuel crossover tube?
(yours will be black nylon, example pic from an older 250) and vacuum hoses between carbs do not carry fuel Note carbs will need to be split to replace the fuel tube orings.
April 18th, 2016, 06:21 AM | #16 | |
I used DucatiMan's image since it shows the hose that gave me problems. I had a tear where the arrow indicates. It was a tiny tear. When it leaked when the bike was running, the gas appeared to come from the top of the float bowls. I trimmed that hose a little to get rid of the tear and had enough left where it could be reconnected without pinching or kinking anywhere. I had to use tweezers to get the hose back on...it's cramped in there! |
April 18th, 2016, 06:31 AM | #17 | |
Join Date: Aug 2015 Motorcycle(s): 05 Ninja 250, 04 KTM 625 SMC, 01 Xc250 Posts: A lot.
You might want to replace the rest of your fuel and vacuum lines on your carbs where your in there. Also replacing the JIS screws with stainless steel allens so next time your carb work is less of a headache.
Because Unregistered sucks at riding. |
April 18th, 2016, 08:57 AM | #18 |
the hose marked in red is a vacuum hose
April 18th, 2016, 09:10 AM | #19 |
Don't vacume lines have to be after the throttle plate? What causes the vacuum if there is no restriction to open air?
April 18th, 2016, 09:19 AM | #20 | |
Vintage Screwball
MOTM - Mar '16
That's in the venturi and subject to the effects it creates. IE, vacuum.
Goin' fast on slow bikes! |
April 18th, 2016, 09:28 AM | #21 |
Vintage Screwball
MOTM - Mar '16
It turns out one of the drillings for that passage is on the intake side of the butterfly. So, it looks like it's both yes and no.
To compensate for this there's an air jet in the lower diaphragm chamber that transfers ambient pressure to one side of the coasting enricher's spring-loaded cut off valve. The excess vacuum in front of the butterfly valve is transferred to a drilling that leads to the other side of the cut off valve. This sucks it open, allowing the pilot jet to feed more fuel to the engine, preventing an overly lean condition. (Pop. Pop. Pop.)
April 18th, 2016, 09:33 AM | #22 | |
April 18th, 2016, 09:35 AM | #23 | |
Vintage Screwball
MOTM - Mar '16
April 18th, 2016, 09:37 AM | #24 |
I always run my needles and below a hair on the rich side, so I'm sure my bike would be fine. That said, there really is no need to delete it.
April 18th, 2016, 09:40 AM | #25 | |
Vintage Screwball
MOTM - Mar '16
That said.....Have you priced that diaphragm? $60 bucks, and that's not from Kawasaki...... Not joking. That was the reason for my delete.
April 18th, 2016, 09:45 AM | #26 |
i'd think they added the enrichener to compensate for super lean (EPA) pilot screw settings...as racinninja stated he deleted> tuned them> no issues.
It would be interesting to take a stock 250, pilot screws untouched from factory (still capped) and bypass/plug off the enrichener...I wonder if or how bad it would pop. That would then reveal Keihins motives as to using it at all. As it added manufacturing expense....my guess would be its addition was mandatory to both make the bike behave, meanwhile satisfy the EPA.
April 19th, 2016, 04:22 AM | #27 |
Holy balls! For the life of me I couldn't figure out how to split the carbs when I originally did my rebuild and just assumed it couldn't be taken apart. Now that I figured it out I'm going to pick up some o-rings (hopefully) today to replace these horrible excuses of fuel sealing capabilities since apparently none of the 3 rebuild kits I bought came with the replacement o-rings. Good catch ducatiman!
April 19th, 2016, 04:45 AM | #28 |
Normal commercially available "carb kits" fail to supply rail (upper vent and lower fuel supply) orings... as the standard "carb clean" not requiring a split. As these bikes are ageing...instances arise where spilt does become necessary. Don't even contemplate a split without orings in your hand....
i stock fuel and vent rail orings within kit form, if you (or any other member) need. Note the link bar JIS phillips heads are gonna be *real* tight....use a hand impact driver to smack them loose. "Persuasion" is necessary. When reassembling a split, the choke spring, center spring and throttle lever spring, inner hoses...all tricky to get together in one shot. Have fun!
April 20th, 2016, 02:37 AM | #29 | |
Indeed! I don't think it was that bad. The part that made it bad was the new o-rings on the overflow tube. Just did not wanna go back together even with lube (vaseline). Everything else just fell into place. You were right about the crossover pipe... New on the left and old on the right. I'll put it on my bike sometime later but I'm fairly positive that is going to be the cause of my leak based on proximity. Thanks a ton! |
July 10th, 2016, 10:26 AM | #30 |
Sorry, I haven't followed up. After having my carburetor off my bike more times than I wanted trying to figure out from where the gas leak was coming, I finally found the problem and fixed it. It ended up being this little tube (part #92005B) with 2 gaskets on it that runs/connects between the 2 carbs. Since I had the carbs apart I went ahead and replaced part #92005A as well and one of the vacuum hoses since that was a suggestion as well. And I'm more than thrilled to report that there is NO MORE gas leak and I pretty much have a nicely, overhauled carburetor
Thanks for all the help and suggestions. Now I need to get cables tightened |
July 11th, 2016, 10:06 AM | #31 |
Glad you figured it out!
Leaking gas | Alisha_Ardella | 2008 - 2012 Ninja 250R Tech Talk | 23 | May 11th, 2015 10:41 AM |
2010 Ninja 250 Leaking Gas | dhooooo | 2008 - 2012 Ninja 250R Tech Talk | 7 | January 29th, 2015 02:18 PM |
Gas Leaking - 2008 Ninja 250 | professorman | 2008 - 2012 Ninja 250R Tech Talk | 10 | October 23rd, 2014 11:41 AM |
02' Ninja 250 EX250H / ZZR250 Leaking Gas | campbellsteven | 1986 - 2007 Ninja 250R Tech Talk | 3 | September 19th, 2013 04:19 PM |
leaking a little gas | h0yitsdom | 1986 - 2007 Ninja 250R Tech Talk | 15 | July 11th, 2011 04:57 PM |
