Old June 10th, 2016, 09:31 PM   #1
ninjapanda
Motorcycle(s): Ninja 252, Honda VTX 1800, Vulcan 1500, Honda Shadow ACE 1100
Ninja 300 Motor in a Pregen 250.
Had a 2007 250 with a blown motor and was offered a running 2014 Ninja 300 motor dirt cheap, so I decided to combine them. Have already mounted the 300 motor in the 250 frame, wasn't too bad, all but 1 mount (the top front) met up perfectly .
Using the 300 wiring harness and the 250 ignition, also using the fi system from the 300 of course, it barely fits, but it does fit. The old battery is now way too small and the old battery box had to go. Made a new one out of vinyl ester and have it mounted much further back.
I am trying to keep it as original to the 2007 as possible when it comes to controls and gauges. The throttle and kill switch have been pretty much plug and play.
The stuff I need to finish .
The fuel pump I am using is from a txr500 ( I read about it on this site) I plan to mount that in the rear plastics.
The Wiring diagram sorta sucks hard for the 300. It list the wires, their color, not their purpose when it comes to the gauge cluster. I am using the 250's gauges, so the speedo is staying mechanical, but I have no idea about the rest of the stuff.
I plan to slightly modify the tank by adding a float sender and a removing the petcock adding a few dedicated ports.
If anyone has any suggestions or pointers it would be greatly appreciated.
Especially in regards to the 300's cluster wiring.
Also I'll post picture later.
ninjapanda is offline   Reply With Quote
Old June 13th, 2016, 08:05 PM   #2
ninjapanda
Only modified mount.
Trying to figure out where to mount fuel pump.
http://vid139.photobucket.com/albums...ps4hn0tkcl.mp4 Test start
Fuel Pump temporary mount.
Last futzed with by ninjapanda; June 15th, 2016 at 02:11 PM.
Old June 15th, 2016, 07:06 AM   #3
Palero
Palero's Avatar
Motorcycle(s): 1988 Honda Hawk GT 1989 EX250F (Died from left-turning car) 2011 EX250J (Died from SAME left-turning car)
Keep us updated!
Looking to take some motorcycle classes this Summer?
Palero is offline   Reply With Quote
Old June 15th, 2016, 07:49 AM   #4
LittleRedNinjette
Certified Troublemaker
LittleRedNinjette's Avatar
Raven's Rejuvenation
Old June 15th, 2016, 03:29 PM   #5
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
I haven't seen the 300 diagram, but from what I've seen a lot of Kawi's use the same colors for a lot of things. If you can post/send the 300 diagram, I can try to take a look at it.
Old June 15th, 2016, 05:48 PM   #6
ninjapanda
This is the connector to the cluster, I figured I would just trace the wires back from the full diagram, but any help would be beyond appreciated.
Old June 26th, 2016, 10:08 PM   #7
Finesse
ran when parked
Finesse's Avatar
Motorcycle(s): Freeride 250R, KLX250SF, mopeds
MOTM - Sep '17, Dec '14
next time put a gsxr1000 motor in a ninja 250
Finesse is offline   Reply With Quote
Old June 26th, 2016, 10:21 PM   #8
gixxer engine + ninja 250 frame =
Old July 7th, 2016, 07:49 AM   #9
ninjapanda
I was going for easy mod, not trying to breakout my welder for 2 weeks worth of work.
Comparing the 250 & 300 motor/engine (Version 2) cuong-nutz 2008 - 2012 Ninja 250R Tech Talk 147 May 1st, 2023 08:34 PM
Newgen motor in a Pregen Frame - Thoughts? kurbboy 1986 - 2007 Ninja 250R Tech Talk 84 January 25th, 2022 09:24 AM
Pregen (2005) Starter Motor mrudich Items Wanted 2 December 4th, 2014 02:42 PM
300 motor in 250 frame cuong-nutz 2008 - 2012 Ninja 250R Tech Talk 44 October 9th, 2014 03:57 PM
motor prep for a pregen? saber63 Ninjettes At Speed 1 June 28th, 2011 05:57 PM
