Old May 28th, 2018, 01:08 PM   #1
Tylorwashere
Motorcycle(s): 2005 Ninja 250
Relocating rear blinkers
So I know this has been done to death, but I have a question about moving my blinkers to the empty pods on each side of the brake light.
Do you guys pull the socket out of the old blinkers and use that? Or buy a new bulb socket to install in the new pod? I'm having a hard time pulling mine out, and wanted to know if you're better off just purchasing new ones
Tylorwashere is offline   Reply With Quote
Old May 28th, 2018, 01:23 PM   #2
Tylorwashere
Here's (hopefully) some pictures of what I'm talking about
[IMG][/IMG]
[IMG][/IMG]
Old May 28th, 2018, 02:26 PM   #3
I installed LED lamps as turn signals in those spots but wasn't happy with the visibility, so I connected them to the brake light and mounted separate signals. They look great as brake lights when they come on and suddenly make the tail light look larger.
Another possible consideration is that signals in the empty tail light spots aren't legal because they don't meet the DOT minimum distance between brake light and turn signal light.
Old May 28th, 2018, 02:41 PM   #4
Mohawk
Mohawk's Avatar
Motorcycle(s): ZZR250, VFR800
So they are blanked off in some countries becausev5hey do not meet light spacing or visibility standards.
Not sure about your GPZ, but the ZZR just uses painted over orange lens for the blanks, so if you move the bulb holder to the fitted internal reflector & get it mounted correctly, then you can use some fine wet & dry sand paper to remove the paint from the blank. This will leave a dull orange finish, but clean it up & spray it with a couple of coats of lacquer & it comes up perfect.
You’ll know if your blanks are lenses, because they will be orange inside !
Have fun.
Old May 28th, 2018, 02:46 PM   #5
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
I used sockets similar to these that I had laying around from old car tail lights. They were just right to snap into the holes, I have them hooked up as running (tail) lights and turn signal lights.
Old May 28th, 2018, 02:48 PM   #6
Tylorwashere
I haven't been able to find anything about a legal distance from the taillight, just as far away as possible, and that leaves alot to interpretation. I ordered some sockets for the blank holders, I'll post results when they get here
Old August 28th, 2018, 06:28 PM   #7
1994Ninja250F
‘94 Rider
1994Ninja250F's Avatar
Motorcycle(s): 1994 Kawasaki Ninja EX250F
This will help, even though it’s talking about putting brake lights in there it’s the same general procedure.
https://faq.ninja250.org/wiki/I_want...y_rear_sockets
I did this a long time ago, and I’ve had no problems with how they operate. Did it when I was very new to working on bikes (and cars) and it went smoothly.
For what it’s worth, I’ve been riding my Ninjette all over Ohio for the past 9 years with the rear lights set up this way, and the police have never given me any grief over it. And yes, I’ve just happened to have a police cruiser behind me in traffic many times, and I’ve never been stopped. However, YMMV.
1994Ninja250F is offline   Reply With Quote
Old August 28th, 2018, 07:06 PM   #8
Snake
Snake's Avatar
Here are some links for you to check out......
https://www.ninjette.org/forums/showthread.php?t=194079
https://www.ninjette.org/forums/showthread.php?t=156916
https://www.ninjette.org/forums/showthread.php?t=26436
https://www.ninjette.org/forums/showthread.php?t=10096
https://www.ninjette.org/forums/showthread.php?t=7890
Old August 28th, 2018, 09:55 PM   #9
Look up DOT FMVSS#108 and in California, CA ADC § 699. Front & rear separation should be at least 23". Bikes after 1973 are 16" apart. Rarely would you ever get cited, but I have. Also got ticket for riding with high-beam when my low-beam burnt out. And written up for too-loud exhaust. Ironic since cop's Harley was louder than mine.
Having said that, my pre-gen has turn-signal in empty side-pods too. We'll see how long I get away with it. > Gonna get some clear-lens and put amber-bulbs in so at least they're more distinctive and intentional as turn-signs.
http://2wheeldiscount.com/1994-2006-...-P2178853.aspx
Old August 29th, 2018, 12:44 AM   #10
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
hyperlites
check post 69-71
https://www.ninjette.org/forums/show...=316244&page=2
"trying not to get old"
What to do about rear blinkers? Roark 1986 - 2007 Ninja 250R Tech Talk 1 August 25th, 2014 10:14 AM
Need help with rear blinkers kennetht 2008 - 2012 Ninja 250R Tech Talk 40 November 27th, 2013 01:22 PM
DIY: Relocating the rear turn signals noche_caliente 2008 - 2012 Ninja 250R Tech Talk 6 August 15th, 2009 05:15 PM
DIY - Relocating the rear brake reservoir VeX 2008 - 2012 Ninja 250R Tech Talk 12 December 3rd, 2008 11:13 PM
Relocating rear directionals Sailariel 2008 - 2012 Ninja 250R Tech Talk 0 October 5th, 2008 06:14 PM
