Old April 24th, 2020, 05:52 AM   #1
ATLANTA
ATLANTA's Avatar
Motorcycle(s): 2005 Ninja 250r
Smile Hello Hello! What up though?
What's up everyone? I'm Jonathan, I live in Atlanta GA, and I finally have the pleasure of owning my very first bike, a 2005 Ninja 250r. It had been sitting in a shed for 2-3 years before I got it and within the last month I've managed to get it running at about 80% capability. It's still running mad lean, and will only run with the choke on, but it does extraordinarily well despite those setbacks. I'm always open to any suggestions, corrections, or wisdom anyone has to share. Also if anyone's in the ATL metro area I'm looking for some riding buddies.
See y'all on the forum!
ATLANTA is offline   Reply With Quote
Old April 24th, 2020, 06:08 AM   #2
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
ATLANTA! Glad you found us...
Old April 24th, 2020, 06:10 AM   #3
ATLANTA
ATLANTA's Avatar
Thanks man. I'm glad to have found you guys too. This sure has saved my bacon more than a few times already
Old April 24th, 2020, 06:48 AM   #4
ducatiman
ducatiman's Avatar
"will only run with the choke on"
classic symptom of pilot circuit varnish clogging, not surprising in view of 2-3 year dormancy
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old April 24th, 2020, 10:03 AM   #5
ATLANTA
ATLANTA's Avatar
Hey Gordon how're you? I've heard a great deal about you and read some of your posts, it's nice to talk to you finally. So the pilot jets were quite gummed up, you couldn't see daylight through them. However that was 2 cleanings ago and after guitar string, carb cleaner, and compressed air each cleaning I can see through all the small orifices just fine. Is there something else that could cause this symptom?
Old April 24th, 2020, 01:10 PM   #6
Jets are fine, leave them alone if you've cleaned them already. You'll want to scrub clean secret hidden fuel-circuits. Basically follow path of fuel from jets out to carb venturi.
Analogy I use is garden-hose with sprayer. People focus 100% on the sprayer, scrubbing it and poking it with wires until they can see to Catalina. Now... what about 50-ft of hose with 10 golf-balls stuck inside? Clean out that hose as well!!! Basically every where fuel flows that you haven't cleaned yet. You can use food-coloring (I like FDA#5) to drip into fuel-passages to see where it flows (or doesn't).
Last futzed with by DannoXYZ; April 24th, 2020 at 11:16 PM.
Old April 24th, 2020, 02:10 PM   #7
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Welcome!
Old April 24th, 2020, 02:51 PM   #8
ATLANTA
ATLANTA's Avatar
Jets are fine, leave them alone if you've cleaned them already. You'll want to scrub clean secret hidden fuel-circuits. Basically flow path of fuel from jets out to carb venturi.
That makes a lot of sense. Do you think you could give me a little more detail as to the process? I really want to give this a try
Old April 25th, 2020, 03:55 AM   #9
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
welcome from your east georgia neighbor
i do deal's gap/cherohala skyway, moonshiner 28. anything mountains. check out the rides sections
"trying not to get old"
Old April 25th, 2020, 07:14 AM   #10
Snake
Snake's Avatar
Hello and welcome!
How much did you buy the bike for? I’m looking for another bike for a friend and wondering what they are going for.
Old April 27th, 2020, 11:06 AM   #11
Hi Jonathan, welcome to Ninjette!
All info you need to know can be found in search for "clean carbs ducatiman". Note, due to regulatory changes, modern spray "carb cleaners" no longer work. They don't have chlorinated compounds such as trichloroethylene, carbon-tetrachloride, or chlorobenzene, which does actual job of cutting polyvinyl bonds in dried petrol. Nowadays, spray "carb cleaner" is just weak carrier solvents that does nothing. I used to clean off inside of sprocket covers with carb-cleaner, and it would drip out as tar-like sludge goo. Now, it drips off clear-grey having dissolved nothing.
Thorough cleaning process requires lots of manual scrubbing. i'll give you summary here. Process roughly goes like this:
1. Scrub out all hidden secret fuel-circuits beyond jets with brushes. Amazon - nylon brushes. I like to use 75/25% acetone mix with PEA-based fuel-system cleaner such as Chevron Techron, Red Line SI-1, etc.
2. Soak in ultrasonic cleaner for hours using polar solvent (PineSol, Totally Awesome, vinegar, etc.) Be aware that Simple Green dissolves aluminium, so avoid it. Amazon - 4L Ultrasonic cleaner
3. Scrub again with brushes. Pay particular attention to holes where fuel-circuits exit into carb-venturi (neon green dots in photos below). Remove deposits but be careful not to remove any metal as size of these holes are critical to fuel-metering
4. micro soda-blast all circuits to clean out debris. Use finest soda available AircraftSpruce - mini soda blaster
5. replace all rubber parts: float-valves, O-rings and seals
6. adjust float-levels
7. sync carbs with manometers. While old-style analogue gauges work, I prefer modern digital versions. carb-sync gauges
Be sure to completely disassemble emulsion tube and poke out all lateral bleed holes with copper wire . Same with pilot jets.
Originally Posted by n4mwd View Post
Here are the secret passages in the carbs. They are kind of hard to figure out sometimes and this picture guide will show where they are for cleaning purposes.
Carb Pilot jet Circuit
Carb Main Jet Circuit
Carb Fuel and Overflow Drain
Carb Diaphragm Intake, upper choke and vacuum ports
Carb Choke Circuit
All of this takes a lot of time and certain amount of experience. It takes me longer to do complete carb-cleaning job than it would take for complete engine tear-down and rebuild. Here's engine I rebuilt in less than one weekend, versus over a week for carb-cleaning. I prefer to just send them to ducatiman for refurb and restoration as he's all required equipment and is so much more experienced and efficient at it.
Last futzed with by DannoXYZ; June 7th, 2020 at 05:33 PM.
Old May 3rd, 2020, 09:57 AM   #12
Welcome!
Old December 10th, 2020, 07:13 PM   #13
NinjaPony
New rider
NinjaPony's Avatar
Motorcycle(s): 2021 Ninja 400 (abs), 2004 NinjaEx (2007 motor)
Wow! Thank you very much and also Damnit!
NinjaPony is offline   Reply With Quote
