Old June 1st, 2013, 07:52 AM   #1
WOTurtle
WOTurtle's Avatar
Motorcycle(s): 09' 250 ARRRRRR
pilot road 3 will not bead up
I just got my 150 70 pilot road 3 in from revzilla and the damn thing will not bead. Ive had it on my buddies tire machine and after no luck there took it to columbia powersports and despite getting to sit on and drool over the ninja 1000 for 20 minutes or so even they couldnt get it on. Tried the starting fluid trick once but it just burned on the edge of the rim and then went out.
WOTurtle is offline   Reply With Quote
Old June 1st, 2013, 08:07 AM   #2
http://www.dansmc.com/beadexpander.jpg
http://www.dansmc.com/rubberdonut.jpg
Old June 1st, 2013, 08:10 AM   #3
The KY version of that setup is a strap and tire iron. Wrap the strap around the tire, slide the tire iron between the tire and strap and turn the tire iron to tighten the strap around the tire.
Old June 1st, 2013, 08:11 AM   #4
WOTurtle
WOTurtle's Avatar
Already bought a ratchet strap. No dice. Whats up with the rubber doughnut?
Old June 1st, 2013, 08:21 AM   #5
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
You put it between the rim and bead, creates a seal and once enough air pressure builds the tire pops into place.
My Cafe Racer Build
My intro post
Old June 1st, 2013, 08:22 AM   #6
These bead seaters provide safe seating of tubeless bias or radial tires by pushing the tire off center and creating a seal for the air, so one side sets first.
You can improvise one with a rubber hose and a plug to hold both ends together.
As you surely know, the valve stem should be out and the flow of air should be as big as possible.
Use lubricant for tires,....lots of it.
Old June 1st, 2013, 08:26 AM   #7
WOTurtle
WOTurtle's Avatar
Soapy water isnt really cuttin it. I was thinking mabye canola or corn oil? Bad idea?
Old June 1st, 2013, 08:36 AM   #8
You can use anything that is not corrosive to aluminum (nothing caustic like soap) and is compatible with rubber (non-petroleum based).
This is the best I have used:
http://www.napaonline.com/Catalog/Ca...434_0006382737
Old June 2nd, 2013, 07:02 AM   #9
WOTurtle
WOTurtle's Avatar
Starter fluid and matches did the trick.
[RoadRUNNER] - Review: Michelin Pilot Road 4 Ninjette Newsbot Motorcycling News 0 August 11th, 2014 03:11 AM
[visordown.com] - New Michelin Pilot Road 4 tyres Ninjette Newsbot Motorcycling News 0 February 10th, 2014 07:50 AM
Michelin Pilot Road 4 Tires Review kaosbandit General Motorcycling Discussion 2 January 24th, 2014 03:08 PM
[webbikeworld.com] - Michelin Pilot Road 3 Review Ninjette Newsbot Motorcycling News 0 May 5th, 2012 05:50 PM
Just had some Pilot Road 2s installed austinm911 2008 - 2012 Ninja 250R Tech Talk 5 March 5th, 2012 11:23 AM
