Old February 18th, 2016, 07:27 PM   #1
jpanichella
Motorcycle(s): Electric Ninja 250
Electric Conversion, increasing ground clearance
Hey guys,
A little background on my project. It's a 2000 Ninja 250, I gusseted the frame and replaced the engine with a battery pack and electric motor that produces around 35 HP. The battery pack is from a salvaged Nissan Leaf. The bike's really fun, but I'm a little worried about ground clearance. I'm just exploring my options if it becomes a concern. Here's a few pictures of the bike.
When it's on it's side stand, the leaning corner of the battery pack is 6" off the ground. I was thinking about raising the bike, I did some research and found a place that does custom fork tubes at any length. I was thinking about maybe getting 1 or 2 inches over stock, and raising the rear end as well to keep the geometry the same. Will this change the rideability of the bike in any significant way? What do you guys think?
Thanks for your help.
jpanichella is offline   Reply With Quote
Old February 19th, 2016, 03:36 AM   #2
Welcome Jon!
Electric car engine on a bike! Sounds like a cool project but your pics are not showing up for me. Can you check the privacy or share settings on them in your google account so we all can see? I am really interested in how you mounted that all together.
In general... I would be worried about ground clearance via suspension as well. The pregen ninja's aren't really known for their spectacular springs. It sounds like you know this already but maybe you can just respring the stock tubes and totally replace the rear shock to something more suitable that would require much less customization and be a lot cheaper.
Old February 19th, 2016, 08:10 AM   #3
Ghostt
Ghostt's Avatar
No pics?
Why are you worried about ground clearance? Are you using it off road?
I agree about the PreGen suspension being soft, cheap solution is to get the spring, and shock from a NewGen.
violente et ignorantia
ZX-2R BLOG
Old February 19th, 2016, 08:21 AM   #4
Pics seem to be in a protected google account; the OP is likely the only one that can view them.
Old February 19th, 2016, 09:23 AM   #5
HoneyBadgerRy
HoneyBadgerRy's Avatar
Originally Posted by Ghostt View Post
No pics?
There is a thread over on Ex500's about cutting the stock springs to stiffen them up, and it had a formula about the current spring rating, your weight, and how much to cut off. Obviously you can only cut off so much without getting coil bind, however I has able to easily modify the stock ninja 250 springs to be rated perfectly for my 130-140 lbs and it was much cheaper than buying newgen suspension, or buying springs. As for the rear, a newgen shock is a ok cheap option, but I would opt for something with some adjustability.
I'm not sure why OP is worried about ground clearance, but If he is planning on taking the bike in rough off road like conditions, then maybe he would be better off buying a used MX shock.
Old February 19th, 2016, 11:28 AM   #6
Ghostt
Ghostt's Avatar
I cut mine too, but I had a pair of 1st Gen EX springs laying around, which are about .55kg and 20.5" in length, as opposed to PreGen @ .44, 18" in length The NewGen is about .65, less cut if you need to increase.
I had to cut about 5.5" off the EX, , which raised them up to about .82, 15" length.
The rear shock in a PreGen is crap, at least the NewGen is better for a heavy rider, about 200lbs, and you can adjust the preload to set the static sag, both modifications are easy enough to do as it's just replacing, no modifications necessary, unless your cutting the springs, and you can find them cheap on eBay.
ZX-2R BLOG
Old February 19th, 2016, 08:05 PM   #7
jpanichella
Hey guys, sorry about the pictures. Do these work?
Old February 19th, 2016, 08:07 PM   #8
Yes sir, those work just fine. Cool mods!!!! Spring it up as you see fit, you shouldn't have a ground clearance problem after that unless you're riding it on the track.
Well done!
Old February 19th, 2016, 08:09 PM   #9
Ghostt
Ghostt's Avatar
Now that is just awesome, well done sir, well done.
ZX-2R BLOG
Old February 19th, 2016, 08:32 PM   #10
HoneyBadgerRy
That looks cool. The only thing I can say is you should bondo the gas tank to hide the bolt holes, and make the ridge calmer. (Make it look more factory)
Old February 19th, 2016, 08:59 PM   #11
jpanichella
Thanks for the kind words guys! The tank is the last big task, that and finishing the 12 volt system. Here's a timelapse of the build and a ride by.
Old February 20th, 2016, 09:29 AM   #12
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
Hotness!
My Cafe Racer Build
My intro post
Old February 26th, 2016, 04:16 PM   #13
Mohawk
Mohawk's Avatar
Motorcycle(s): ZZR250, VFR800
Sweet, what motor & controller did you use ? I thought about doing this to a bike, but batteries are expensive. So recycling a wrecked car set is a great idea.
Old February 27th, 2016, 11:22 AM   #14
jpanichella
I used this motor and controller package:
http://www.evdrives.com/product_p/ck-1003.htm
You can source batteries locally, or this company recycles hybrid cars and sells the batteries individually. I used 10 of these modules.
http://hybridautocenter.com/HAC4/ind...ule&Itemid=605
Old February 27th, 2016, 12:20 PM   #15
crazymadbastard
what is the expected range? and which charger is used?
My Cafe Racer Build
My intro post
Old February 28th, 2016, 11:25 PM   #16
jpanichella
They're LED drivers made by meanwell, I'm doing a writeup and will include some more info.
Old February 29th, 2016, 04:40 AM   #17
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!)
MOTM - Nov '15
Mount the battery horizontally? Boxer style!
Excellent project! Well done, Sir!
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over
SLOWn60 is offline   Reply With Quote
Old February 29th, 2016, 04:51 AM   #18
MrAtom
MOTM - July '15
What does it top out at? 0-60 times? Does it like to wheelie? How far can you travel on one charge? So many questions!
Old February 29th, 2016, 06:08 AM   #19
Mohawk
Mohawk's Avatar
Not sure of the dimensions, but it looks like there would be room to mount the battery turned through 90degrees, so what is currently across the frame would be front to rear.
If you are worried about front wheel clearance, just put bike in choc's then remove the handlebars, lossen top clamps & remove fork caps, let forks colapse to full compression, theen see how much space you have left !
Old November 2nd, 2017, 09:07 PM   #20
jpanichella
Don't have enough posts for a classified thread, but wanted to let you know that the bike is for sale. Asking for $4900.
I finished everything up and it runs perfect. I also stiffened up the front end so ground clearance is a nonissue.
For sale is my custom built electric Ninja 250. Fully street legal and ready to ride. The last thing that needs finished is the gas tank, it's primed and ready for the new owner to put their mark on this bike.
Here's the basic specs:
Top Speed: 87 mph (that's the fastest I've gone, but I ran out of straight road)
Range: About 50 miles if you're driving in town
Charge Time: About 2.5 hours from your standard wall socket
Brand new Pirelli tires
Powdercoated Frame, Wheels and Hardware
New Brake Pads and stainless brake line
LED Headlight/Tail Light/Turn Signals
I started with a Ninja 250 frame, and built the bike around a battery pack borrowed from a Nissan leaf. Then I installed a battery management system that shuts off the chargers when the batteries are full, and gives me a warning when the batteries are dangerously low. The motor is a very commonly used EV motor by Motenery. The controller is an Alltrax and can be programmed via USB cable (custom throttle curves, etc.)
It's a great commuter vehicle. Always reliable, smooth, you won't smell like gas when you get there. You don't need to shift gears, it's just twist and go, like a scooter. Costs pennies to fill up when charged during off peak hours. I've documented the build below:
http://www.dotheton.com/forum/index.php?topic=64772.0
And of course I'll help you understand how it works and include all the documentation and wiring diagrams. Let me know if you have any questions or wanted to give it a try. I'm selling it because I want to try and convert a full sized vehicle next, it's a really fun hobby.
Old November 2nd, 2017, 10:29 PM   #21
Very interesting. What's the bike weigh?
Old November 2nd, 2017, 11:50 PM   #22
jpanichella
I haven't weighed it, but it feels like like it's sub 250 pounds. Most people who ride it immediately comment on how light it feels.
Old November 4th, 2017, 06:45 AM   #23
greenaero
Motorcycle Hypermiler
greenaero's Avatar
Motorcycle(s): 1999 & 2005 Kawasaki Ninja 250R's
very nice work!
235 MPG Hypermotorcycling to a better tomorrow
greenaero is offline   Reply With Quote
Old November 4th, 2017, 07:04 AM   #24
psych0hans
psych0hans's Avatar
Good luck! I'm going to attempt something similar and make a track bike out of a duke 390 rolling chassis.
Old November 9th, 2017, 05:56 PM   #25
NinjaBraap
NinjaBraap
NinjaBraap's Avatar
Motorcycle(s): 06 Ninja 636, 2016 Yamaha R3 (Street/Track), 2019 Ninja 400 Project Racebike
Now paint it black and wear bat ears! hahaha that's got to be one of the best 250 conversions ever!
Racer, Mechanic, Enthusiast. Vendor for Norton Motorsports
Subscribe to my Instagram and YouTube: Instagram
YouTube
NinjaBraap is offline   Reply With Quote
Question regarding ground clearance (pregen) Sirref Ninjettes At Speed 19 May 24th, 2014 09:44 PM
[topix.net] - Brammo Unveils Ground-Breaking Electric Motorcycles Empulse and Empulse Ninjette Newsbot Motorcycling News 0 May 15th, 2012 09:10 PM
[sportrider - latest stories] - Brammo Unveils Ground-Breaking Electric Motorcycles E Ninjette Newsbot Motorcycling News 0 May 15th, 2012 03:20 PM
[topix.net] - Brammo Unveils Ground-Breaking Electric Motorcycles Empulse And Empulse Ninjette Newsbot Motorcycling News 0 May 9th, 2012 12:00 PM
[superbikeplanet.com] - Clearance Clarence: Suzuki Offers $1000 Off In Clearance Even Ninjette Newsbot Motorcycling News 0 February 15th, 2011 03:40 PM
